BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Differential ratios?
      09-13-2019, 08:53 PM   #1
Tantibus
Australia
Drives: 2015 420i
Hi guys!
I have a question in relation to the differential ratios on the f32 models.
Iíve blown my rear differential and was wanting to source another one, but the ratios are different.
Thereís a 3.15 and a 2.81 ratio. I was wondering if thereís a way to find which one can be used without looking at the diff under the car and what each of them are for?
Itís a 2015 420i, auto gearbox and n20 engine.
If someone can help, it would be a huge help!
      09-14-2019, 12:21 PM   #2
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
How did you blow your differential?
I would go to realoem.com and look up the part number for your differential and then go from there.
Instagram: rjd_f30 | Current: 2013 335i 6MT RWD | Past: FBO 2013 328i xDrive 8AT |
johnung1637.00
      09-15-2019, 05:24 PM   #3
Tantibus
Australia
Drives: 2015 420i
Thanks for the reply!
Iím honestly not too sure, itís likely because Iím putting down too much power, but I was sure that the bottom end would be able to handle the power gains.
I did check out realoem.com, wasnít lucky enough to find the part I needed.
Thanks so much for your help though!
      09-15-2019, 08:48 PM   #4
Okhan19
Jamaica
19
Drives: 328I 2015 ATM rktune downpipe
Hi that model came with a 3.15 differential if it is an automatic you can check. https://www.automobile-catalog.com/auta_details1.php
      09-15-2019, 09:01 PM   #5
rjd_F30
rjd_F30's Avatar
Hmmm, I think this should be the page for your car. https://www.realoem.com/bmw/enUS/sho...diagId=33_2122
This is the differential for an October 2014 build, right hand drive, rear wheel drive 420i with an automatic transmission. If that info is correct (less the build date, I just guessed yours) then it looks like you should have a 3.15 final drive ratio. Hope that helps! If any of that info is wrong, post the exact details of your car and I can take another look.
      09-15-2019, 10:12 PM   #6
johnung
Hi guys!
I’ve blown my rear differential and was wanting to source another one, but the ratios are different.
There’s a 3.15 and a 2.81 ratio. I was wondering if there’s a way to find which one can be used without looking at the diff under the car and what each of them are for?
It’s a 2015 420i, auto gearbox and n20 engine.
Getbmwparts is a good source for correct part numbers too
differential, drivetrain, f30, f32
