12-10-2019, 10:08 AM | #23 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
IK6SPEED4488.00 |
12-10-2019, 11:30 AM | #24 | |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
These are the wires I was told to move from quadlock to OABR: 31 17-ETX_TH+ 32 19-ETX_TH- 37 18-ETX_RH+ 38 20-ETX_RH- On the stock EVO connectors there is nothing plugged into quadlock 31/32/37/38 but there are pins in OABR 17/18/19/20. If I recall correctly, on the wiring harness I purchased pins 17/18/19/20 are unoccupied on the OABR connector so I'll have to check what's plugged into the quadlock in the car. My guess is that 31/32/37/38 on the wiring harness quadlock are actually fed by the cars original quadlock which is what I need to move to the OABR. I have a set of keys for removing MQS pins and I was able to remove the pins from the original OABR so I should be able to splice the 6" of twisted wire to the correct wires in the quadlock and insert the pins into the OABR in the car. Last edited by psyki; 12-10-2019 at 11:46 AM.. |
12-10-2019, 02:43 PM | #25 | ||||
Rep 1,912
2016 cars have a NBT Evo ID 4 silver top with a ATM. You just need a ID5 or ID6 black top head unit. Flash the head unit wiping the old FSC. Then get a FSC repair kit matching your vin. NBT next cars (2014-2015) will need a ATM and NBT Evo that will have to be coded to matched the ATM donor vin. I have done this in a few E9X's with full working connected drive. Just today one of those cars was involved in a bad accident. BMW Assist automatically called the police and recorded the car's location. They did not care at all that the car was a E91 instead of the X3 ATM donor car. The same concept applies to your F30s. Make the NBT Evo and ATM match. Then trick them into thinking they are in the donor car. You don't even need a coding bench to flash the NBT Evo. I flash NBT Evos in my E90 using Ethernet direct to the head unit. Maybe it is time for a DIY post to spill the beans on the NBT Evo. You can read up more info on my dev thread but it is not a DIY: https://www.e90post.com/forums/showthread.php?t=1569776 Last edited by Nickco43; 12-10-2019 at 02:52 PM.. |
12-11-2019, 07:47 AM | #26 |
Luxury at the redline :)
9105
Rep 7,563
[/QUOTE]
Thank you very much for the info, especially the link. I'm not sure why I didn't find it before but it's very informative and answered all my questions with certainty. |
12-11-2019, 08:44 AM | #27 | |
Rep 10,473
It's ridiculous to spend that much for a retrofit that leaves out some of the features, imo. |
12-11-2019, 10:26 AM | #28 |
Rep 1,467
following.
12-11-2019, 01:28 PM | #29 |
E36fiend
285
Rep 637
Update: Got everything working last night, once I moved the 4 pins from the quadlock to the OABR connector as advised the Feature Installer tool applied the FSC codes without a hitch. Navigation now works!
All in all this was not the most difficult retrofit (adaptive cruise control was much more involved), I strongly encourage anyone interested to purchase the wiring harness I linked earlier in this thread. With it the entire hardware install is 99% plug and play if you have a pre-2019 headunit as you can apply FSC codes with a thumb drive. I only had to move the wires because my HU has an 18-11 i-step level which has defeated the thumb drive patch technique. Modifying the dash and screen for the 10.25" touch screen only took a dremel and about an hour of time, the higher resolution screen is gorgeous and looks like it belongs in the dash although reaching up to touch it is rather cumbersome. I'm thinking about removing the silver trim and painting it satin black. ConnectedDrive services are not working yet but I have a plan I'm confident will work, for the time being it appears the previous owner purchased an RTTI subscription that is good until June so I'm set there If you've used e-sys to do FDL coding, you can perform the coding steps necessary to make this retrofit work. Just make sure you get a HW4.1 headunit as they come with 4GB RAM and will not need to be flashed to work. Thanks to IK6SPEED and steve@codemybimmer for assistance! Feel free to ask any questions, I'll update the thread when I get ConnectedDrive working. |
12-11-2019, 03:31 PM | #31 |
9105
Rep 7,563
Looks great, love the bigger screen.
