BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > AUSTRALIA > Coolant Leak B58
      10-30-2019, 06:29 PM   #1
chrisveal
chrisveal's Avatar
Drives: BMW M6 Gran Coupe
Coolant Leak B58
So my 340i randomly dropped about 2 litres of radiator fluid yesterday at lunch (drove to lunch, about an hour for lunch, walked back to car and it was over the ground). I couldn't see where it came from, it also "sounded" like the water in the reservoir was boiling which seems odd/wrong as the temp never even got to 110C. I had no low level coolant warning or over temp either.
So I filled the system with fluid, bleed it and took it for a drive 30-40 min, got home, parked it up. I check post 30 min, no leak. Got up in the morning and it had dropped about a litre over night. It also is dropping in both reservoirs, I thought they were independent of each other?
Can anyone give some advice please?
Cheers
Chris
      10-30-2019, 06:38 PM   #2
BMWILUVU
Drives: 340ix
Cheers
Chris
Pressure test the coolant system. Most of our leaks are (in order of most to least frequent):
radiator cap leak
reservoir leak
turbo leak
      11-01-2019, 08:10 PM   #3
chrisveal
chrisveal's Avatar
I have dropped my car off at Brisbane BMW, it turns out that the water pump has a leak and requires replacement.
      11-05-2019, 04:00 AM   #4
chrisveal
chrisveal's Avatar
Picked up my 340i today and can not fault the guys at BMW Brisbane. They covered the pump plus extras under warranty and my cars back home running sweet.
BMWILUVU834.00
      11-05-2019, 12:27 PM   #5
cfm56d7b
Drives: 2025 BMW X6 M60i & 2015 BMW X5
Glad it all worked out on the first service visit.
      11-06-2019, 12:24 AM   #6
misguided_will
misguided_will's Avatar
65
Drives: 2018 BMW 340i M Sport
how many kms has your car done?
2018 F30 BMW 340i M Sport
Injen EVO intake, OEM 437m rims, Catted VRSF dp, Magnaflow catback, Activ8 piggyback, Pedalbox.
      11-07-2019, 04:05 AM   #7
chrisveal
chrisveal's Avatar
Hey mate, my car had done 67k
      02-02-2020, 04:49 AM   #8
juld0zer
482
Drives: Prev 135i 7DCT, Now 130i 6sp
radiator cap leak
reservoir leak
turbo leak
Don't take this the wrong way but I don't think this is correct. The high temp cap has been around for ages and is a proven design. They usually fail from oil contamination (yet to be common on B58) or mishandling (impact damage to the tip).
B58 F chassis cars usually come from the factory improperly bled. This will confuse a lot of people but a pressure test will yield nothing. Most should have been taken care of by now as this issue usually occurs within the first 15k
Next is either stone impact to the low temp radiator (the two circuits are linked) or the belt driven water pump leaking at either the weep hole or the reservoir cap on the pump.
B48 models are getting on with age and we are seeing the vent pipe to the cylinder head fracturing underneath the manifold. It's a crap design. Thermal cycling and vibration
Urbz8.00
      02-02-2020, 01:46 PM   #9
BMWILUVU
Drives: 340ix
B48 models are getting on with age and we are seeing the vent pipe to the cylinder head fracturing underneath the manifold. It's a crap design. Thermal cycling and vibration 🤦🏻*♂️
Lot of people have coolant residue around the cap. Mine did leak.
      04-06-2025, 01:16 PM   #10
Gyurco1
Gyurco1's Avatar
Drives: BMW F10 535d
i have test drive on 540i and when car come to me about from 3 mails drove i open bonet and and i see boiling noise coming from coolant tank i try to opened but coolant start coming out
      04-10-2025, 08:40 PM   #11
LUX3
52
Drives: BMW F30 330i
I also am cursed with the B58 F coolant consumption.
At 60000km have been topping up 100ml every 1000km.
Went to independent garage and tech performed pressure test but found no leak.
He felt confident that water pump was the problem so that was replaced.
Did absolutely nothing to stem the constant coolant consumption which has continued unabated.
Don't see the cap leaking.
What now? Guess I will keep topping up....🤐
      04-15-2025, 12:02 PM   #12
b48user116
Drives: BMW F30 330i 2018
Try another indy shop for BMWs only. Do your exhaust fumes smell sweet?
      04-15-2025, 09:42 PM   #13
LUX3
52
Haven't noticed that.
      04-16-2025, 09:48 AM   #14
b48user116
What about the thermostat? Last time I changed mine, it was stuck open. Guess what? It was leaking too
