BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > ESYS Install Help
      08-17-2019, 03:21 PM   #1
SirFisher
SirFisher's Avatar
Drives: 2016 BMW 340i xDrive 6MT
ESYS Install Help
Hello, I have been searching around forums for the past few hours and have not found a solution to my problem so I figured I would post this here. I recently purchased a new laptop and after freshly installing Esys v 3.27.1 with the free token master v 2.82.162 free installer, when launching I am met with the error; "Loading: E-Sys Launcher PSdZ API Module Failed! Error C:\ProgramData\TokenMaster\E-Sys Launcher Pro\bin\PSdzAPI.dll: Can't find dependent libraries."
Is there a newer way to provide the est token to E-sys, I have this exact software setup on a different laptop where it runs without this error. I have checked through my entire c: drive and have now found the PSdzAPI.dll file anywhere. Is this something I need to download from somewhere or have I set my E-sys up incorrectly...
Older posts say to upgrade the pro launcher version, but as far as I know this is the newest reliable method. I looked into purchasing the premium as donation ware but I do not know when I would receive this product.
I followed the E-sys installation instructions provided by shawnsheridan to the best of my ability and have done a clean install of windows on my laptop as well as copied all of the files I used to install from my other laptop and that has not helped.
Any and all input is greatly appreciated, I just retrofitted NBT EVO id6, the 6wb cluster and rear parking sensors to my vehicle and I am in desperate need of coding it.
Thank you so much
      08-23-2019, 08:41 AM   #2
torobravo33
Drives: BMW 340ix
Sounds like you need to download the PSdZ data and add it to C:/data/PSdZdata.
      08-23-2019, 11:19 AM   #3
SirFisher
SirFisher's Avatar
I will double check that I installed the PSdZdata in the correct location. I downloaded the latest Lite folder and installed it per the ESYS install instructions under C:/data/PSdZdata.
I tried redownloading the data but I got the same weird error saying its missing a file in the ProgramData folder, which is odd because the Pro Launcher is 32bit meaning that the tokenmaster folder is in ProgramData(x86)
      08-23-2019, 11:22 AM   #4
SirFisher
SirFisher's Avatar
I wanted to mention as well that I installed Esys on a separate windows surface in the exact method I did for the other laptop which has the response listed above. Interestingly the surface so far has not had any issues nor does it run into this error. I just would like to try and figure out what I did wrong on my own laptop because I am unable to borrow the other surface laptop that often.
      09-20-2019, 07:17 AM   #5
Fettler
Drives: BMW 520d 2016
Hi, I have the same problem as SiriFisher above:
New install of E-Sys v3.27.1 build 44813 with TokenMaster's free E-Sys Launcher Pro v2.82.162. When I run the launcher I get error message: "Loading: E-Sys Launcher PSdZ API Module Failed! Error C:\ProgramData\TokenMaster\E-Sys Launcher Pro\bin\PSdzAPI.dll: Can't find dependent libraries." I'm using Windows10 Home laptop.
When I start E-Sys without using the launcher, it runs and connects to my vehicle. I have downloaded PSdZ data and put it in C:/data/PSdZdata
Did you solve this problem? Any help would be much appreciated, thanks
      09-21-2019, 02:23 PM   #6
joshaguirre
joshaguirre's Avatar
Drives: 2016 X3 xDrive28i F25
Same issue here...
      09-23-2019, 11:33 AM   #7
RuleNormaliai
RuleNormaliai's Avatar
24
Drives: F31 320d EfficientDynamics
The best working settings for me are:
Download E-Sys 3.27.1
Download ESysLauncherPROSetup_2.8.1_Build_155
Download TokenBuster_1.0
Install Esys
Install Launcher
Run TokenBuster
Follow the instructions and you're done!
Enjoy your fully working E-Sys (offcourse you will need PSdZData of version that you want)
If you want more info you can PM me i will be glad to help you out.
      09-30-2019, 08:08 AM   #8
pete in fate
Drives: 2016 320i
v3.33.0
Install Esys
Install Launcher
Run TokenBuster
Having issue with v3.33.0 Do you have links to the downloads that I need? You are very helpful, really appreciate it! Thanks!!
      10-01-2019, 06:10 PM   #9
FIREXTREMESLAYER
FIREXTREMESLAYER's Avatar
Drives: 15 BMW 328i
has this issue been resolved? i'm still being affected by it...
      10-05-2019, 11:09 PM   #10
SirFisher
SirFisher's Avatar
I'll be totally honest, I do not know why the issue was resolved. I took a break for two weeks and it was working by the end of it. Now I am having issues with ISTA+, so I do not know if the problems are related...
e-sys, installation
