09-19-2017, 12:41 AM | #23 | |
Rep 808
The LSD will have more impact if you are tracking the car, suspension during day to day driving and appearance. Last edited by the dope steez; 09-19-2017 at 10:36 AM.. |
09-23-2017, 06:52 PM | #25 | ||
Rep 3,947
1. Tires - Square Michelin 255/40/18 Pilot Super Sports. 2. Brakes - F8X M3/M4 stock pads in my M Sport Brake Option. They're holding up to HPDE use for now. If I'm spending more time in the Intermediate/Advanced or Advanced run groups, I may need to move up to Pagid RSL29 pads. 3. LSD - You can apply more throttle much sooner after apexing. Without an LSD, you really have to wait for the car to settle because accelerating out of a corner was a bit "busier" with that open differential. This definitely shows when you're on the skid pad and trying to maintain oversteer. 4. M Performance Suspension Kit - I basically did this because my stock passive 704 Sport Suspension was due to be replaced at approximately > 70,000 miles. I suppose if you're just a typical commuter driver and are simply concerned with how the car rides on a straight highway, you could just do suspension, but that type of static driving would seem awfully boring. |
zinner559.00 |
09-23-2017, 11:28 PM | #26 |
Rep 142
09-24-2017, 04:23 AM | #27 |
Rep 3,947
MacklinUSOB518.00 |
09-24-2017, 10:11 PM | #28 | |
Cheapskate
4450
Rep 4,993
i also vote coilovers. you get the benefits of looks and performance that you don't need to drive at the limit to feel during regular street driving. instant gratification. |
09-25-2017, 05:49 AM | #29 | |
Rep 3,947
Since the OP is asking suspension vs. LSD, it's reasonable to assume that he's concerned with performance and not just the opinions of his stance brethren. Last edited by Polo08816; 09-25-2017 at 10:33 AM.. |
09-25-2017, 11:57 AM | #30 | |
Cheapskate
4450
Rep 4,993
regardless, a differential is a wear item. Eventually it will fail and need to be replaced. Doesn't matter how well you take care of it. he's modifying the car to improve it. you don't have to wait for an item to fail to replace it. clearly people on this board value modifications over $$$ value. that's just an absurd statement to make when someone is clearly modifying their car for one purpose. i've done both and can say that i enjoyed the coilovers much more. an lsd only helps you in turns when you are pushing it. the open diff is plenty capable until you start pulling a wheel, especially with summer tires. with coilovers you instantly feel the car get stiffer and stay more level through turns at any speed. i threw an lsd on my car first thinking it would transform it and still spun on the street and drag strip. it wasn't until i started tracking the car heavily that i felt the handling improvement. and since OP is asking suspension vs. LSD which will make the greater difference in overall handling and feel on a daily driver, i vote coilovers. you won't be waiting for sweeping on ramps to enjoy it (only to get stuck behind a minivan when you finally get to a good one). |
09-25-2017, 12:18 PM | #31 | ||
Rep 3,947
I would make the argument that because he lives in Maryland, is RWD, and does see some snow in the winter season, an LSD is a greater improvement for a car that is a daily driven even in inclement weather conditions. So to answer the question of which is the better bang for the buck? Given that he already has the optioned Adaptive M suspension and wants this car to be both his daily and occasional track/autox vehicle, an LSD is the better bang for the buck. |
09-25-2017, 12:47 PM | #32 | |
Rep 969
kern4174449.50 |
09-25-2017, 12:49 PM | #33 | |
Rep 3,947
At the end of the day, you'll always get people who cheerlead the purchases they've made. I'm also not surprised you'll have more people pedaling the coilovers because that's an easier DIY. If you can get the car on jack stands in your garage/driveway, you can install coilovers. The same is not true for the differential. You pretty much need a lift, transmission/diff jack, and a BMW special tool to remove the axle shafts. Also, the optimum suspension geometry is about 10mm lower than the 704 Sport Suspension. That's a figure that Ohlins, AST, and BMW have pretty much agreed upon. If you're lowering your car more than that, then you've clearly placed importance of aesthetics over function/performance. Last edited by Polo08816; 09-25-2017 at 12:58 PM.. |
09-25-2017, 01:22 PM | #34 |
Rep 1,291
Guys there’s no need for such a heated argument, you’re both respected members, i’ve been here long enough to know that... bottom line to me is both upgrades are worthwhile.
