BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Error when trying to code KOMBI
      08-24-2018, 02:20 PM   #67
deneyer
Belgium
35
Originally Posted by atzebmw View Post
After you code the HU_NBT you have to assign a new cafd (detect caf for swe).
Why should i have to detect new cafd/swe for nbt when i didnt change the nbt, you have to vo code the 6wb in nbt witch you do by right clicking on nbt and hit code
      08-24-2018, 02:25 PM   #68
atzebmw
Drives: Tesla Model 3
I just changed my last posting.
      08-25-2018, 04:16 PM   #69
deneyer
Belgium
35
I checked everything and there are 2 things different.
- Kombi_Cic was set to mid with 6wa and when coded 6wb it was set to low. I changed it to High
- setting_info_display was set to aktiv in 6wa and to nicht aktiv on 6wb so i set it back to aktiv
Now i got the menu back but its called info display and not instrument cluster display.
Alsoi checked the navi option but i have noting on the cluster. With my 6wa i had the arrow on the cluster but now i get nothing. So what do you have to code for this? And in D_kombi Navi nbt_enable is set on nbt_aanzeige
Annyone know what the problem is?
      08-25-2018, 04:33 PM   #70
atzebmw
In my car it's also called "Info display".
Do you have a head up display?
Navi_NBT is also set to "nbt_anzeige" for my car.
Edit:
https://f30.bimmerpost.com/forums/sh...8&postcount=47
maybe "kein_NBT" for your car the right setting?
      08-25-2018, 05:01 PM   #71
deneyer
Belgium
35
Edit:
Kein nbt means no nbt my car has nbt, and no i don't have HUD
      08-04-2020, 04:18 PM   #72
freespirit
freespirit's Avatar
83
Drives: f30 2016 BMW 328i
Sub'ed
      08-06-2020, 06:19 AM   #73
DeeKay
DeeKay's Avatar
Denmark
553
Drives: 2021 Tesla Model 3
I have no idea what you have going on. You say you had 6WA, but error above shows BKOMBI, which is Basic Kombi. 6WA is KOMBIi and 6WB is DKOMBI.
All I can tell you is to inject CAFD, at a minimum FA must be correct (Type Code, Build Date, and Option Codes) and then your PSdZData must also have comptable CAFD with existing ECU firmware. SVT must also be correct, and if ECU is showing BKOMBI, and you have 6WB, your SVT is not correct.
Hi Shawn
Sorry to bother you but I’m really new in this coding. I purchased and got a 6WB coded in my F36 and everything works except the navigation in the middle. I then tried to log in and when loading the code from the car, it gives error BKOMBI connection. Shouldn’t BKOMBI have been swapped for DKOMBI? Naturally I can’t find your codes because of the “missing” DKOMBI menu and BKOMBI connection issue. As mentioned all other features work and I have the Instrument selection menu in iDrive where I can select what to view in instrument cluster. The navigation is there as well as an option, it just doesn’t show
| 2021 Tesla Model 3 |
      08-06-2020, 07:40 AM   #74
shawnsheridan
shawnsheridan's Avatar
Originally Posted by DeeKay View Post
Hi Shawn
You need to delete BKombi from SVT using SVT Editor, and go into E-Sys => VCM, File Tab at Bottom, and on bottom right under SVT Target, you loaded the Edited SVT file, and then select Master Tab at Bottom, and "Write SVT". Then DKOMBI should appear when you read ECU list.
      10-21-2020, 06:03 PM   #75
cjsansom
Drives: 2012 F30
Almost there 6WB
@shawnsheridan Shawn, you are the hugest help, thanks so much. Some of these threads are so long, but I promise I've tried to search them all first before this post. So I just installed a new 6WB into my F30 with HU_BASIC. I had to install a 3 ended MOST cable. I could only get BKOMBI to show up until I found your instructions on editing the SVT. I now have DKOMBI showing up. I was using 3.28.1 and could not get 'Detect CAF from SWE' to highlight. I found a post where you suggested 3.27.1. Using that I now get Detect CAF to highlight but now when I select it I get a PSdZ error "Failed to get CAFs for SWE "swfl_00003e5a-007_003_005" (C1111).
I'm guessing I don't have up to date PSdZ data? Not sure where to get it or put it (I now have both 3.28.1 and 3.27.1 installed). Ughh. The only thing I'm not sure I've done is I remember you saying you set the VO Production date to 1211?? Not sure exactly how or where to set that.
      10-21-2020, 08:28 PM   #76
shawnsheridan
I'm guessing I don't have up to date PSdZ data? Not sure where to get it or put it (I now have both 3.28.1 and 3.27.1 installed). Ughh. The only thing I'm not sure I've done is I remember you saying you set the FSC date??
Try latest PSdZData.
Injecting CAFD (Detect CAF for SWE) and Flashing ECU's with >= v.4.17.20 PSdZData requires using newer E-Sys 3.30.0 or higher.
It's FA Date (Zeitkriterium) not FSC Date.
PM sent.
      10-21-2020, 10:47 PM   #77
cjsansom
Drives: 2012 F30
PM sent.
Exact same error with 4.17.20 and ESYS 3.30.0
      10-21-2020, 10:53 PM   #78
shawnsheridan
If FA is correct for 6WB including Build Date, then you will need to flash it.
      10-21-2020, 10:57 PM   #79
cjsansom
Drives: 2012 F30
Where is the build date?
      10-21-2020, 11:10 PM   #80
shawnsheridan
FA Date = Zeitkriterium
      10-23-2020, 06:29 PM   #81
cjsansom
Drives: 2012 F30
OK, fair enough. The FA date was 0312, I changed it to 1211 but I got an error about not everything in my FP was available in 1211. I then tried 0313, but got the original error (Failed to get CAFs for SWE). Should it be something else?
      10-23-2020, 06:52 PM   #82
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
Try 1115.
      11-04-2020, 11:52 AM   #83
cjsansom
Drives: 2012 F30
Originally Posted by Ibo24 View Post
Try 1115.
So I finally was able to inject a CAFD using Esys 3.38 and latest Pzdata. FINALLY! Thank you for your help Shawn.
      11-04-2020, 11:54 AM   #84
shawnsheridan
      12-22-2020, 08:32 AM   #85
Rechard786
Drives: BMW f30 320i ed
Hi all I am 3 days new to esys. Got error below pls help.
KOMBI 60 - psdzerror
failed to get Cafs for SWE 'swfl_oooo110b_002_117_074'
Pls help. Thks
      12-22-2020, 08:36 AM   #86
shawnsheridan
Pls help. Thks
If you cannot Inject CAFD, then you must flash it.
      01-24-2022, 06:54 AM   #87
HaugF30
Drives: Bmw F30
I have Retrofitted a NBT in my car and lately i got a Tyre Pressure Warning, checked all my tires and they were all good.
I then tried to reset the warning, but with no result, this is a 2010 F10 so i don't have the valve types that is in the rims.
But anyway, i tried to code the entire tire Pressure thingy away, but somehow i cannot acess my Kombi, since i have managed to code it away in the NBT_Hu i guess i will also have to code it away from the KOMBI.
But i get this error:
https://f30.bimmerpost.com/forums/at...1&d=1643028857
      01-24-2022, 06:57 AM   #88
shawnsheridan
[url]https://f30.bimmerpost.com/forums/attachment.php?
When you read ECU List, does KOMBI have CAFD or is it missing?
