BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > How do you launch 335i AWD 6 Speed
proTUNING Freaks
      07-20-2020, 01:56 PM   #1
FancyTie
FancyTie's Avatar
Drives: 2013 335i M Package 6spd
How do you perfectly launch a 335i AWD manual? I just bought it and I don't know where to shift perfectly. It takes no time to reach 6k rpm on 1st gear and if you change to 2nd gear, it goes to 4500rpm and I don't think that's the best way to do it. I've seen some thread where people start on 2nd gear.
Any tips?
      07-20-2020, 03:24 PM   #2
brigade24
brigade24's Avatar
Drives: 2013 335 X-dive
if you keep the traction control on, it has launch control. put it in sport+ mode, clutch in, mash the throttle and it will rev to approx. 3000rpm.
Other wise you gotta do it by feel. Keep in mind that the F30 has a clutch delay valve so even if you dump the clutch, the clutch will engage slowly to not damage anything. I believe the intent was to protect the differential but don't quote me on that.
I believe the clutch delay valve is integrated into the slave cylinder so many folks swap in an e90 slave cylinder since the clutch delay valve for it was remotely located.
      07-21-2020, 05:30 PM   #3
sqwinny
Drives: 2013 6MT 328i M Sport
You can remove it and eliminate it or "drill it out" to increase the flow. I found this recently myself. Just need an extra hand and will be removing this little piece of metal:
DIY: Clutch Delay Valve Removal https://f30.bimmerpost.com/forums/sh....php?t=1686574
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
      07-22-2020, 04:56 PM   #4
brigade24
brigade24's Avatar
ah so no purchase required!! excellent!! thanks!!
