09-20-2020, 11:21 PM | #89 | |
Rep 7,606
09-21-2020, 07:57 AM | #90 | |
Rep 2,639
here's a fix: https://www.bootmod3.net/log?id=5f65...729b1efbe82987 It ran better later on during the track as it was still adapting, but it needs some work. I don't plan on getting a custom tune until I get my hands on a DE HPFP.
09-22-2020, 09:15 PM | #92 | |
Rep 2,639
09-22-2020, 10:52 PM | #93 | |
Rep 7,606
harkes1077.00 |
09-26-2020, 09:58 AM | #94 | |
Rep 62
https://www.bootmod3.net/log?id=5f6e...0b4309108775c5
KWV1’s, Remus sport exhaust, VSRF hi-flow cat, TIC & Charge pipes, 5” stepped intercooler; turbosmart BOV,MST V2 inlet, MHD Stage 2, oem m437 wheels, m performance alcantara steering wheel.
09-26-2020, 09:58 PM | #95 | |
Rep 4,140
09-26-2020, 10:00 PM | #96 |
Rep 62
After
10-08-2020, 01:09 PM | #97 | |
Rep 2,639
I was sent a replacement unit to replace the one I have, and after testing, the old one I had had a defective solenoid cable, we just sent the entire old unit back and replaced it, now everything works, no codes, no nothing, just whoosh sounds!
10-08-2020, 01:15 PM | #98 |
Rep 7,606
Nice, thanks for the update. I am currently testing the CTS intake and there is SO much whoosh sound even with stock DV. Review and comparison on that + dinan + OEM MPPK setup coming soon after i finish logging tomorrow!
Pussiwillow521.00 |
10-09-2020, 06:13 PM | #99 | |
Rep 2,639
As you can see, WGDC is about 10% less than DV+ or stock DV, I believe Pureturbos even advertised between 10-20% less WGDC as well for the Turbosmart. I had between 61-68% WGDC using the same map with the DV+, it also looks like AFR is very stable as well, hell this BOV literally fixed most of my OTS map problems. I actually recommend this over DV+ for sure, and if you run custom, I'm sure with the reduced WGDC, you can probably squeeze out a bit more boost. https://www.bootmod3.net/log?id=5f80...0b4379a0b37bfc
10-12-2020, 04:25 AM | #100 | |
Rep 2,357
(A Dane in China) |
10-12-2020, 11:18 AM | #101 | |
Rep 7,606
10-12-2020, 03:56 PM | #102 |
Rep 2,639
Honestly, I think it would be a 5-10% difference, the turbosmart holds boost much better and I believe you might not overboost much on EWG as it's not vacuum, but I think it'll help with holding boost through shifts, plus you don't need to do maintenance on it like the DV+
10-12-2020, 04:03 PM | #103 | |
Rep 7,606
Anyone have datalogs on the same tune with EWG before and after DV upgrade? |
10-12-2020, 09:21 PM | #104 | |
Rep 2,639
10-13-2020, 12:20 AM | #105 |
Rep 7,606
Those are EWG numbers? Where'd you read that? You're getting me a little hyped even though i dont think even 5% is achievable for just DV upgrade on a OTS map, but i will highly consider ordering the TS DV if it goes on sale for black friday to confirm or deny this theory. Would just like to see some data before then.
10-13-2020, 01:07 PM | #106 | |
Rep 2,639
thejeremyman94363.50 |
10-13-2020, 01:45 PM | #107 |
Rep 7,606
Thanks for the link. The way I interpret this is that its not clear if its for EWG or PWG (i think PWG) and "on some cars" means the baseline car had a horribly leaking DV causing excessive WGDC and the TS DV fixed that issue. So a EWG car with a working OEM DV going to a TS DV would see significantly less improvement. But hey, maybe i am just a pessimist.
10-13-2020, 02:40 PM | #108 | |
Rep 2,639
10-20-2020, 04:06 PM | #109 |
Rep 198
sub'd. Planning on purchasing a pure stage 2 kit on black friday and deciding between the DV+ and TS EM BOV. Interested to hear if the version pure is posting about is the recirc version or VTA. For what its worth I had a pneumatic BOV on my last car that had a factory ECU operated recirc valve and that caused no AFR issues. The pneumatic BOV was a PITA though in terms of throttle response, ECU controlled BOVs are definitely the way to go. My current take is that the easier install of the TS EM BOV, slightly better throttle response, and need to lubricate the DV+ every year or so is well worth the extra $135 for the TS BOV. Interested to hear everyone else's thoughts though. It seems like I have a much clearer choice than those of you who already have the DV+ installed on your vehicle and are facing the decision on whether it is worth swapping out or not.
10-20-2020, 04:16 PM | #110 | |
Rep 7,606
After running the CTS intake for a bit (see my intake review thread), there's no way i would get a VTA BOV given how loud the recirc is with a non-closed box intake. Potential concerns with dumping metered air aside, the noise would have to be excessive and i would be worried it would get old fast, unless you are specifically seeking that. It's funny because with the CTS intake, i keep wondering what it would sound like with no DV and a bunch of compressor surge lol. |
