05-13-2019, 06:09 AM | #111 | ||
Rep 155
05-13-2019, 07:35 AM | #112 | |
Rep 9
1: ON (6.5" screen) 4: ON 8: OFF <- Although this doesn't seem to do anything for me. I want mine to function like yours, do you have a manual transmission or automatic? That's the question they asked me before suggesting the number 4 dipswitch change. |
05-13-2019, 07:40 AM | #113 | |
Rep 88
I can test the mic some more, because I'm still not a 100% sure which mic is being used in which ocassion. But I can tell you that I have Media sound set to BMW iDrive Bluetooth instead of AUX, my phone is only connected to BMW iDrive via Bluetooth and when I am in CarPlay and for instance open WhatsApp, I hear Siri reading my messages in Dutch over the speakers and I can reply to Siri in Dutch in CarPlay and all works fine. When I then make a phone call from CarPlay it also works over the iDrive Bluetooth connection. That's why I assume it's always using the OEM mic instead of the CarPlay mic in this setup. Also because Siri also works over the OEM mic when you don't have CarPlay. But I can simply make sure by calling my wife and talk very loudly in one of the mics But yeah, I haven't had any issues yet. What kind of problems did you encounter? |
05-13-2019, 07:54 AM | #114 | |
Rep 88
Is yours easily accessible? Did you install it under the iDrive unit or also in the empty space next to the glove box compartment? |
05-13-2019, 08:13 AM | #115 | |
Rep 9
05-13-2019, 08:32 AM | #116 |
Rep 212
05-13-2019, 09:59 AM | #117 | ||
Rep 88
05-13-2019, 10:10 AM | #118 | ||
Rep 155
ooshnoo877.50 |
05-13-2019, 10:43 AM | #119 | |
Rep 1,687
Drives: 2014 428i and 2018 X5
I hope some kind of update makes it a bit easier to use.
AlbertoSONIC97.50 |
05-13-2019, 11:07 AM | #120 | |
Rep 88
1. I'm in CarPlay 2. I get a call 3. I answer the call with the Phone button on my steering wheel 4. All works fine, sound over speakers, OEM mic, but still CarPlay call interface But... 1. I'm in CarPlay 2. I get a call 3. I answer the call with the iDrive controller by selecting the answer icon in CarPlay 4. No audio, but caller can hear me In that case the phone automatically changes from BMW Bluetooth to CarPlay Bluetooth and therefore using the CarPlay mic. But because the audio source in Media is BMW Bluetooth and not AUX, I don't hear the caller. So I either have to switch on the phone to BMW again or change the audio in iDrive Media to AUX. If only the sound was the same quality I would live completely in CarPlay. |
AlbertoSONIC97.50 |
05-14-2019, 02:43 AM | #121 | |
Rep 88
I also added my wife's phone to CarPlay wirelessly and it works. I did turn off Wifi and Bluetooth on my phone just so it wouldn't interfere in the pairing process. Another experiment will be to see what happens the next time I get in my car alone. And then the next step will be to see what happens when we both get in the car the same time. |
AlbertoSONIC97.50 theblues86.50 |
05-14-2019, 07:58 AM | #122 |
Rep 155
@steker
I've talked with Unique about your request of the option to disable steering wheel control. They told me that yes, it's a software option, not hardware, but it's deeply hardcoded in the software so it can't be enabled or disabled with a toggle in settings. So it's a no, too complex to enable or disable. They suggested to use apps to listen fm radio (streaming), that's what I do and works fine. There are apps on the appstore that offer carplay functionality, you can scroll fm radio stations in carplay and listen them. Obviously it uses internet data to listen, it's not real fm. |
ooshnoo877.50 |
05-14-2019, 09:14 AM | #123 | |
Rep 1,687
05-14-2019, 09:43 AM | #124 | ||
Rep 155
Some time ago I requested a feature, which I don't remember right now, but they told me they were busy working on new updates. Didn't tell me anything about them, though |
05-14-2019, 09:50 AM | #125 |
Rep 5
Hi all, I am totally new in this forum and also want to retrofit my car with carplay. When doing research I found this: https://www.aliexpress.com/item/Afte...9a2b3c00koPldv it seems pretty new, so I wanted to ask if anyone knows which manufacturer is producing it and if someone has any experience. On the box it says "Limcet Box" but I couldn't find anything.
I am also thinking whats the better option: Retrofit to BMW NBT Evo ID 5 / 6 with atm or just build in one of this boxes. Would be great if you could provide some feedback. |
05-14-2019, 09:56 AM | #126 | |
Rep 88
I will try to go all-in on CarPlay mode. I've unpaired my phone with BMW iDrive and am now fully connected with the CarPlay unit. Sound is decent now after the EQ tweaks and no confusing situations when answering phone calls with the wrong button. I use Tunein Radio so I can listen to all my local stations through their app. Let's see how this all goes. My wife actually is also in full CarPlay mode, but when I called her there was a significant delay. Maybe that was a one time thing, I will test some more. Do you know if Unique is also working on updating the firmware? Sometimes when you start your car it can't find CarPlay at all (no Wifi or Bluetooth) and sometimes it can find it but just doesn't connect. It has only happened 2 times to me and 1 time for my wife, but still annoying obviously. Do you know how they would distribute an update? Would they let us know there is an update or will they only send it when you request it? |
05-14-2019, 09:58 AM | #127 | |
Rep 1,687
05-14-2019, 10:00 AM | #128 | |
Rep 1,687
https://f30.bimmerpost.com/forums/sh....php?t=1594062
05-14-2019, 12:32 PM | #129 | |
Rep 170
Drives: iX3 M Sport
In the same period I have only had the one No Signal issue whereas before it was nearly everyone I got in the car and getting no joy using the reset button. Looks like the new loom has improved this issue and solved the audio problems.
Current Car: iX3 MSport Sophisto Grey
Previous Car: F31 320d ED |
05-14-2019, 02:25 PM | #130 | |
Rep 88
05-14-2019, 05:45 PM | #131 | ||
Rep 155
About the software update, you need to ask them to send it to you, they send you a small file that needs to be copied in a usb key (formatted in fat32) and plugged in the microusb (with an otg adapter) in the "update" port of the carplay unit. Then you click the reset button, wait the led to flash quickly and then when it stays still, you just unplug the usb key and the unit reboots with the new software. Btw since I'm interested in software updates too (as I requested some fixes), I can tell you when it's ready so you don't need to ask them every day if it has been released (like I do xD) |
05-14-2019, 05:56 PM | #132 | ||
Rep 155
