12-09-2019, 02:13 AM | #1 |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
NBT EVO retrofit issues
I have retrofitted a 2019 NBT EVO HW4.1 headunit along with a CAN filter and wiring harness (https://www.ebay.com/itm/BMW-F-SERIE...Y/163330868386). I also added a 10.25" touchscreen and an ATM that was verified to work by another member here. I changed the VIN in the headunit to the VIN of the ATM in e-sys, VO coded the HU_NBT2, and then coded the proper resolution for the screen.
When it first booted up the main menu was just a list starting in the middle of the screen and then scrolling down out of view. Certain menus and apps filled the screen ok but there were many alignment issues. I went and coded HMI_VERSION to "id5" (id4_plus_plus and id5 were the only options), but then when I code HMI_ID_VERSION to "id6" the UI looks like the pictures. When I code it for "id5" it works exactly as it should and "id6_lite" works as well, but this headunit should be able to handle ID6. Is there some other coding parameters I'm missing? Furthermore, GPS is not working and in the ConnectedDrive menu the 'Update services' link is greyed out. FM radio and bluetooth work though. I went to read the FDL coding for the ATM in e-sys and I get connectivity/timeout errors. Any thoughts on what to do there? This harness should be 100% plug and play. Edit: for anyone reading this down the road I wanted to edit the first post to say that I got connecteddrive services 100% working. When I first coded the HU I changed the VIN to the ATM VIN using 'FSC Extended' in e-sys but I did not change the VIN in my FA before VO coding NBT2. GPS and Navigation worked but the car did not receive the confirmation code when registering the ATM VIN on the connecteddrive website. Later I went back and changed the VIN in my FA to the VIN of the ATM and VO coded NBT2 again, after that I was able to register online and the car received the confirmation code. Navigation, BMW Apps, and the connecteddrive phone app all work great now Edited again just to clarify my above edit: You should create and maintain 2 discrete FAs that are identical except for one difference: #1 has the VIN from your ATM and #2 has the VIN for your actual vehicle. Use the #1 FA with the ATM VIN for coding NBT ONLY! Use the #2 FA with your vehicle VIN when VO coding any other module. Last edited by psyki; 09-14-2022 at 10:03 PM.. |
12-09-2019, 12:19 PM | #3 | |
Luxury at the redline :)
9105
Rep 7,563
The NBT EVO uses the ConnectDrive 4G data to determine its GPS location, it doesn't use a dedicated aerial antenna like the Pre-EVO units did. Until you get it to have a steady in-vehicle data connection, the GPS will not work. I can't figure exactly out why the service is grayed-out but that the reason for no GPS data. |
12-09-2019, 12:49 PM | #4 | |
E36fiend
285
Rep 637
I believe I have everything hooked up correctly. The fact that I can't read FDL from the ATM in e-sys is troubling, I will check in ISTA for errors there. |
Poochie9104.50 |
12-09-2019, 01:09 PM | #5 |
9105
Rep 7,563
You're probably going to have a slew of similar errors in ISTA-D, good luck trying to figuring out which out is related to the data outage. However, mismatch a VIN in the ATM and headunit sounds like the likely culprit.
I was considering this mod since I have a NBT EVO but ID4 but seeing how intricate the installation is, I'm beginning to believe that CarPlay and Waze is not worth the hassle. Nevertheless, good luck and keep us updated. |
12-09-2019, 02:26 PM | #6 | |
E36fiend
285
Rep 637
12-09-2019, 04:09 PM | #7 | ||
9105
Rep 7,563
Since certain parts of the world doesn't have ConnectDrive data service, BMW coded EVO units in those regions to instead use external antenna for GPS, instead of the ATM, like in the US drives. You just have to figure out the proper parameters to make those change, if you're unable to resolve the gray-out issue and choose to go that route. |
12-09-2019, 05:02 PM | #8 | |
Rep 10,473
ATM is a must to feed GPS signal. |
12-09-2019, 05:09 PM | #9 | ||||
9105
Rep 7,563
12-09-2019, 07:59 PM | #10 |
9105
Rep 7,563
12-09-2019, 08:32 PM | #11 | |
Rep 10,473
12-09-2019, 08:36 PM | #12 | ||
9105
Rep 7,563
I can't find one case of someone successfully doing so. This seems like a easier workaround.. |
12-09-2019, 08:38 PM | #13 | |||
Rep 10,473
If not concerned about connected drive, very easy to make VINs match and work. |
12-09-2019, 08:42 PM | #14 | ||||
9105
Rep 7,563
What's required exactly to go from a NBT EVO ID4 to a ID6 and retain all the functionality? I'm still learning the ropes of this mod, it's pretty intricate for a novice. |
12-09-2019, 08:47 PM | #15 | |||||
Rep 10,473
All that's needed is iDrive 6 HU (really should get HW 4.1, the latest and most likely the last iDrive 6 Hardware Level) NOT FROM OVERSEAS. I'd be safe and only buy a USA, not even Canadian model. Code your VIN in the HU and a few changes in NBT2 coding to change to ID6 with esys. As your ATM is already installed and working with your VIN, no changes needed there. |
Poochie9104.50 |
12-09-2019, 08:50 PM | #16 | ||||||
9105
Rep 7,563
Silly FYI, why not from overseas; does the harddrive vary from a US-spec unit or is it a language issue? |
12-09-2019, 08:53 PM | #17 | |||||||
Rep 10,473
2) They do not have HDRadio 3) They do not have SiriusXM chips Canadian is technically SiriusXM Canada and might have subscription issues to USA service at some point. |
Poochie9104.50 |
12-10-2019, 12:23 AM | #18 |
E36fiend
285
Rep 637
Update: I got GPS to work, there was a wiring issue that once resolved the location resolved immediately. I purchased a set of FSC codes from a vendor that I haven't been able to get working yet, apparently this headunit is too new to use the thumbdrive flash trick and when I tried using the vendor provided Feature Installer I'm getting an error message. I've reach out to them for assistance, I'll update when I have new info.
Poochie9104.50 |
12-10-2019, 12:50 AM | #19 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
12-10-2019, 01:43 AM | #20 |
E36fiend
285
Rep 637
Thanks for the tip! The vendor I bought the FSC set from is who made the wiring harness I'm using. Can you elaborate on exactly what pins need to get moved and where? Do they need to be moved or can I splice them?
12-10-2019, 07:24 AM | #21 | |
Rep 1,976
From what I know, the Ethernet pins are on the bottom right slot of quad lock and those wires are really thin to just take out.
Poochie9104.50 |
12-10-2019, 09:44 AM | #22 | ||
Rep 10,473
https://www.ebay.com/itm/BMW-NBT-EVO...r/113887576479 |