To chime in in some way that i hope is useful 1) I’d say wearables are primarily tyres and brakes (and fluids but well...), dampers come later in life as does friction-plates LSD, but *not* open or quaife-style differentials. Ultimately a car is wearable anyway, depending on the time horizon you consider. 2) coilovers also come in EDC compatible flavour, i’m happy with my KW DDC coilovers, giving much better body roll control as well as braking performance without losing the adaptive aspect (i like my gadgets )
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i Last edited by Lancelot; 09-25-2017 at 01:30 PM.. |
09-26-2017, 07:29 AM | #35 | |
Cheapskate
4450
Rep 4,993
if you want to be honest, tell OP that after tires and brakes, you're not going to be knocking seconds off fast with any one mod. |
F30_SixSpeed1170.50 |
09-26-2017, 09:16 AM | #36 | ||
Rep 3,947
But it also sounds like the OP doesn't want to do anything other than coilovers to his suspension regarding suspension geometry. Also, look at the following front axle drops: Base RWD - 0mm 704 Sport Suspension RWD - 10mm Ohlins, AST, and BMW M Performance - 20mm (recommended - * Ohlins and AST can be set to stock height) KW Street Comfort for RWD - 1.2" ~ 30.5mm (minimum drop - beyond the optimal drop) KW V3 - 1.6" ~ 40.6mm (minimum drop) KW is more for aesthetics and takes the "good enough" approach to apply to a wide range of chassis codes. If you're going to spend that much money on a coilover system for a RWD F2X, F3X chassis, do it right from the beginning and go with Ohlins or AST. In addition, the OP lives in Maryland which sees snow and is hilly. If this car is going to be a daily driver even in the winter, I'd recommend a minimal drop and an LSD. Upon further review, kern417 , are you the guy that was looking to install an air lift system on your car... http://f30.bimmerpost.com/forums/sho....php?t=1404655 Quote:
09-26-2017, 03:03 PM | #38 | |
Cheapskate
4450
Rep 4,993
and yes, i was looking at an air lift system because the house i lived in had a 30* slope to get into the driveway. i barely made it on a stock car without scraping, so there would be no chances after lowering with a front lip. the design of the kit is the same as what you get on exotics to lift the front end. you must have thought i was looking for air bags but regardless, the house i'm in now has a flat driveway, so no worries there either . idk what planet you live on but for everyone else that's having fun, coilovers is 100% the way to go. half the people i know are disappointed because an lsd didn't give them the benefit they thought it would, and the other half probably forgot they even have it installed. great for a road course, but nothing special for a daily driver. especially when you try to add speed and the whole car leans to the outside line. these cars tend to understeer from the factory anyway. |
09-26-2017, 03:24 PM | #39 | |
Rep 3,947
I knew exactly what an air lift system was. At least air bags are functional when you're carrying higher payloads or towing with a substantial tongue weight. I just can't take someone who lowers his car substantially, installs a front lip that offers no functional benefit + reduces the front approach angle, and then needs to look into an "air lift" system to clear his own driveway seriously. |
09-27-2017, 11:41 AM | #40 | |
Cheapskate
4450
Rep 4,993
like wth are you thinking and now you are pretty much saying you don't understand why anyone would modify their car to improve the appearance. you're just as dense as i thought lol. go sell your car and build a miata. you'll finally hit your goal of all go/no show that you're yearning for. |
09-27-2017, 01:06 PM | #41 | |
Rep 3,947
Ohlins coilovers - $2375 * http://www.hpashop.com/Ohlins-RT-F3x...ins-RT-F3x.htm Installation accessories - ~$500 - replacement top hats, bolts, nuts, etc. which are recommended when installing suspension. bolts are stretch bolts which are one time use Installation cost - ~$500 * per OP Approximate total cost - $3375 KW Street Comfort - $1640 Installation accessories - ~$500 - replacement top hats, bolts, nuts, etc. which are recommended when installing suspension. bolts are stretch bolts which are one time use Installation cost - ~$500 * per OP Approximately total cost - $2640 From a percentage difference perspective, it's not significantly different. Like all things in life, if you're planning on doing something, just get it right the first time if possible. |
09-28-2017, 08:26 AM | #42 |
Cheapskate
4450
Rep 4,993
nope, not a math issue.
https://www.turnermotorsport.com/p-3...-435xi/?pdk=AQ $1320, albeit the awd version. i've tried various coilovers from $500 solowerks to $900 bc's to $2k clubsport coils. the only thing i haven't tried is a regular strut/spring combo. But for daily driving fun and enjoyment, the $1000ish coils are great. nothing "wrong" about those options. like i said before, theres no doubt that there can be a performance improvement in the right setting with the right driver, but you're not going to experience that in day to day traffic. unless you are getting custom suspension with your own spring rates and adjustable dampening/rebound, camber/caster plates, etc etc etc. you're leaving something on the table. the definition of "right" is relative. this reminds of another thread about how people waste money on their cars. like yes you can go spend $5k+ on ceramic brakes, but everyone knows it's a waste for street driving. there's nothing wrong with choosing an option that's still high quality but a better value. |
09-30-2017, 08:44 AM | #43 | |
Rep 3,947
The best combination for a passive fixed suspension is - hands down - the BMW M Performance Suspension Kit. You give up a bit of NVH for a factory performance solution. As far as ceramic brakes, they're too expensive to run at the track unless you're sponsored or are ridiculously wealthy. Steel brakes are the way to go for the average enthusiast. |
09-30-2017, 11:25 AM | #44 |
Cheapskate
4450
Rep 4,993
so we agree on something. but there are plenty of people that got the ceramic brakes because it's the best, and why wouldn't you get the best if you're going to upgrade? so when someone asks if it's worth it, you have to consider other factors besides what's best performance-wise.
for example this go around on my 2018, i'm doing coilovers and axle back first. even though it doesn't make the car significantly faster, that's what made my previous cars the most fun and made the biggest difference in feel. my car already came with summer tires, and not interested in piggy back tunes currently, so i'm good in those areas. other mods will round it out down the road but an LSD wasn't the first thing i felt that i missed. i still can corner fast enough that my wife gets pissed at the lack of an o-shit handle. |
