03-17-2020, 05:47 PM | #1 |
Rep 99
Help with ISTA+
Greetings!
I have setup the latest ISTA+, using ENET cable on a new laptop, after my old one died. Both laptops were running Windows 10, and both using the same exact software versions. Difference is, I can not update or do a control unit replacement, and I can't for the life of me figure out what's going on. The software sees the firmware I have is newer, and does the measures calculation, but the execute measures plan stays grayed out. See attached picture. Same thing when going to replace a control unit. I have done this install, and have gone over the instructions over and over trying to figure out if I missed a softwareinstall, or step, but I can't see where I have. If anyone has a hint, let me know! I do have the full PSDZData not the lite, so I'm not sure... Thanks! |
08-29-2020, 11:16 AM | #2 |
Rep 99
I was wondering,
Do I need an icom to do software updates on ISTA on F series now? I did one before on an older (2019 version) so I know it used to work with just the ENET adapter. Thanks in advance! Bonus question, do those cheaper icom clones work? I have no problem buying the official one if it gets me access to software and coding new modules access, but if the cheaper ones do this too I'd give it a shot. Thanks! |
09-13-2020, 10:21 AM | #3 |
Rep 99
Bump
Anyone know of this? I've tried reinstalling the latest software for ISTA+ and full psdzdata and the software update calculates but stays grayed out. |
09-13-2020, 11:37 AM | #4 |
Rep 2,302
You can not do software updates with ISTA with an enet cable.
At least you need an ENET emulator or something for that. I do not know exactly. Then you need the SDP-Data and BLP-Data for doing updates. The SDP-Data are the psdzdata Full but in a special folder. The BLP-Data are the psdzdata Lite in another special folder. Then also the programming function has to be activated in the registry for ISTA. |
09-13-2020, 12:55 PM | #5 | |
Rep 99
I know before just using the same cable I have now and an older version (2019) of ISTA it did work. I will look about this change to enable programming, maybe I just have a setting wrong, but I haven't found it yet. Thanks, Sean |
