BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > if my cat goes out, would it mean that it's now catlessDP?
      05-23-2020, 03:22 AM   #1
ty666
ty666's Avatar
Drives: BMW 435xi
I have a fabspeed high flow DP on my N55 witha stage 2 BM3 aggressive, i recently increases the burble tune to the max setting and have been doing a lot of downshifting, pops and bangs, after heavy acceleration and downshifts, i smell a burning smell (not oil) and today i got an engine light. I haven't scanned it yet, but I'm assuming my high flow cat is dying. I don't really care much about it anymore as emissions tests are no longer required where I live.
Question is if my high flow dp goes out, does that mean that it's catless now? is there any disadvantage for having a damaged catted dp other than the check engine light?
Dinan Stage2 | Fabspeed High Flow DP | Dinan Carbn Air Intake | Remus Exhaust | H&R Sport Springs | 19" Savini Wheels | Continental ExtremeContact Sport Plus | Rear Diffusr | M4 Carbn Mirror Caps | Smoked Sequential Mirror Signls | Lip Spoiler | **PREVIOUS VEHICLE: 2013 BMW F30**
**INSTAGRAM: aphotic_f32 **
      05-23-2020, 03:48 AM   #2
VictorF32
VictorNM
Drives: BMW 2016 435i Msport
I have a 435i and have had a VRSF Catless down pipe for 6 months ZERO issues keeping the MHD catted/oem box unchecked and hiding the cel. Don't quote me but maybe the backfiring or burble tune is literally melting the honeycomb (filter) inside the cat? And pieces of the honeycomb or the filter are coming out the back little by little because of increased heat and pressure from the tune? I've seen a video of a 3 series revving and pieces of the cat flying out of the exhaust. Running pump gas or e85 maybe the issue?
Just trying to help, hope your able to diagnose and fix that notorious Check engine light, it is a daily struggle.
      05-23-2020, 04:30 AM   #3
ty666
ty666's Avatar
Drives: BMW 435xi
Thanks, but i couldn't watch that video till the end, wtf is that guy doing? I'm sure that car is stolen. lol
Poochie4674.00
      05-23-2020, 06:20 AM   #4
Logicoeur
Logicoeur's Avatar
416
Drives: F30 335i xDrive
Check the CEL before hypothesizing it's the cat.
F30 335iX | Remus Axleback | 18X9 ET32 19lb TR-1 255/40/18 | MPerf LSD
      05-23-2020, 12:53 PM   #5
alohasurftoad
Drives: 428i gran coupe
it's possible that the excessive "snap, crackle, pop" from max burble tune damaged your catalyst. fabspeed uses metal catalysts which are stronger but you can kill anything with enough effort. if it is damaged you aren't really catless until the catalyst has been burned out or completely removed. if it is partially there the flow is likely worsened.
if it's partially there you need to remove the rest of it. if it's not damaged i suggest you sell it and get a catless downpipe. it's what you should have done prior to going max burble. you can get decent money for a used fabspeed if the catalyst is good, of course.
here is a thread about a melted catalyst...
https://f30.bimmerpost.com/forums/sh...atalyst+melted
      05-23-2020, 03:40 PM   #6
Elvisfan
Drives: 2018 430ix convertible MGM
Hello,I have a question. Would someone on this forum kindly explain why so many BMW owners apparently donít care about the air they breath,but really care about how much noise their car makes? I really donít understand it. Especially not caring about the air.
Thanks.
      05-24-2020, 03:18 AM   #7
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
2111
Drives: 340 6MT
      05-24-2020, 12:25 PM   #8
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
Thanks.
I got stock dp. I care about the planet, I recycle and keep my garbage off the street. Just leave my car out of it if I ever go catless.
