09-09-2020, 01:38 PM | #89 |
Rep 4
My Experience was this
only works for my f13 if the setting KMFRT_SCHLIESSEN is set to 00
this ensures that when you press lock there is ZERO delay in that very split second you press the lock button. Hope this helps. Thanks to those who contributed previously. |
12-01-2022, 04:08 AM | #90 |
Lord C.M.Baksa
Rep 2
Hi, as a novice I wish to know how to operate the electric mirrors from the Fob.
I have a BMW 420i convertible F33 and would like to know how to setup to operate the mirrors from the remote. |
07-02-2023, 12:31 PM | #92 |
Rep 3
Automatic tilt passenger mirror problem
Hey All! Newbie here!
I am hoping I can get some help for my F22 240i. From the factory it has a dimming interior mirror, but the exterior mirrors are folding manually and heated. Thanks to the instuctions i found on this forum i undestood that i could swap the mirrors. I bought 2 new powerfolding exterior mirrors and interior switch with extra button, i changed the 3 wires as mentioned and i started the coding. I have not the E sys and the experience to use it, so i coded as i write below via bimer code(expert mode). FEM_BODY 3053 KOMFORTSCHLIESSUNG_FB aktiv FEM_BODY 3053 KOMFORTSCHLIESSUNG_PA aktiv FEM_BODY / 3053 / KOMFORTOEFFNUNG_FB aktiv FEM_BODY / 3053 /KOMFORT_SCHLIESSEN werte 00. FEM_BODY 3110 ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN aktiv FEM_BODY 3110 ASP_GESCHWINDIGKEIT_AUTO_AUSKLAPPEN 14 (20km/h) FEM_BODY 3110 ASP_MAX_GESCHWINDIGKEIT_BEIKLAPPEN 14 (20km/h) FEM_BODY / 3110 / ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN aktiv All worked perfectly and thank you a lot for the information i got from you. I have only one problem so i would apreciate your help. The automatic mirror tilt of the passenger mirror isn't working. I know that so it could work the button must control the driver's mirror, but when i put the reverse, the mirror's glass does not move at all. Except the normal mode settings i changed, i also used the expert mode and activaded the codings i write below: ASP_BORDSTEINAUTOMATIK aktiv ASP_BORDSTEINAUTOMATIK_DELTA 5A ASP_ELEKTROCHROM_SPIEGELGLAS aktiv Is there anything else that i should do? Have i made any mistake? Is something missing? If that helps, some information regarding the car: M240i LCI 2018 model - Left hand drive(Greece) - 6MT - Android 10 Head unit - Aftermarket back camera Thank you a lot in advance. |
07-04-2023, 07:54 AM | #93 | |
Rep 3
ASP_MEMORY_BERBAUT: aktiv (0x01) |
07-24-2023, 05:11 AM | #94 |
Professional Nomad
679
Rep 128
I tried coding the mirrors to fold on my 2019 F36 with Carly and could never get it to work. I was left to use the folding mirror button on my door arm rest to fold them. Frustrated, I ended up getting a license for BimmerCode and a OBDLink CX Bimmercode Bluetooth 5.1 BLE OBD2 Adapter and was able to code this with my initial attempt in a matter of minutes. I wish I got BimmerCode in the first place.
07-25-2023, 06:16 AM | #95 | |
Coding ECU's remotely
445
Rep 1,172
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
RobotDoctor678.50 |
07-25-2023, 11:23 AM | #97 |
Professional Nomad
679
Rep 128
07-25-2023, 11:31 AM | #98 |
445
Rep 1,172
