05-07-2019, 09:05 AM | #67 |
Rep 9
Yesterday I received mine from Unique. I previously watched some video's on how to do the install and in 1 they unhooked the car battery in the manual it just says make sure the car is in off position.
Did any off you do this without disconnecting the car battery? Disconnecting the battery on an F31 is a pain. |
05-07-2019, 09:48 AM | #68 | |
Rep 1,687
Drives: 2014 428i and 2018 X5
05-07-2019, 12:29 PM | #69 |
Rep 170
Drives: iX3 M Sport
Same here, no battery disconnection. I had the unit playing as I was rebuilding to make sure I didn't tap anything that would stop the system working.
Current Car: iX3 MSport Sophisto Grey
Previous Car: F31 320d ED |
05-07-2019, 02:53 PM | #70 |
Rep 88
I finally got to installing the Unique CarPlay unit. I have the full nav and optic fibre, so it was a pain to install (removing glove box, trying to fit all those cables in the tiniest of spaces, even just getting the iDrive unit back in there took me a while because of the extra connector). But I got it working and it's working great!
I'm really happy with it. It's fast and all apps work perfectly. Only thing I don't like is that Spotify sounds worse than when using the BMW Spotify. So I keep Bluetooth connected to BMW for calls and music and use Wifi for everything CarPlay related. I also got the NO SIGNAL thing. It also went away after closing the car and unlocking it after a couple of minutes, but it wasn't a great start. I hope they will fix this with a software update. But the biggest issue is that I now have the following error: "Safety system passenger Malfunction / Failure in the passenger safety system. Make sure to put your seat belt on. Let a nearby BMW Service centre check your car." Any idea what this could be? I already got this error message the moment I turned on the CarPlay unit for the first time, while everything was open and cables were hanging out. I assumed it had to do with the airbag lock on the right side of the car, because that cable was disconnected, but when I put everything back together, I still got the error (the lock on the side is working). I haven't touched any other cables related to safety systems. Any ideas? |
theblues86.50 |
05-07-2019, 03:05 PM | #71 | |
Rep 1,687
05-07-2019, 03:12 PM | #72 |
Rep 88
I will try that. Do you have any suggestions which ones to check? There were two cables connected to the back of the glove box compartment (I didn't take them out though), are those related to that? It might also be a sensor or something related to the seat belt.
I also read it's possible that because I turned on the car while the cable of the passenger airbag lock was disconnected, the error stays until it gets reset by a dealer. It sounds plausible, as all connectors are so sturdy (even by force some barely come of), I can't imagine them ejecting by accident. |
05-07-2019, 03:43 PM | #73 | |
Rep 1,687
But from what I remember, there is only one connection for the airbag, and all those that are connected to the glove box aren't related to the airbag
05-07-2019, 04:09 PM | #74 | |||
Rep 88
I removed the side panel where the airbag lock is. Disconnected the cable. Then removed the bottom plastic plate. Then the glove box with he cables connected. That's it. |
05-07-2019, 04:38 PM | #75 |
Rep 88
On another note, has anyone here tried to connect a second iPhone wirelessly to CarPlay? My wife also uses my car and also has an iPhone. How would she connect the first time? Also by cable like the initial pairing? And what happens if we are both in the car?
05-08-2019, 09:20 AM | #76 | |
Rep 1,687
steker155.00 |
05-08-2019, 09:28 AM | #77 |
Rep 1,687
Has anyone had any luck in getting your music to sound good? The sound quality is just absolutely terrible in my opinion. I've tried everything in the MMI box settings... Loudness, EQ, etc... and nothing matches the sound quality I used to have when playing my tunes through USB or Bluetooth directly to iDrive. Maybe that's the nature of AUX???
I always keep an old piece of crap iphone in my console which has my music on it, but if I switch iDrive to USB, I won't hear any sounds coming from carplay via AUX.
steker155.00 |
05-08-2019, 09:38 AM | #78 | ||
Rep 212
You can check this post for Bimmertech Carplay: Quote:
05-08-2019, 10:34 AM | #79 | |
Rep 155
- Set aux level to +8 - Set carplay EQ to Classic - Set idrive EQ to reduce lows and increase highs. Adjust these to the point you're liking it. Keep in mind that you won't get the same audi quality as bluetooth or usb audio. The best you can do is to try to get it closer to it. |
ooshnoo877.50 |
05-08-2019, 10:37 AM | #80 | ||
Rep 88
But... there is another problem! I have PDC and when I put my car in reverse the screen goes black, but the beeps are working. When I go into neutral it switches from black to the PDC screen, but obviously it's useless in neutral. It's really weird that in reverse it's not showing but in neutral it is. Anyone else have this problem? |
05-08-2019, 10:44 AM | #81 | |
Rep 88
I have Bluetooth connected for phone calls and Spotify to iDrive, in Media I also have iDrive set to Bluetooth and not AUX. This way I can still use CarPlay for phone calls and Spotify, but get the audio quality of iDrive. Only disadvantage is that Google Maps doesn't make a sound then, but I can live with that. And worse case is just switching to AUX in Media. |
05-08-2019, 10:47 AM | #82 | |||
Rep 155
05-08-2019, 11:09 AM | #83 | |
Rep 1,687
AlbertoSONIC97.50 |
05-08-2019, 11:32 AM | #84 | |||
Rep 88
So I don't have a camera, just PDC and the normal PDC screen. Are you saying that because of the CarPlay unit it expects a camera feed and, because I don't have a camera, it just shows a black screen? I turned the Rearview setting to Off, but it's still showing a black screen when I put the car in reverse. Noob question... what is the dip switch and where can I find it l |
AlbertoSONIC97.50 |
05-08-2019, 11:36 AM | #85 | ||||
Rep 155
The dip switches are 8 switch in the bottom side of the carplay unit (the opposite side of the one with the IDCORE logo), you'll need to tear down everything again to reach them, then use a small screewdriver or fingernails to move that tiny dip switch in the ON position. |
steker155.00 |
05-08-2019, 11:39 AM | #86 | |
Rep 1,687
steker155.00 |
05-08-2019, 11:56 AM | #87 | |||
Rep 88
Thanks again for the help guys, with this being such a new product there is obviously not much to be found on Google. |
AlbertoSONIC97.50 |
05-08-2019, 12:04 PM | #88 | |
Rep 1,687