Why is the ConnectDrive service not working yet? And also, does the BMW APPs (Spotify, Pandora, M Laptimer, ect) working also? |
12-11-2019, 03:39 PM | #32 | |
E36fiend
285
Rep 637
After I applied the FSC codes I wasn't sure if I was supposed to perform an 'Update services' but I've learned that it's fine so I still need to do that. I'll update here in a little bit with the results but yes, the FSC set I purchased has all those apps. |
Poochie9104.50 |
12-11-2019, 03:57 PM | #33 | ||
9105
Rep 7,563
One last question, I had swapped just my iDrive 4 EVO controller to the ceramic version and everything worked fine but I kept getting a persistent fault code within ISTA-D indicating that the new controller needed to be encoded. I then sold the controller and purchase a stock one, as what came with my vehicle but the fault code remained. I went through hell trying to get rid of it and the only way I was able to resolve it is have the dealer update the software and program my vehicle accept the new controller. Did you ever run a test on your vehicle to see if any hidden fault code exist due to the new hardware? |
12-11-2019, 04:18 PM | #34 | |||
Rep 10,473
I wonder if your replacement controller was out of a non-F3x as well as that would present same error. If it's not a F3x controller, ISTA will not like it being there. Tell everyone who sells their old parts like this to recoup costs they are nuts as eventually they will probably be needed. |
Poochie9104.50 |
12-11-2019, 04:41 PM | #35 | ||||
9105
Rep 7,563
I've come to the conclusion that any replacement controller needs to be programmed to the vehicle. The dealer updated the entire iStep and all the modules but some folks here claim that it was unnecessary, as only one module can be solely programed, without updating the software. : My question is if I upgrade to ID6, which is obviously a different controller, would I have the same issue? As I mentioned to you before, the ceramic controller worked fine even with the exception of the fault code but I'm so anal about these things, it just kept bugging me until I found a way to get rid of it.. I'm one of those guys.. BTW, excellent advice on keeping all your old electronic parts in case of future software updates; it should be a sticky post but most folks here are so hardheaded, they would probably ignore it and learn the hard way. |
12-12-2019, 09:26 AM | #36 | |
Rep 464
Yes you will. In my experience, any time I replace a module (that contains a CAFD file), the CAFD file is missing in the replacement module when connected into my vehicle and I have to add ("inject") and configure (i.e. VO/FDL code) the CAFD file to my vehicle (FA). FYI, I routinely check and update the FW (i-level) of the replacement module to that of the rest of the vehicle. Not absolutely necessary but if there are dependencies with other modules, there may be compatibility issues. Do you have a Launcher Pro 3/E-sys/e-net cable setup? If you do, use E-sys to read the SVT of your vehicle and check your CON (ZBE3?) to see if it has a CAFD file. If not you will have to inject the right i-level CAFD file and then VO Code the CON module. Larry
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
Poochie9104.50 |
12-12-2019, 09:46 AM | #37 | ||
9105
Rep 7,563
I would give you two "likes" if I could I suspected replacing the controller would result in a "encoding" fault error again. When I originally had the issue, I had spoken to 5 different "coders" here and even had one assist me remotely but none of them could give me a strait answer or help me in removing the permanent fault. It was extremely frustrating.. Only after the dealer programmed the vehicle to a new controller had the fault disappeared but I lost all my custom coding, including some options I could no longer recover (increasing the triple-turn signal). I accidentally spilled a can of Redbull on my laptop so it's currently being repaired but the vehicle is fine now, no more fault, therefore I don't need to run ESYS any further. However, I couldn't leave well enough alone and I was looking to upgrade to ID6 But after your advice today, I'm not going I do the swap anymore. There is too many "what iffs" for my liking. Had you not dole out this vital piece of missing info, I suspected I would of made a poor choice, so thanks again for the information! I've encountered a few that have the same fault, so here's a printout of what the dealer did to resolve the issue for anyone else that might run into a similar problem |
12-12-2019, 11:55 AM | #38 |
Rep 464
Hi Poochie,
If you have the proper tools (E-sys and ISTA+) which I believe you already have available and someone experienced with ID6 retrofits to help e.g. steve@codemybimmer, it should be a straight-forward process to retrofit an ID6 HU, especially if I am right, your 2016 M2 came with the proper Telematics box. PM to me your VIN or manufacturing date and I will check to determine what hardware was factory installed in your M2. Larry
Poochie9104.50 |
12-12-2019, 12:36 PM | #39 | |||
Rep 10,473
12-12-2019, 01:06 PM | #40 | |
9105
Rep 7,563
After the last incident, you have to understand I was on island by myself trying to figure it out, so I'm a little gun-shy this time around but I will be paying attention. I sincerely appreciate all your help and I look forward to others making progress with this mod! |
12-12-2019, 01:20 PM | #41 | ||||
9105
Rep 7,563
Everyone and all that did it so far claim that ConnectDrive functions might be in jeopardy of not functioning properly and can't guarantee any hidden faults. That doesn't inspire a lot of confidence. I'm going to wait until someone makes some headway on this retrofit and then I'll go for there. BMW's complicated CAN Bus system is prone to fault if everything is not in synced with each other and is not something I want to deal with at the moment. |
12-12-2019, 01:54 PM | #42 | |
Rep 464
I understand and respect your decision.... Larry
Poochie9104.50 |
12-12-2019, 02:47 PM | #43 | |||||
Rep 10,473
