10-19-2020, 04:57 PM | #1 |
Rep 424
Throttle body clean and coolant flush
Went to dealer for oils change vehicle check on a 2017 f36 with 28k mi. Dealer says I need throttle body carbon clean up and coolant flush due every 3 years. Anyone done these already?
//'17 F36 440i Mineral Grey
//MPPSK w/carbon tips //Apex ARC8 255/40/18 //MST intake //AutoTechnik brace |
10-19-2020, 05:25 PM | #2 | |
David
786
Rep 2,009
I'd ask for pictures of the throttle body it's probably spotless at that mileage. If I remember coolant is 10years/ 150k HOAT
j2dad5389372.00 |
10-19-2020, 05:27 PM | #3 |
Rep 16,082
How much does he want to clean the throttle body? All he's going to do is use a $12 can of CRC spray, an easy DIY job. Coolant only needs to be flushed if it turns brown, indicating rust in the cooling system.
10-19-2020, 06:30 PM | #4 |
Rep 1,502
Coolant flushes aren’t on a fixed schedule anymore. I’d definitely be cautious with future service recommendations from that particular dealer.
10-20-2020, 07:35 AM | #5 |
Rep 919
Add a bottle of Techron every few months.
10-20-2020, 07:38 AM | #6 |
Rep 424
Thanks guys, I already did the maintenance but should of held off I'm thinking of going to a different dealer from now on as these guys just tag on shit to get you to pay seems like.
10-20-2020, 07:43 AM | #7 |
Rep 849
Drives: BMW 435i
The throttle body "service" or "induction system service" seems to be standard fare these days with just about every dealership from every brand. Must be a great profit item for the service department.
I've had the same thing recommended by every dealership I've been to recently; VW, Honda, Toyota, and Mazda dealerships in my area. Oddly enough my BMW dealership hasn't mentioned it...yet.
10-20-2020, 07:52 AM | #8 | |
Rep 424
10-20-2020, 08:20 AM | #9 |
Rep 849
Drives: BMW 435i
Agree, and I've yet to see it on any service schedule for any car I own/have owned. Can't believe people fall for it.
10-20-2020, 08:23 AM | #10 | |
Rep 424
10-20-2020, 08:37 AM | #11 | |
Rep 16,082
That's good advice for keeping the injectors clean, but not the throttle body, intake manifold or intake valves. You clean those with intake cleaner. Even better, install an oil catch can to prevent the oil that causes carbon deposits from making those components dirty in the first place.
And they buy it wholesale by the case. |
10-20-2020, 10:26 AM | #12 |
Rep 919
Thank you, Bill! I'd removed my TB to clean it and my idle control valve in e46 and it stayed clean for maybe 7-8 years. Didn't even think that this car might have other gizmos! I will put this cleaner on my list!
10-20-2020, 11:10 AM | #13 | |
Rep 1,597
10-20-2020, 11:40 AM | #14 |
Rep 16,082
When I use it I put a piece of wood from the driver's seat to the gas pedal, using the seat adjustment to move it forward just enough to keep the RPM at 2500 while injecting the cleaner. Spraying it with short bursts the engine never hesitates. I remove the MAF sensor, spraying through that opening. While you've got it off clean the MAF sensor, using MAF sensor cleaner. Don't use the intake cleaner on the MAF. It's the same active chemical, but the intake cleaner is far more concentrated, and will damage the MAF sensor.
10-20-2020, 11:48 AM | #15 |
Rep 303
From the product’s info page, though...
“Not a throttle body cleaner” So, does it do the actual job or were you recommending using this as an intake cleaner? Thanks! |
10-20-2020, 01:33 PM | #16 |
Rep 906
Coolant flush
Coolant changes used to be done as factory-recommended maintenance every two years. Now BMW sees it as lifetime fluids.
Mike Miller's maintenance guide still recommends a coolant change every two years. It's not required maintenance, but recommended preventative work if you plan to keep the car long term. Same boat as transmission fluid changes.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
10-20-2020, 01:39 PM | #17 |
Rep 16,082
It's not a throttle body cleaner per se but when you inject it through the MAF it will clean the throttle body along with the intake manifold and valves. They probably say it's not a throttle body cleaner because throttle body cleaner wouldn't be sufficiently concentrated to clean the manifold and valves. Since deposits on the manifold and valves are far more problematic than deposits on the throttle body it wouldn't make any sense not cleaning all of them at the same time.
10-20-2020, 01:46 PM | #18 |
Rep 975
If there was evidence that frequent coolant flushes prevented the plastic cooling components from crumbling, I'd probably do it yearly.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
10-20-2020, 04:13 PM | #19 |
Rep 424
Here's the rundown
10-20-2020, 04:13 PM | #20 | |
Rep 16,082
Fliplegend1471.00 Wgosma806.00 |
10-21-2020, 01:22 AM | #21 | |
Rep 906
10-21-2020, 06:56 AM | #22 |
Rep 16,082
It does, and corrosion can occur. If you don't see any change in color then a reasonable change interval is 6 years or 100,000 miles. If you don't want to fix what isn't broken, or fail to fix what is broken, get some coolant test strips. A lifetime supply will cost you less than $20.
https://www.amazon.com/Cool-Trak-311...ag=googhydr-20 Another method to test pH is with a DMM. Last edited by Billfitz; 10-21-2020 at 07:24 AM.. |
