01-23-2019, 10:52 AM | #45 |
Masterchief
354
Rep 1,003
ive only had them on for a 100 miles so hopefully the sound does reduce, cause its a definitly noticeable when you are driving with the windows down. i sorta wish i knew about this noise before pulling the trigger cause i would have just went with blanks instead
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
01-23-2019, 11:07 PM | #46 | |
Masterchief
354
Rep 1,003
Have you guys had reports of noisy rotors?
AWE Non-Res Touring | TE37 SL PW | Ohlins RT Last edited by yoon_209; 01-24-2019 at 10:44 AM.. |
01-24-2019, 10:58 AM | #47 |
Not stock
472
Rep 617
Don't want to beat a dead horse here, but if you have never driven a car with drilled/slotted rotors the noise is, unfortunately, completely normal and expected. It's annoying when driving next to medians on highways especially in an otherwise quiet car.
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
01-24-2019, 01:43 PM | #48 | |
Masterchief
354
Rep 1,003
it is quite unfortunate the they make so much noise. i just never expected the it be an issue, i dont even wanna drive with my windows down cause it bothers me. i may go back to blanks
01-25-2019, 02:23 PM | #49 |
Big Turbo Boys N Girls
327
Rep 579
hmm, wonder if the rotors or pads are defective. I have slotted rotors and my friend has slotted and dimpled. No noises. Also the M Performance brakes are also slotted and dimpled and make no weird noises...
Might want to try a different pad or rotors.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
01-25-2019, 04:24 PM | #50 |
Rep 417
Just wanted to share my experience with R1 concept as well.
TLDR: I had great experience with their products and service which I will get them for my cars when brakes are due. I have been using their eline since 2011, started with a 240sx, GS400, and recently the Q50. They all fit great and do the job. 240sx ones were slotted with zinc coating, had them for a year before I sold the car and did not experience any problem. They pair up with the Hawk performance ceramic pads pretty well. GS400 ones were blanks without any coating. They replaced my 1 year old wrapped Brembo blanks and they are still able to stop the heavy car after 4 years. (I only put 10k miles on the car since the replacement). It came with defects and R1 concept was able to expedite my replacement after I sent them the picture. Rust is not a huge issue on this pair. Pair with akebono ceramic pads with no problem. Q50 ones are blanks without coating as well. Had them for 6 months, excessive rust due to the humid nature of Bay Area. I brushed them out and sprayed them with caliper paint 2 months ago. No sign of wrapping or decrease in performance so far. Also pairs with akebono ceramic pads with no problems *I am not affiliated with any of these mentioned brands and I always paid for the parts without any special discounts (except the regular 10-15% usual promotions)* |
01-30-2019, 10:50 AM | #51 | |
Masterchief
354
Rep 1,003
I have noticed that the pad wear on the rear rotors are even however on the fronts I did see that the geomet coating towards the center of the rotor hasn't worn off yet and another line of coating towards the outside of the rotor has not worn down yet. Could this be a cause of the noise? Possible improper install of the pads? its been about 300 miles on the pads and rotors.
AWE Non-Res Touring | TE37 SL PW | Ohlins RT Last edited by yoon_209; 01-30-2019 at 04:32 PM.. |
02-01-2019, 12:21 PM | #52 |
Rep 55
I have m perfs slotted and drilled and they make no weird noises. Also friend has slotted drilled stop techs and they also do not make a weird noise. Im not buying the slotted and drilled rotors make noise bit.
02-04-2019, 05:24 PM | #53 |
Masterchief
354
Rep 1,003
im definitely thinking its an improper pad install. something is forsure rubbing which is causing that sound. especially since my rears dont make any noise at all.
02-05-2019, 01:31 PM | #54 | |
Rep 2,653
yoon_209353.50 |
02-05-2019, 06:58 PM | #55 | |
Masterchief
354
Rep 1,003
im definitely, going to take it to another shop and see what they say
02-10-2019, 02:40 PM | #56 | ||
Masterchief
354
Rep 1,003
I have noticed my front rotors are dimpled and not drilled but my rears are drilled. is that normal?
AWE Non-Res Touring | TE37 SL PW | Ohlins RT Last edited by yoon_209; 02-11-2019 at 01:55 PM.. |
09-07-2019, 12:50 PM | #57 |
Rep 5
After reading this thread, I believe i'm having the same issue. It's literally only coming from the front. Bugs the crap out of me, can't quite figure it out yet. I put the car up in the air and proceeded to spin the wheel to see if i could perhaps pin point where the noise was coming from. it honestly sounded like it was coming from the caliper. Did you ever figure out where the sound was coming from and did you find a solution for it? I recorded the sound, i would be super curious if it was the same noise you were getting.
09-07-2019, 08:00 PM | #58 | |
Masterchief
354
Rep 1,003
09-08-2019, 10:15 PM | #59 |
Rep 5
So I actually got in contact with R1 Conepts and they're sending me new brake pads and hardware kit for the front. (keep in mind I just purchased the geomet rotors drilled and slotted about a week ago) They were pretty helpful and cool about the whole situation. But I also went ahead and ordered some generic blank disc rotors from oriely's just so that I can eliminate my doubt to see if its coming from the new dimpled and slotted rotors that i got from R1. Again this noise is only coming from the front, the rears are just fine. Even when I put the car up in the air, I don't get that weird sound when I spin the wheel. I'll keep you updated, out of curiosity ... can we send audio files through the forum ... i want to see if its the same noise you're getting.
09-08-2019, 10:21 PM | #60 | |
Masterchief
354
Rep 1,003
i dont have clips right now, but its a high speed clicking/buzzing noise, almost like when you put a can on the bike tire it makes that noise. the weirdst part is that the noise goes away when i actually brake, mine might be the pads tho since i put ceramics.
09-16-2019, 09:26 PM | #61 | |
Rep 513
Drives: 2008 335i
02-24-2022, 11:33 PM | #62 |
Rep 3,752
Bringing this thread back alive.
I am currently looking to replace my brakes. Came across a brake rotors called Dynamic Friction on Rockauto website and found out that Dynamic Friction Company uses the same address as R1 Concept, so concluded that they are the same company. Anyway... Can we have 3 year update on how they holding up. Thanks in advance |
03-10-2022, 06:17 AM | #63 | |
Rep 95
I'll likely go elsewhere. |
03-10-2022, 02:56 PM | #64 |
Rep 7,591
I've ran through 2 sets (F+R twice) of R1 concepts rotors and 4 sets of (various brand) pads on my 3000gt over the last 10 years or so. I had the rotors turned between each set of pads. The e-line would not hold up to aggressive braking on a 4000lb car making well over stock power. When i switched to their "premium" rotors (step above e-line) on my 2nd set and went to EBC yellow pads i didnt have any more issues.
I probably wouldn't buy them on my 335 though, the prices look crazy based on my quick search. |
03-10-2022, 04:16 PM | #65 | |
Rep 95
12-07-2022, 10:10 PM | #66 |
Rep 207
Drives: bmw 428xi
Any feedback on these rotors?
