BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Flash DME to ECE / Increased top speed limiter
      02-18-2024, 04:01 AM   #1
whereisguru
Drives: F33, 435i xDrive
Hi,
I recently attempted to lift the speed restriction on my vehicle in order to bypass the speed limitation. Initially, i changed the type code of my vehicle using E-Sys: 3T33 => 3T31. Subsequently, I flashed the DME and EGS with the ECE data. Additionally, I added the SALAPA Element S840A to ensure that the vehicle supports the necessary functions.
Despite these modifications, however, the vehicle continues to be limited to 130 miles per hour (MPH). It seems that the modifications did not achieve the desired results.
* UPDATE *
Since the engine control unit (DME) locks after 10 operating hours, the flash couldn't remove the speed limiter. I was able to solve the problem through tuning.
Thanks.
dme, flash, speed limit
