04-07-2020, 01:04 PM | #1 |
Rep 12
Help with an amp install on basic stereo sound system
Hi,
I have a '12 f30, with nbt retrofitted, I'm trying to install an aftermarket amplifier, POWERBOX65.4M-V7: Powerbox 520 Watt Micro 4 Channel Amplifier, not sure where am I supposed to connect the rem in& out wires to? Can I splice it into any of the wires available? Any idea? The pinout is in the attachment. Thank you |
04-14-2020, 12:37 PM | #2 |
Rep 77
Not sure what you are trying to do but all you need to get this working with a base Head Unit is a Connects2 CT10BM05 SOT T-Harness Adaptor ISO Wiring Lead. Cost around £15.00 I had this confirmed by Vibe Technical department.
There is a video on utube simples .......... I'm considering using this amp as a simple PnP solution after upgrading my base front door speakers to HK mids & HK Tweeters. My original thread is here: https://f30.bimmerpost.com/forums/sh....php?t=1701485 This upgrade has noticeably improved the listening experience but now I want to boost the bass by adding a set of either Eton B195 or Vibe OPTISOUND Mid Woofers. Just wondering about the 4 pin connector on the base subs into a 2 pin on the Vibe. The Etons accept the original 4 pin but cost twice as much for the privilege! |
04-14-2020, 03:27 PM | #3 | |
Rep 2,180
The 4-pin connector at the OEM woofers is the parallel connection of the front and woofers. If you unplug the OEM woofers then there will not be any power/sound to the front speakers.
This Vibe amp seems to be wired (ISO Quadralock harness) to power front and rear speakers, leaving the OEM woofers connected to the front speakers. A better connection would be to use the Vibe amp to power front and woofers, leaving the rear speakers powered by the OEM HU. But the Vibe amp ISO harness is not made to support this configuration for two reasons- the OEM HU front outputs are full range, but not the rear so the rear channels of the Vibe amp cannot be used to power woofers unless the 4 inputs of the Vibe amp are connected to the front outputs of the OEM HU, and woofers must be connected to the new rear outputs of the Vibe amp by running new cables to each woofer. The 4-pin parallel connection is gone with the removal of OEM woofers so you need to create jumpers at the female 4-pin woofer connector in the car (pin 1-2, pin 3-4) for the Vibe amp to power the front speakers. Otherwise they will not sound. Jumpers are shown in the photo of the MB Quart speaker kit suggested in your other thread. Quote:
04-14-2020, 04:34 PM | #4 |
Rep 12
I don't have room for a harness, as I already have one for the nbt, the gps antenna and so on. I am planning on splicing into the wires going in the pins 1-8 in the attached picture, and also the power and ground. As previously said, not sure where to connect the rem, the wires that are sending the signal to the amplifier to turn on/off, don't want it draining the battery.
04-14-2020, 04:48 PM | #5 | |
Rep 2,180
04-14-2020, 05:35 PM | #7 |
Rep 2,180
04-14-2020, 05:40 PM | #8 |
Rep 12
I was asking because from what I read so far rem would give in an impulse to start( the same as a tv, even if it's powered on, you need to turn it on still) and rem out to send the signal to shut off. What do you think?
04-14-2020, 06:12 PM | #9 | |
Rep 77
1. the 4 inputs of the Vibe amp. I can only find 2 input/outputs all RCA. 2. are connected to the front outputs of the OEM HU.... How? 3. woofers must be connected to the new rear outputs of the Vibe amp. What new rear outputs? Is there a way to simply convert the female 4-pin woofer connector to accept a 2 pin connection & retain the front speaker signal? |
04-14-2020, 07:01 PM | #10 |
Rep 2,180
That’s pin 13 at the Quadralock - remote out- which connects to the Vibe amp - REM (remote in).
04-14-2020, 07:12 PM | #11 |
Rep 12
04-14-2020, 07:14 PM | #12 | |
Rep 2,180
The OEM HU outputs are full range front and high pass rear. The Vibe amp harness will use those outputs as its inputs. The Vibe amp outputs will be full range front, high pass rear.
You cannot power the woofers with a high passed signal unless you want no bass. Therefore you need to wire all Vibe inputs to the OEM HU front outputs (split 2ch into 4ch). Then Vibe amp outputs will be all full range, front and rear. Now the woofers can have bass. The rear speakers will be powered by the OEM HU rear outputs. It is not clear if this Vibe amp has crossovers. If not then Eton has a dedicated crossover for this type of amped front/woofer 4ch setup. If you do not want this front/woofer setup then get the Eton woofer (4-pin). Otherwise you will need to wire the Vibe woofers for a 4-wire setup at the OEM female woofer connector -jump pin 1 to 2, pin 3 to 4. You will know what to do once you remove the OEM woofer. Quote:
04-14-2020, 07:16 PM | #13 |
Rep 2,180
04-14-2020, 07:24 PM | #14 |
Rep 12
And by doing this it will be triggered to turn on by radio on pin, just wondering will it to off automatically when turning off the car/hear unit? Sorry to be a pain, just trying to fully understand this setup.
04-15-2020, 05:16 AM | #16 |
Rep 12
04-15-2020, 07:07 AM | #17 | |
Rep 77
So......Can I connect a 2 pin Vibe woofer or any other 2 pin speaker via the BMW OEM sub connector 4 pin using pins 1 & 3? I'm assuming 1 is positive & 3 is neg [or is it 2 & 4?] whilst at the same time jumping the pins 1-2 & 3-4 to maintain the front door speaker signal? In other words jump the connectors but spur + & - wires off from the pins to connect the woofers. If so I may go with a set of HK subs and do a straight swap as mine are almost certainly glued in. What a botch job the base stereo is! I think that BMW intentionally made this as difficult as possible to upgrade by gluing in the woofer & making the speaker terminals and connectors incompatible. |
04-15-2020, 08:41 AM | #18 | ||
Rep 2,180
Pins 2 and 3 are coming from the OEM HU front output, pins 1 and 4 go to the front speakers. So unplugging OEM 4-pin woofers and connecting a 2-pin woofer (pins 2/3) means disconnecting the front speakers (pins 1/4) from the system. Quote:
Again, once you take a look at the 4-pin connector you will know what to do. |
04-15-2020, 09:05 AM | #19 | |
Rep 77
04-15-2020, 09:23 AM | #20 | |
Rep 2,180
Pin numbers are in the connector if you look closely. |
04-15-2020, 09:43 AM | #21 |
Rep 12
Encanto, can you please tell me if I do as you said and connect the amplifier REM to pin 13 and leave the REM Out unconnected, do you think the amp will turn off with the radio or not? Any thoughts? Thank you
04-15-2020, 09:48 AM | #22 |
Rep 77
And the mist is lifted! So a 2 pin connection is possible. Just jump pins 1/2 & 3/4 & then connect 2/3 to the woofer. Thank you.
Is there any recommended or preferred method for doing this. I've seen numerous examples all look very professional. |
