09-17-2019, 02:16 PM | #1079 |
Rep 234
09-17-2019, 03:08 PM | #1080 |
Rep 410
09-17-2019, 06:52 PM | #1081 | |
Rep 1,454
Why 4.74? Our tank is 15.8 gallons, so 10% is 1.58 * 3 = 4.74, which is 30% of your tank capacity. |
09-17-2019, 10:18 PM | #1082 | |
Cheapskate
4448
Rep 4,993
G.Newt810.00 |
09-17-2019, 10:46 PM | #1083 | |
Rep 1,454
x = E10 pump gas y = "E85" gas %E = measured E content at the pump x + y = 15.8 (tank capacity) 0.1x + %Ey = 4.74 (30% volume) As an example, assuming your %E is actually E70, the matrix says 10.53 gallons of E10 pump + 5.26 gallons of E70. The main lesson learned here, is that my TI-84 is not useless after college like I thought it'd be. Guess I gotta bring this to the pump haha. Last edited by G.Newt; 09-18-2019 at 08:19 PM.. |
kern4174447.50 |
09-18-2019, 09:48 AM | #1084 | |
Cheapskate
4448
Rep 4,993
09-18-2019, 12:11 PM | #1085 |
Rep 1,369
I just use this and assume that most pump E85 is probably closer to E70.
http://www.georgebelton.com/E85Calculator.php
09-18-2019, 12:33 PM | #1086 | |
Rep 458
2019 M240i M Performance Edition / xDrive / ZF8 / BM3 Stg 2+ E30 / xHP Stg 3 / Dorch Stg 2 HPFP / Evolution Racewerks Catless Downpipe / MPPSK Exhaust / FTP Drop in Filter / FTP Intake Pipe / FTP Chargepipe / NGK 94201 Spark Plugs .022 / Michelin PS4S - 225/35/19 + 245/30/19
B58togo808.50 |
09-18-2019, 01:08 PM | #1087 | ||
Rep 198
09-18-2019, 02:48 PM | #1088 | ||
Rep 964
InstigatorX58.00 kern4174447.50 |
09-18-2019, 07:29 PM | #1089 |
Cheapskate
4448
Rep 4,993
I'm on android and mine is called "E85 Blend"
09-19-2019, 09:01 PM | #1090 |
Rep 797
Been driving around for a few days now with the burble off, I don't miss it.
But .. the rev hang and the complete bog on certain normal 2>3 shifts remains. Every once in a while I'll drop into 3rd at slight throttle and lower rpm ~2k and there's nothing there. Just normal driving around town. I have to clutch in and blip to get any power back it's like the injectors are off or the plate is stuck fully closed. |
09-20-2019, 11:56 AM | #1091 | |
Cheapskate
4448
Rep 4,993
09-20-2019, 03:54 PM | #1092 |
Rep 7
With BM3 is it possible to adjust settings/maps "on the fly?" Or does each change require a reflash? Let's say I want to be able to quickly switch to a valet mode.
09-20-2019, 06:52 PM | #1094 |
Rep 931
09-21-2019, 10:57 AM | #1095 |
Rep 7
So just keep the cable in the car and make sure my phone has a good signal theN?
dstanding
09-23-2019, 10:21 AM | #1096 | |
Rep 234
I would recommend downloading the maps for offline flashing so you don't have to worry about good signal. |
kern4174447.50 |
09-23-2019, 11:18 AM | #1097 | |
Cheapskate
4448
Rep 4,993
I've noticed MHD relies heavily on integration with other aftermarket vendors like JB4 and PureTurbos to sell their products. I think it's mostly a marketing thing unless the pump is getting released this week or something, which would surprise me since it hasn't even been hinted at during development. |
09-24-2019, 01:13 PM | #1098 |
Rep 1,454
Installed NGK 94201 plugs at 0.022" gap today. Very smooth power delivery. No more bogging on occasion at WOT. Idle seems about the same, but time will tell if the once in awhile rough idle for a second goes way.
But immediately I noticed how smooth it runs now, not that it was bad before. I'm at altitude (5,000 ft), so YMMV. But these seems like a winner. EDIT: Forgot to mention I'm running Stage 2 91. I'll be going to Stage 2 E30 soon and can update. |
kern4174447.50 |
09-25-2019, 11:45 AM | #1099 | |
Cheapskate
4448
Rep 4,993
09-25-2019, 04:57 PM | #1100 | ||
Rep 1,454
Idle seems fine, just normal fluctuations. But the power delivery is smoother. Also, I only have a year of warranty left and am only at 30k miles. I doubt they replace them for free.
2022 CT4-V Blackwing 6-speed
kern4174447.50 |
Tags |
bm3, bootmod3 |
