08-08-2013, 06:15 PM | #1 |
Rep 1,591
#ProjectKatniss: AW M-Sport F30 335i
BMS Stage 1
Alright so bone stock (2013 BMW 335i M-Sport 8AT) we did a baseline dyno run on DynoJet @ EAS in Anaheim CA two weeks ago. Put down ~277whp/297tq without any mods whatsoever. Today I had them install the BMS Stage 1, the best run was ~295whp/339tq. The 'butt dyno' feel you all are getting on your Stage 1 is definitely a direct result of the TQ increase. I'll post up the actual dyno charts once I get them sent electronically or I'll scan what I have in. Dyno video Macht Schnell 15mm wheel spacers on BMW 403M 19" wheels On a side note, threw some Macht Schnell 15mm spacers on while I was EAS so you can see what they look like on 403M wheels and stock suspension. 10mm were out-of-stock so I wasn't able to do the front just yet. Before After. Please bear in mind that this was right after putting it back on the ground and is at stock M-Sport suspension height. With a slight drop and/or settling it will camber in a bit. iND Front Painted Reflectors Then, as soon as I get home from EAS today my front reflectors arrived so I threw those on real quick. (I know. You've seen one, you've seen 'em all)
-JustinNApproved
08-08-2013, 06:26 PM | #2 |
Rep 1,975
Not too bad at all. Dp and stage2! ... I wish I knew a good dyno nearby to take mine to
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
08-08-2013, 06:28 PM | #3 |
Rep 1,591
Pretty much. Downpipe and Stage 2 are in the near future. I need to do suspension and wheels next though. I put spacers on to hold me over for a bit so that I can just do suspension next.
-JustinNApproved
08-08-2013, 06:56 PM | #4 |
Rep 3,780
My guess is 91 octane. 93 octane and the extra psi would get you another 8-9whp.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
08-08-2013, 06:58 PM | #5 |
Rep 886
I envy your 295whp/339wtq with just the BMS Stage 1!! I'm at about 285whp/315wtq with my Stage 2 and 93oct
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
08-08-2013, 07:18 PM | #6 |
Rep 710
Damn. Imagine what a downpipe and stage 2 will look like on the dyno
**JB Stage 1** 2012 F30 335i/BSM/Coral Red Interior/Diamond Black Trim/Premium Pack/BMW Apps/Ext Blue Tooth/Sirius XM/Sport Auto W/Paddle Shifters/Sport Suspension/Meisterschaft Super GT Exhaust
08-08-2013, 07:29 PM | #7 |
Rep 3,780
His numbers are on a dynojet. If yours are from a Mustang or SuperFlo, they run lower.
08-08-2013, 07:30 PM | #8 |
Rep 1,591
Yeah I think he has a 328i. Which makes the difference here.
-JustinNApproved
08-08-2013, 08:09 PM | #10 | |
Rep 1,591
Seeing Adam from the M3 boards there again today putting down 500whp+ all day is very humbling though. Lol
-JustinNApproved
08-08-2013, 08:26 PM | #11 | |
Rep 886
I moan and groan daily about not getting the 335, oh well I guess, was trying to be financially responsible at the time, ugh. Hopefully in 2-2.5yrs the M2 will be out so I can just switch over to that and call it a day
08-10-2013, 05:50 PM | #12 | |
Rep 665
Out of curiosity, were weather conditions very similar on both dyno days? |
08-10-2013, 06:30 PM | #14 |
Rep 4,323
That's about what mine "feels" like, I just need to head Ivey Tuning to compare to my Evo VIII, where I put down about the same (300/320awtq)....my BMW feels faster than the Evo up top, and definitely more stable, but down load, from the dig, the Evo had a bit more grunt because of the awd. I DO need to launch without DSC though...
08-10-2013, 08:36 PM | #15 |
Rep 665
Even though comparing peak dyno numbers and nothing more from cars dynoing at different places, in different conditions etc.... To make it somewhat more comparable, you guys posting dyno numbers should include (if possible)
08-11-2013, 10:44 AM | #18 | |
Rep 1,575
08-12-2013, 11:45 AM | #19 |
Rep 886
As long as it is not leaded race gas, you should be fine. I would do a bit more research though before you pull the trigger...just for peace of mind
08-12-2013, 11:52 AM | #20 | |
Rep 3,780
For some reason, on my Ipad, your info made it seem like you had a stage 2 N55-hence my Mustang vs Dynojet comment.
08-12-2013, 11:57 AM | #21 |
Rep 1,591
Jameson looking at your signature, your roadster must be nuts with that kind of power! What does it weigh?
-JustinNApproved
08-12-2013, 02:24 PM | #22 | |
Rep 3,780
It's heavier than it looks thanks to a power top, heated power seats and all the other power options you get in a modern car. It's about 3000lbs. But it's still a pretty solid power to weight ratio, traps about 120mph in the 1/4 when everything is dialed in which I am working on at the moment.
