07-19-2020, 11:19 PM | #1 |
Rep 46
Pure Stage 2 or Stage 1 Turbo for F32
Hey guys!
Probably a stupid question but if you're willing to help me that's awesome. 1) What kind of power increase can you experience on an N55 setup with the PS2 setup on pump gas 91 octane assuming FBO already on the car, gapped NGK plugs and upgraded coils w/ a JB4? Is this pointless to do/consider? 2) What makes up for such a huge cost difference between the PS1 and PS2 turbo kits for N55? Is it truly worth the price difference and if so, why? |
07-20-2020, 08:59 AM | #2 |
Rep 1,934
1) search
2) search. The difference is that ps1 goes in your stock manifold. Ps2 comes with a manifold because they port the stock manifold on the inside, and cold side compressor is larger. Ps1 is minimally larger than an EWG Turbo. Search
07-20-2020, 09:02 AM | #3 | |
Rep 46
Yes I am searching amidst asking... Looks like you still realize major power gains with the PS2 setup even on pump gas. May be good to explore a better fuel pump setup from what I'm seeing too. |
07-20-2020, 09:10 AM | #4 |
Rep 191,021
Stage 1 is more of a stock replacement , if you want more power you need the stage 2.
Power depends on the supporting mods, fueling and how aggressive your cutom map is. Its best to discuss power with your tuner direct
07-20-2020, 09:12 AM | #5 |
Rep 46
Perfect! Thanks for the info! I'm assuming there's no harm aside from decreased power by running pump gas?
07-20-2020, 10:26 AM | #6 |
Rep 191,021
Correct
07-20-2020, 12:15 PM | #7 | |
Rep 7,613
If you are serious about going upgraded turbo i suggest you spend 5-10 hours researching, start with pure and their vendor info, then the forums and various threads on PS2 and other turbo upgrades on the market, then come back with specific questions. Right now you are basically taking other people to do your homework for you. In the meantime you also need to fully understand the fuel system on F3x platform and its limitations, and what other mods you might want/need besides "FBO". |
07-20-2020, 01:06 PM | #8 | |
Rep 46
I have inquired with Pure Turbos directly and am doing my due diligence in collecting the information and research I'm asking about amidst my also very busy life/schedule. So apologies to interrupt your day as no one asked for you to spend your precious time responding here in the manner you chose to do so in. That being said - Yes it seems that the stage 1 setup is simply an slightly larger version of the stock turbo setup and that if I really want to leverage larger power gains I should pursue the PS2 setup with some accompanying tunes, possible fuel components and still obtain good power on pump gas without majorly sacrificing longevity. |
07-20-2020, 01:21 PM | #9 | |
Rep 7,613
Back to the 'build', at a fundamental level you should consider the turbo upgrade in the context of other mods you want to make to the car, the fuel you have available (e85?), your budget, goals (street? 1/4 mile? autocross? track day?), etc. If you lay all of that out people will be able to provide more specific advice as to what setup will fit the bill. There are options other than PS2 out there, and other aspects such as fuel available might influence whether you want to go upgrade HPFP or meth, for example. |
07-20-2020, 01:31 PM | #10 |
Rep 46
I appreciate the further explanation and can understand that, I have just started diggin and have been searching on the forums and "other posts on bimmerpost/bimmerforums ect" to help paint the clearest picture of what folks are doing and experiencing with the PS2 pursuits.
I'll be gathering more info as I go and am aiming to have a fairly reliable, high 400's hp/tq setup on the ohlins r&t I have for occasional autox and possibly future track days as they open up Gem State Raceway here in Idaho. My old N54 was a different experience so learning as I go with the best practices for the N55 setup. Right now I have the following; - 6.5 FMIC - CP/Catted DP - Muffler delete exhuast - JB4 tuner - No backend tune yet - 6spd manual - Ohlins R&T w/ Millway CP's Regarding fuel - We have E85 but I've read a lot about it burning components much faster than on 91/93 but I could be misunderstanding it too |
07-20-2020, 01:45 PM | #11 | |
Rep 7,613
Next step will be determine what fuel you want to run. I have no idea what you mean by 'burning components' but E85 is not a dangerous fuel to run... its typically the preferred fuel in the forced induction aftermarket community for many reasons, one of which being high octane. For our platform running a mix (say, E30-50) is much more common than straight E85 because we are DI, but the idea is the same. If you have E85 available i would highly consider that route, in which case you would need a upgraded HPFP. If you dont go E85 and only have 91 you are most likely going to want to run meth, which adds additional system complexity, although you already have the JB4 to control it. You might be able to get away with stock HPFP on pump gas and mid 400s whp/tq numbers, but pushing to high 400s even with meth is beyond stock HPFP capabilities. So, if you are going to upgrade the HPFP anyways, might as well run a Emix and a custom tune, in which case you can eliminate the JB4 completely. Aside from that just consider other mods you might want to do with the turbo swap - DV (GFB or turbospart), TIC pipe, and definitely a turbo inlet (I recommend MST). |
07-31-2020, 02:36 PM | #12 |
M340i
394
Rep 974
Drives: BMW M340i
So what is the cost of PS2 installed 4k? And then another 2k for a fuel pump. Will it even make 500hp?
Seems better to just start with a different platform. |
07-31-2020, 04:08 PM | #13 | |
Rep 7,613
I don't think its unreasonable to want to go to 500hp on this platform, but that's around the upper limit i personally would want to push this car/platform to. If you were chasing say, 700+, then yeah, get a different car to start or plan to build your motor and/or break parts. But yes, PS2 with supporting mods and tune is proved to make low 500s whp without being on the edge of reliability. People run it for tens of thousands of miles. Yes, you are doing to spend thousands of dollars on parts to go from stock to 500whp, but the total price including the car is not necessarily significantly higher than other platforms when you account for the fact that you still have a blend of performance and luxury. If you just want a cheap, fast straight line car and don't care about that, then you probably shouldn't have bought a BMW to begin with, lol. |
imperfectluck428.00 |
08-13-2020, 06:40 PM | #14 |
Rep 46
Thanks for the insight and yeah I got the car pretty inexpensively, I do like how it's fairly "under the radar" as I attend client meetings it's not an obnoxious "look at my fast car" and I came across the ohlins r&t coils for cheap too so the car is pretty fun just would be interesting to have it up to that 500hp mark for my own entertainment haha...
That being said from what I've found these are the parts I'll need (not including the hpfps) to get where I want to be? Does that look right to you guys? |
08-13-2020, 06:55 PM | #15 | |
Rep 7,613
Not sure what DV it comes with, but i would consider turbosmart in addition to GFB. I would also consider the MST v2 inlet over the pure. |
08-13-2020, 09:07 PM | #16 |
Rep 2,361
You will not max out your fuel pump on 91AKI with PS2. Wast of money.
(A Dane in China) |
08-14-2020, 01:50 PM | #17 |
Rep 46
08-16-2020, 09:04 PM | #18 |
Rep 2,361
You will not run enough boost on 91 to max out stock HPFP. Get the PS2 first.
(A Dane in China) |
f32, fbo, n55, pure turbo, purse stage 2 |
