05-18-2017, 08:37 AM | #23 |
Rep 1,980
Drives: 2020 G20 320i M Sport
No worries, just let me know. It will take a week to source and prep one for you
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
06-12-2017, 07:45 AM | #24 |
Rep 56
06-12-2017, 08:28 AM | #25 |
Rep 755
I have a CIC system and I am happy with it. The NBT while better, is not a lot better to go through the hassle. If I wanted to retrofit the latest, what would I need. Is it even possible?
03-25-2018, 11:32 AM | #27 | |
Two turbos are better than one!
119
Rep 404
I am in the same boat as Tim, except I have the HK sound system - 2013 335 M-Sport with CIC.
What reasonable options are there for people such as us in terms of upgrading the CIC? It seems like: 1) NBT upgrade is harder and more expensive (Stve can you comment on just how mch?) 2) Android 10.25" units are buggy and support is spotty 3) Apple carplay is useless for people like me with an Android phone Thanks Quote:
Sapphire Black M4 Competition |
03-29-2018, 08:51 AM | #28 |
Rep 660
I am in a similar boat, same year car with the older iDrive system. I have the older NAV system and iDRive system and I wanted to see what I would have to do to upgrade my unit to one of the newer iDrive systems. It just sucks that I should have wait a few more months for the 2014's to drop but got a killer deal on my car in 2016.
04-23-2018, 02:58 AM | #29 |
Rep 11
I have retrofit my BMW F20 2013 car came with standard HU , I retrofit with NBT EVO 2 ID6 aftermarket ATM witch activate SatNav and slot for GPS
09-11-2018, 10:06 AM | #30 | |
Rep 59
Hi, i have recently installed a NBT HU in my Pre Lci F11, i used the Pre Lci retrofit kit from bimmerretrofit but i got no sound in my system, i know this is a 5 series car, but do you think it will be the same? have you done a installation in a 5 series car? |
09-11-2018, 10:10 AM | #31 |
Rep 1,980
Do you have Hi-Fi or Harman Kardon?
09-11-2018, 10:35 AM | #32 |
Rep 59
Oh i forgot to mention, i have Hifi 676 which is FA coded to the NBT_HU
It doesn't matter if i disconnect everything from the Combox or not, still no sound. My thought is that i also need Most Loop on the Fibre optic comming from the Combox, what do you think? |
09-11-2018, 11:34 AM | #33 |
Rep 1,980
hmmm, Hifi is via most on the F10 if I'm not mistaken. Did you move the black and green optical cable from quad lock over to the Bimmerretrofit harness?
09-11-2018, 12:37 PM | #34 |
Rep 59
Yes i did, i also put a most loop connector to the lines which were previously connected to the Zgw.
09-11-2018, 02:21 PM | #35 |
Rep 1,980
I would say at this point that the head unit is not coded to the proper amp. Did you VO code the NBT?
09-11-2018, 05:02 PM | #36 |
Rep 59
09-11-2018, 06:49 PM | #37 |
Rep 1,980
Only thing I can suggest is to bridge pins 13 and 15 on the quad lock together and that should power on your diversity antenna and presumably the external amp.
09-12-2018, 01:48 AM | #38 | |
Rep 59
https://f30.bimmerpost.com/forums/sh...5#post23711925 Yes this must be the reason i guess, just find it strange that Bimmerretrofit didn't know about this |
09-12-2018, 06:02 PM | #39 |
Rep 59
Yep, connected a wire from Pin 13 to Pin 15 at the Bimmerretrofit ENbt adapter's Quadlock and voila, i got sound from the system again
But i got a coupple of other problems, anyone know what to do? I have coded the Oelstand in Fdl, but the meter is grey and is showing only a few percent at the bottom. The other problem is that then i try to set the setting of the tailgate in the idrive, the setting goes down again, kinda like those 80's Equalizer meter's, is there something i have forgotten to Fdl code here? |
11-10-2018, 09:16 AM | #40 |
Rep 8
Per my know USB and BT are connected to Combox, what did you do to make them work in NBT? what would happen once combox is disconnected?
11-10-2018, 10:52 AM | #41 | |
Rep 7
cheers, Jason |
01-16-2019, 12:39 PM | #42 | |
Rep 171
Drives: X3 M Comp
-NVE |
MatthewLC23.00 |
01-16-2019, 07:01 PM | #43 | |
Rep 2
I am doing the retrofit Steve was talking about. I got an NBt unit that did not have XM. That was important to me so I am getting rid of my NBT for one that has XM. If you are looking for a nav unit, this one is great. In good shape. From 2016 x5. Can easily be coded to your vehicle. |
steve@codemybimmer664.50 |
05-29-2023, 12:40 PM | #44 |
Rep 38
Drives: F30 328i and e92 330d
Hello, can any one can help me how to make my rear view camera work on nbt evo? I had CIC
