05-05-2021, 02:48 PM | #1 |
Rep 14
Tire wear track
Hi guys,
30min stint on track ended on front tires like this....is it overinflated? Let me know your thoughts, thx. pressure 38F 42R, M adaptive suspension, RWD Last edited by GreepM; 05-05-2021 at 03:27 PM.. |
05-05-2021, 04:58 PM | #3 |
Rep 14,107
Drives: G82 M4C X-Drive
38 is borderline high, but that depends on your tires. I try and keep my tires below 38 on the track. The wear looks about right if you are on factory setup, there is some corner wear. Most cars require camber to keep wear even on the track, about -2.7 to -3.0. So yes, that's "normal" but it isn't ideal, but it isn't nearly as bad as I've seen before.
Your rear pressure is too high.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
05-06-2021, 07:29 AM | #4 |
Rep 71
Drives: 2016 435i xDrive Gran Coupe
Tyre pressures too high. Some tracks are more abrasive than others, and the tyre compound is a huge factor, which Goodyears are they?
05-06-2021, 07:57 AM | #5 |
Rep 849
Drives: BMW 435i
While the pressure might be a little high, I don't know if lowering it much would help.
The first picture makes it look like there is wear on the side of the tread block all the way down to almost the sidewall. At the very bottom of that picture you can faintly make out the inverted "V" symbol marking the edge of the tread and the start of the sidewall.
05-06-2021, 02:42 PM | #6 | |
Rep 7,591
I would run 32/35 F/R and check it after each session because it has probably went up. To me the wear looks normal, about the same as my brand new tires did after 13 autocross laps. Plowing through corners with understeer will make things worse so make sure you arent going in too hot. |
Desertnate390.50 |
05-06-2021, 03:42 PM | #7 | |
Rep 15,858
Desertnate390.50 |
05-10-2021, 11:12 AM | #8 | |
Rep 14
(..it's also my daily, so bigger sidewalls...and 255 on the rear makes the car quite understeer so... maybe next time I'd go 235/40F and 245/40R) maybe because of the bigger sidewalls the pressure went to 38s idk...I'm not scientist Still asking myself, when the car is 50:50 weight ratio, why the rears should have more pressure? Next time I'll try 32F square or 30/32 F/R hot |
05-10-2021, 11:20 AM | #9 | |
Rep 14
05-10-2021, 03:50 PM | #11 |
Rep 849
Drives: BMW 435i
You can slightly change the car's understeer/oversteer behavior depending on pressures. It's really the autocrosser's only weapon in a stock class and I'm sure BMW did the same thing as they dialed in the handling for the car.
05-21-2021, 05:06 AM | #12 |
Rep 14
update:
yesterday 32/34 hot (started with 26/28 btw) DSC OFF !!! I'd say, when you have it ON the car is quite a lot understeer. I was fighting only with oversteer, which was super fun, only once went wide in to the gravel I don't know if it's mainly because of the pressures or DSC off, but I enjoyed the whole session. |
