BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Error when trying to code KOMBI
      09-22-2022, 06:42 PM   #111
shawnsheridan
shawnsheridan's Avatar
Originally Posted by HerbT View Post
its original kombi of the car. i got that error when i was coding with bimmercode app. after coding digital seed on cluster right after it rebooted its 999999
Well, fault code is for Mileage Manipulation:
Fault Code Description
Internal fault.
The total distance cannot be restored in the instrument panel.
The fault code entry occurs if the total distance stored in the EEPROM of the instrument cluster cannot be read after a reset.
The total distance in the instrument cluster and in the partner control unit is faulty. The total distance travelled cannot be restored in the vehicle.
The fault memory entry will only be detected one time per terminal change. The fault memory entry is made when the total distance can be restored neither from the instrument cluster nor from the partner control unit after turning on terminal R.
Fault Impact
The value 999999 km is displayed in the instrument cluster for the total distance. The manipulation dot is set.
What is story here? What caused this?
When you calculate Service Plan with ISTA, what does it say you need to do to fix it?
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      09-22-2022, 07:46 PM   #112
HerbT
Drives: E92
Internal fault.
Fault Impact
i used the bimmercode app to activate and deactivate the auto start features. then i also coded the the digital speed display on the cluster. right after the coding the cluster turned off then turned on with 999999 red dot. on the service plan its asking to replace the cluster
      09-22-2022, 11:26 PM   #113
shawnsheridan
It have never seen anything like this where Coding would corrupt Mileage. I have no idea what fix is.
      09-23-2022, 04:12 AM   #114
Siki78
Siki78's Avatar
136
Drives: F30,G30
Do you have Mileage blocker install on car?
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
