11-26-2018, 05:10 PM | #2 |
A family of bimmers
2745
Rep 7,741
Fabspeed. But you gotta pay to play. A tune will hide the cel with a catless.
11-27-2018, 06:14 AM | #4 |
No 55mph
1621
Rep 8,476
Only catted DP that is guaranteed to not throw CEL is the FabSpeed with Hi Flow 200 Cell HJS Cat Elements as previously mentioned
Proven fact in my case as that is what I use in PA - passes Emissions Inspection every time, no CEL FabSpeed is actually based in PA so I made sure when I ordered they were certain. Tech stated they had many cars in PA using them without a problem & if my car didn't pass they would accept return for full refund Any other DP mfg. NOT using the HJS Cat Elements, that state they will not throw CEL, are full o poop And yes, they are expensive ~$1400 - should have bought one during Cyber Monday sale when they were 25% off They are truly a work of art & fitment is dead on
allblackcoupe12.00 BulsaraF36141.50 |
11-27-2018, 11:14 AM | #5 |
Rep 172
Love my Fabspeed, 5000 plus miles, no CELS
Wagner Competition Intercooler, ER Chargepipe, Fabspeed Catted Downpipe, Bootmod3 OTS Stage 2 93 oct
allblackcoupe12.00 |
11-27-2018, 11:58 AM | #6 |
Rep 4,324
saw this in the classifieds. seems worth it to inquire about.
https://f30.bimmerpost.com/forums/sh....php?t=1540794 |
allblackcoupe12.00 stlb5217.00 |
11-27-2018, 12:34 PM | #7 |
Rep 6
11-27-2018, 01:31 PM | #8 |
Rep 10,473
No issues with CG Precision.
Essentially same as Fabspeed with HiFlow 200 Cell Cat except its available with a larger custom output connection that increases flow to their exhaust system, which can be seen in figures 3-5 below. I have larger output diameter (3.5” instead of OEM 3.0”) from output all the way out the rear end. And the CG Precision are cheaper the Fabspeed. That said, Fabspeed is still a great solution, but there is a better one. Last edited by IK6SPEED; 11-27-2018 at 01:36 PM.. |
allblackcoupe12.00 1QuikWS61620.50 |
11-27-2018, 02:31 PM | #9 | |
Rep 1,288
I would of bought it but they have been out of stock for a longgggg time... went with fabspeed ... |
11-27-2018, 02:44 PM | #10 |
Rep 10,473
11-27-2018, 03:14 PM | #11 |
3441
Rep 79,211
Fabspeed is a good one I've also heard success stories with VRSF High Flow Catted and Wagner too.
11-27-2018, 03:41 PM | #12 | |
Rep 1,288
So in the end as they say you get what you pay for... I'm an Engineer and I only buy what works not based on price... with that said... everything I end up buying is expensive.... lol...... |
11-27-2018, 07:14 PM | #13 |
Rep 352
+1 for Fabspeed.
I have it installed since April along with Dinan stg4 + big turbo without any CEL. It also makes the MPE sound so much better.
2016 435i M-Sport | Carbon Black | 20" 624M Wheels | MPPK | MPE | M Performance Brakes | M Performance Steering Wheel II with Display | xHP | Dinan Stage 4 | Dinan Big Turbo | Dinan High Performance Intercooler | Dinan Intake | Dinan Shockware | Fabspeed Sport Cat Downpipe | Custom Quad Tips | Autotecknic Red Paddle Shifters
11-27-2018, 10:41 PM | #14 |
Rep 232
I purchased an AR design catted downpipe (200 cell), that was advertised to not throw a check engine light. I don't believe it's guaranteed, but it is advertised. I had some problems with my car recently, so I applied the stock tune on my BM3 for about 200 miles before taking it to the dealership. Check engine light came on after about 50 miles of driving on the stock tune. It could be a check engine because of the problem I'm having, but I'll know soon enough. The problem was fixed at the Dealership (under warranty). I'm sure they probably turned the CEL off before giving it back (my wife picked up the car from the dealership today, so I've yet to see it). I will drive about 50 miles on the stock tune to see if the CEL goes back on, before downloading the tune. If the CEL turns back on after 50 miles, it's likely that the hi-flo downpipe is setting off the CEL. I'll report back...
11-28-2018, 02:38 AM | #15 |
Rep 232
Question: You have 2 little holes in different spots on a downpipe, 1 gets attached to a sensor (I believe an O2 sensor), but what's the other one for? Do we plug it? If we do plug it, what type of material do we use to plug it? I'm sure this is an easy question for many of you, but my car has been running rough, and I'm trying to narrow down the problem. I found 1 of the 2 holes completely open. Is it supposed to stay open? Stupid question, I know. But please advise...
11-28-2018, 05:44 AM | #16 | |
No 55mph
1621
Rep 8,476
(1) is BEFORE the cat element and is used for the upstream O2 sensor (regulating lambda probe) that is used for engine management/control (1) is AFTER the cat element and is used for the downstream O2 sensor (lambda monitor sensor) that monitors functionality of the cat I'm guessing that this DP was not installed by you? If you have (1) of those bungs open, with NO O2 sensor installed (I'm guessing the one missing is downstream O2 since car would not run without the upstream O2 installed) that would definitely affect how the car is running & should be causing a CEL constantly
Logicoeur991.00 |
11-28-2018, 10:20 AM | #17 |
Rep 75
5K miles on my Fabspeed with no CEL and custom tune on MHD platform.. Had a small fitment issue in that the flange had to be machined down a bit to ensure a good fit to the turbo,, but a minor nuisance handled by the installer.. all in all happy with the results
11-28-2018, 03:02 PM | #18 |
Rep 1,288
What? don't say this... great... I'll let the installer know... did it look like a one time deal or possible just that's the way it is... first I've heard of fitment issue... How long ago did you install this... hoping I have a newer better batch...
11-29-2018, 01:56 AM | #19 | |
Rep 232
As far as the downpipe; I have a 2015 335i M-sport with an AR design catted downpipe. After some recent trouble with the car, I had a non tuner mechanic (Porsche Master Tech) take a peek under the hood to see if there's anything out of place. I was actually the one to notice that nothing was connected to the lower bung. The tech inspected the downpipe and saw that the bung was completely uncovered and was open all the way through. This tech is a smart guy, but he does not work on modified cars. When he saw the open bung, he capped it off with something (I'm not sure what). He said having that open could trigger a CEL and possibly effect the cars performance. So was that wrong? Should I not be covering the hole? Is there something that fell out that needs to be reconnected? Please advise... The car was at the Dealership for a day, then my wife has been driving the Beemer for the last 2 days, so I've yet to drive it. I'm still on a stock tune and the car has yet to set off a CEL. My drive to work is 50 miles. I'll drive it to work tomorrow, and if I don't have a CEL light by the time I get to work, I'll re-install the BM3 tune. |
11-29-2018, 02:06 AM | #20 | |
Rep 1,044
Also +1 for Fabspeed. Almost a year with no issues. |
11-29-2018, 07:26 AM | #21 |
Rep 176
11-29-2018, 12:18 PM | #22 |
Rep 1,934
Tuned or no?
