02-27-2021, 12:13 PM | #1 |
Rep 145
Drives: 2017 F31 330xi
KSP spacers?
I came across these KSP wheel spacers on ebay, they are a fraction of the cost of the popular brands.
Good deal or run away? https://www.ebay.com/itm/12mm-15mm-B...4/284003210272 It's just a piece of aluminum, as long as it's balanced and there's no vibration, shouldn't they be good or am I missing something? I'm all for buying quality, but not spending money just for the sake of it. |
02-28-2021, 06:46 PM | #2 |
Rep 145
I can't tell if I asked a really dumb question and everyone is just being nice or no one else has seen these spacers?
02-28-2021, 07:26 PM | #3 | |
Rep 4,314
maybe you can "take one for the team" and try them out for the group? |
02-28-2021, 11:32 PM | #4 |
Rep 145
alohasurftoad3069.00 |
03-04-2021, 09:32 PM | #6 |
Rep 145
I ordered a set. We'll see how it goes.
03-17-2021, 07:17 PM | #7 |
Rep 246
I run these on the daily driver with no issues at all. I would say quality is pretty good, but find some of the edges sharp to the touch so be careful. I do like the bigger cut out holes and the notches for easy removal. Also, with the 12mm spacers I run, they clear the hub that protrudes further than previous Bmw's. I tried running name brand 12mm spacers prior but had issue where the spacer would not sit on the hub face due to the longer hub. With that said, I am using my own bolts purchased else where and check torque regularly..
damack188.50 |
03-17-2021, 09:17 PM | #8 |
Rep 145
Mine just showed up today. I won't be putting them on until I put in the new springs and swap in the summer wheels
03-19-2021, 04:04 PM | #9 |
Rep 413
sub'd. I am looking to do the same size spacers on my OEM staggered 19's when the cold weather is gone. looking forward to seeing how this goes. How will you know if they are balanced properly?
03-19-2021, 06:16 PM | #10 |
Rep 145
I'd say go for a drive and see if there is vibration.
04-26-2021, 10:15 AM | #11 |
Rep 145
I finally put these on with my winter wheel change this weekend. They fit perfect, no play at all and no vibration. I used 12mm for the front and 15mm rear and it suits my F31 with the 403 staggered setup well. I can't see a reason for paying double.
04-30-2021, 04:35 AM | #12 |
Rep 89
What size wheels and tires?
04-30-2021, 09:32 AM | #13 |
Rep 145
04-30-2021, 12:27 PM | #14 |
BMW CCA Member
488
Rep 808
FWIW, generally for a spacer, it's more about how it sits on the hub... like a perfect fit, and does it have a nice lip to hold the stock wheel in place. CNC aluminum isn't going to be off-balanced, and especially since it's center of the wheel versus being on the outside.
The BIGGER concern is the bolts. Obviously you need longer bolts and of good/high quality. But same, ran a set of Stanceworks spacers which really looked THE same as every other vendor (hole cuts, polish, etc.) for close to 1 year with REALLY aggressive driving. ZERO issues with alignment or balance. |
08-29-2022, 07:46 PM | #15 | |
Rep 38
Hi Damack, May I ask how those KSP spacers performing over time? I am also interested in buying a set... many thanks |
VP_5675.50 |
09-03-2022, 09:27 PM | #16 |
Rep 145
