10-15-2020, 03:58 PM | #1 |
Rep 22
4 series LED reverse bulbs
I am looking to buy some LED bulbs for my reverse lights. Any idea on where I can find them? Most of the bulbs i find come from 3 series bulb sizes that dont fit on the 4 series.
Thanks in advanced!
IG: @Matty1k
10-15-2020, 04:10 PM | #2 |
Rep 16,139
Find out what bulb you have in your lamps, google that number along with 'LED'. Amazon is usually the best source. They will require coding, there's no getting around that.
10-16-2020, 01:08 PM | #3 | |
Rep 417
I ordered the PW24W and should receive it today. I will follow up on how they fit/perform later. |
Tooadvanced13.00 |
10-16-2020, 01:11 PM | #4 | ||
Rep 22
IG: @Matty1k
10-16-2020, 08:21 PM | #5 |
Rep 417
Got these and just installed them. It is directional so you don't have to deal with +/- terminal problem like other bulb type. Now just have to change some settings on ECU...
One minor trouble is to putting back in the carpet cover. The emergency trunk release and the red clip for the cable can be hard to clip back in and the clearance is pretty tight. In terms of the bracket for the bulbs, there are 3 clips. One is in gray and pretty obvious, the other two are hidden but it is easy to push the fin-like clips to release, then you pull straight down. Other than that it is a 10-15 minutes job. |
10-16-2020, 08:57 PM | #6 | |
Rep 22
IG: @Matty1k
10-17-2020, 08:19 AM | #7 |
Rep 1,700
Drives: 2014 428i and 2018 X5
Amazon or eBay. Not that hard.
10-20-2020, 09:07 AM | #8 | |
Noob
70
Rep 255
FBO, MHD Stage 2+ E20, Xhp Stage 3
10-20-2020, 10:28 AM | #9 |
Rep 417
I realized if I open the driver side door, the car will shift back to Park. Had to climb over to take these
10-20-2020, 03:44 PM | #10 | |
Noob
70
Rep 255
That looks nice, I like it. I also like how you blackened the 435i badge it matches the exterior and blends in, I have a silver one and if I did it on mine the contrast would make it look boy racerish IMO now all we need is the LCI tail lights
10-20-2020, 05:31 PM | #11 | |
Rep 417
Initially I wanted to de-badge, but I don't want to put it back on if I want to sell later. I had a plasti-dip laying around so I just sprayed it. Speaking of taillight, I actually like pre-LCI better. GTS ones are nice too, now I just need to convince her we need a GTS for... groceries |
10-31-2020, 07:31 PM | #12 |
Rep 22
428 led reverse bulb
Finally got the bulbs put in. Coded them using bimmercode "LED"
These looks very bright. They really light up in the darkness. (Reverse bulb) Xenon White PW24W PWY24W LED Bulbs For 4 series Signal or DRL Lights https://www.ebay.com/itm/273704922862
IG: @Matty1k
04-16-2021, 02:51 AM | #13 |
Rep 26
Can anyone confirm then that any PW24W LED, whether it be a DRL, Signal or reverse, will work in the reverse light socket of a 4 series? There are tons of them on eBay stating DRL but I am having a hard time finding any that specifically say for reverse.
04-16-2021, 07:49 AM | #14 |
Rep 16,139
It doesn't matter what it says for position. What matters is that it's white, and the base looks exactly like the picture above. If it doesn't it won't fit.
04-16-2021, 09:54 AM | #15 |
Rep 26
04-16-2021, 10:04 AM | #16 |
Rep 16,139
I can assure you that the bulb doesn't know or care if you use it for DRL, signal or reverse. All that counts is, and I quote, "What matters is that it's white, and the base looks exactly like the picture above. If it doesn't it won't fit." Besides, Tooadvanced already answered your question, with pictures to boot.
