05-10-2021, 12:55 AM | #1 |
Rep 326
What happens if air intake is damaged?
Just curious, what happens if there is a damaged area in the air intake system. This could be a crack or an intake duct incorrectly installed. In this situation, the turbo and engine would be sucking in unfiltered air.
Would the unfiltered air damage the turbo and engine? Would an error code of some sort be thrown in any kind of similar situation?
If you can imagine it, you can achieve it.
If you can dream it, you can become it. |
05-10-2021, 07:35 AM | #2 |
Rep 16,079
It depends where the damage is. If it allows unfiltered air to reach the engine it would have to be fixed or replaced. If unfiltered air was OK there would be no filter.
Slick_FThirty125.00 |
05-10-2021, 08:55 AM | #3 |
Rep 190,750
+1
05-10-2021, 12:32 PM | #4 | |
Rep 326
Would be reassuring to know that I would be notified the moment a problem happens.
05-10-2021, 01:21 PM | #5 | |
Rep 78
Drives: BMW 320i xDrive
You are correct that these pipes are flimsy and can crack. Luckily, there are plenty of aftermarket options to remedy this. The turbo inlet pipe itself is also made of plastic and is highly reccomended to get replaced. If that cracks, the last thing you want are chunks of plastic entering the turbo. However, this is only an issue on older cars where the pipes are brittle. Hope this helps! |
