BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Video- New BimmerTech SmartView!
Studio RSR
      06-30-2016, 08:30 AM   #23
jacob_dk
Denmark
Drives: 2012 X3 F25 20xi
With summer holidays coming up I finally placed an order today along with rearview cam and combox retrofit.
Looking forward to spend time on this project.
I'll submit an installation and review post when done.
Review here:
http://x3.xbimmers.com/forums/showthread.php?t=1288054
In short:
Smartview works beautifully and the delay from phone to screen is a few milliseconds at the most.
It's exactely what I hoped for.
      12-17-2016, 09:58 AM   #24
Bryan_KiesMotorsports
391
Drives: 2013 BMW 335i xdrive
Review here:
In short:
Great to hear!
      02-15-2017, 10:05 AM   #25
GTAF10
Drives: F10 M5
Originally Posted by bkkeys View Post
Hey Everyone,
We have exciting news.. the new BimmerTech SmartView is here!
Check out our short video to learn more and see a live demo!
Thanks,
Bryan
Does that mean we won't be able to listen to radio/music in the background while the screen is in mirroring ?
      02-15-2017, 05:20 PM   #26
MarkoSK
Drives: BMW G20 330eX
You can either listen to the mirrored audio (if you connect it to your AUX port) or the radio/music/any other input.
      02-15-2017, 08:05 PM   #27
Hyperlink
Drives: 2013 328i xDrive Sport Line
You can, but you'll need to change the audio source via iDrive to radio or Bluetooth. If you want to hear audio from the BimmerTech unit you need to run an rca/aux cable from the BimmerTech hardware to the aux port inside of the middle arm rest thing. If you want audio from the mirrored screen all the time just leave your audio input in iDrive as aux. I would contact their support for instructions on where to drill the hole or how to run the rca/aux cable. Kinda of a pain in the butt, but BimmerTech says there isn't really a better way to do the audio thing. It was probably expensive/difficult for them to override the aux input going into the HU.
Location of the aux port:
http://f30.bimmerpost.com/forums/sho...t=phone+cradle
      02-16-2017, 09:18 AM   #28
MarkoSK
There is an easier way to listen to the mirrored audio. You can try to connect your phone to the AUX port via the 3.5mm jack while mirroring.
Some phones, however, disable the jack when mirroring, so it won't work. There is a workaround to force your phone to send all audio as a Bluetooth phone call. Some navigation apps (i.e. Sygic) have this out-of-the-box, so it works flawlessly.
      12-28-2017, 10:40 AM   #29
starbai
PPRSWCE
starbai's Avatar
Guyana
654
Drives: 18 Tanzanite Blue F80 ZCP
Has anyone attempted to stream a netflix movie on their phone and 'cast that ' to the smart view? and it work?
I ask beacuse I'm still not clear, if youre phone is connected to the smartview wifi, doesn't the phone look to the smartview for internet connection? Which of course isn't there... so wouldn't it basically time out any streaming you want to do from things like Netflix, Pandora, etc etc?
In other words, 'cast' the video via wifi to the smartview. But still keep 3G running on the phone to stream video/data/internet connection...
Does this make sense?
      12-28-2017, 01:15 PM   #30
Maciej@BimmerTech
Drives: Subaru
It depends on what you mean by SmartView as we have two kinds of those:
SV HD which is based on the Apple TV3
SV HD FLEX which has two flip out antennas
I'm guessing you're referring to the Flex unit based on the fact that it broadcasts a wifi network to which you connect the phone.
The basic answer is that streaming video apps generally is possible from compatible miracast android phones to the SmartView HD Flex perfectly fine. However after the iOS 11 update iPhones no longer want to stream video apps to the SV HD FLEX. Other apps do work just as they did - e.g. navigation apps.
iPhones work great with our Apple TV3 based SV HD and video apps stream perfectly fine to it from iPhones too. And it's not likely to change in the future either.
You will need mobile internet in your phone for either of these SV streaming setups. When streaming from an iPhone to the SV HD you will also need to broadcast a wireless hotspot from the iPhone which the apple TV will connect to for internet to stream the videos.
I hope that helps.
      12-28-2017, 01:41 PM   #31
starbai
PPRSWCE
starbai's Avatar
Guyana
654
I hope that helps.
Maciej@BimmerTech
Thank you for replying to me. So if I didn't need to or have any interest in doing this wirelessly, My Samsung Galaxy S8 Plus is capable of sending anything on its screen out of its USB-C port. WIRED to an HDMI.
So my question is, could I in theory just get your MMI, (no SV HD or SV HD Flex) and just plug my phone into the HDMI port?
Why wouldn't that work?
Or even for my wife's iphone, today, we use this adapter connected to an HDMI cable and it shoots anything on the screen through the HDMI port.
      12-28-2017, 07:40 PM   #32
MarkoSK
The adapter should work, but you'll have to run cables from the MMI unit (which you'll probably hide under the head unit) to the outside. And don't forget the fact that you'll have to change the adapter (and thus take apart the head unit again) when you'll get a newer phone or a phone from a different brand.
      12-29-2017, 07:00 AM   #33
Maciej@BimmerTech
Drives: Subaru
In theory that should work when connecting the phone to the MMI HDMI input. We have never tested these adaptors ourselves though so I can't confirm it. I dimly recall one customer trying to mirror through the apple lightning to HDMI adaptor that you placed in your post - and it didn't work well or at all (I don't recall exactly) but the reason why was not determined. Maybe there was a bad connection somewhere (HDMI doesn't like to have multiple connections and cables between devices as signal is lost) or the adaptor could have been bad.
But - it should work as HDMI is HDMI. We've had customers connect various HDMI devices to the HDMI ports on our MMI's. E.g. you can check out this blog post where a customer described his battle with installing a DVD player in the back of the car:
https://www.bimmer-tech.net/blog/ite...blu-ray-player
      01-15-2018, 02:51 PM   #34
Maciej@BimmerTech
Drives: Subaru
Good news for SmartView HD Flex users!
Our team managed to make the video streaming apps work again with iOS 11.2 and 11.2.2 iPhones! It is however expected that it won't work with iOS 11.3 though so if you want to continue using apps like youtube with the HD Flex - better stay on 11.2 after the firmware update.
We have updated the download link in the youtube tutorial video with the latest firmware:
      01-15-2018, 03:34 PM   #35
tpliquid
Drives: f31 330i wagon
Would one be able to cast navigation to the screen and then use the phones speaker to output the sound directions?
      01-15-2018, 08:25 PM   #36
MarkoSK
Maciej@BimmerTech Will the FW work if I have the same unit as HD Flex, just bought it on eBay and not BimmerTech?
      01-16-2018, 03:25 AM   #37
Maciej@BimmerTech
Drives: Subaru
I'm afraid that is not possible. Audio and video are not separable in airplay. Maybe it would work if you plugged in an audio jack into the phone but I bet that's not what you're looking for.
I only know how our modules behave, can't comment about ebay modules.
      01-16-2018, 12:05 PM   #38
MarkoSK
It depends on your phone - iPhone streams both video + all audio via mirroring, the majority of Android phones too. However, there's an app for Android that can force it to play audio through speaker even during mirroring. Haven't tried it though.
      01-17-2018, 04:51 AM   #39
Maciej@BimmerTech
Drives: Subaru
Valid point. I've hear that there are even builds of Android that support the separation of audio natively - so it might be possible to do that without any additional apps for some Android users.
      01-17-2018, 11:05 AM   #40
zonbin
Drives: car innova
Thanks
