11-11-2018, 09:42 AM | #111 |
B58 Power
462
Rep 604
Drives: 05/2022 M340i xDrive Touring
F15 with adaptive LED headlights
CAFD provided by IonyM Function sets already in use (see LmmA and LmmB) 01 02 03 04 05 06 07 08 0A (10) 0B (11) 0C (12) 0D (13) 0E (14) 0F (15) 10 (16) 11 (17) 12 (18) Not in use 13 (19) Using LmmIdx19 (in 3005 -> LmmX) for the new mapping. LmmIdx19_Intensity New: 2E Old: 00 LmmIdx19_TimeOn New: 05 Old: 00 LmmIdx19_TimeOff New: 05 Old: 00 LmmIdx19_Priority New: 01 Old: 0F LmmIdx19_RampTime no change LmmIdx19_ErrorImpact no change LmmIdx19_Active no change Changing the mappings in BLINKEN_IDx (in 3004 -> LmmB) to use LmmIdx19 for the DRL. OLD: 01 01 01 01 01 01 01 0F 01 11 NEW: 01 01 13 01 01 01 01 0F 01 11 F15 mappings (10 Bits) 1 Lowbeam3 2 Highbeam 3 DRL 4 not in use 5 Lowbeam1 6 Lowbeam2 7 Highbeam1 8 Fraz1 9 CL1/ML1 10 AZL1 Just contact me if you need help to enable this feature in other models! kind regards Michael |
stu14t450.50 |
11-12-2018, 02:09 AM | #112 | |
Rep 1,201
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
04-02-2019, 07:30 AM | #113 |
Rep 22
Hi all!
You`re all doing a great work in my opinion! Is there any way to switch off DRLs in parking light mode and use fog-lights only in parking lights mode? P.s. standart LED on EU F30. Thanks! |
08-02-2019, 12:55 PM | #114 | |
Rep 1
Hi,
First of all thank you for a great write up. It works but it has an issue. If you will disable DRL in iDRIVE and will use blinker after that, it will also trigger DRL. Same thing will happen if you will use hazard lights while ignition switched off. It can be solved by setting LmmIdx10_Intensity to 00, but it creates another problem - it turns of DRL completely while using blinker or hazard lights. That also applies when light switch is set to "parking lights". Any ideas how to solve it? Please Quote:
09-04-2019, 07:49 AM | #115 | |
Rep 276
Does 1 of these also work for an f34? |
09-05-2019, 03:20 PM | #116 |
Rep 2,302
09-06-2019, 02:32 AM | #117 | |
Rep 276
Thats why i asked if its the sme codings, cause headlights are totally different connected |
09-06-2019, 04:19 AM | #118 |
Rep 276
09-10-2019, 08:51 AM | #119 |
Rep 1,201
You will have to go back to my original post and work out the mappings of all the 10 bits then see what the settings values are for those. Although the numbers will be different it's only because the setup is different, the principal should be the same
09-14-2019, 01:55 PM | #120 |
Rep 2,302
In newer CAFD (e.g. CAFD_000024C3_010_080_001) the value BLINKEN_PO_Idx doesn't exist anymore so it can't be changed.
Does someone know a solution for this except to change to an older CAFD? |
09-14-2019, 03:01 PM | #121 |
Rep 1,201
Probably only applicable to US cars as (see post #20) BLINKEN_PO is for vehicles with an LED turn signal and accent light section of the position light sharing a common light output area. It may not be necessary to change that or it may only be in US cars.
09-14-2019, 03:09 PM | #122 | |
Rep 2,302
I coded this about one year ago and after a software update i didn't code it again. Tomorrow i want to do it again. I will try it without these values. |
09-16-2019, 03:58 AM | #123 | |
Rep 2,302
It works without this value. |
stu14t450.50 |
09-19-2019, 11:21 AM | #125 |
Rep 1,201
Unfortunately, no. Only on LCI models fitted with FLE modules (and some others with older LED adaptive systems)
12-09-2019, 02:31 PM | #126 |
Rep 18
Hello! need your help! I activated the turn signals to the floor through bimmercode on LED headlights, but they have a flicker, maybe I did something wrong and you would suggest how to do it through esys, I really want everything to work, since I really like it. I attach the video.
03-28-2020, 04:42 PM | #127 | |
Rep 30
I also set Lmmldx10_RampType to 00 and Lmmdx10_TimeOff to 03 to let the DRL's fade back up in 0,3 sec. Last edited by bringmywallet; 03-28-2020 at 04:50 PM.. |
stu14t450.50 |
04-20-2020, 05:33 PM | #128 | |
Rep 2
Thank you! |
05-31-2020, 06:37 AM | #129 | |
B58 Power
462
Rep 604
I also had to change the POLI#_Idx values to have the dimming in every other light function instead of open/closing. I was trying to find a solution with Blinken_Var and Blinken_Var_Connection. It´s possible to control when Blinken_Idx and when Blinken_Var_Idx is used through Blinken_Var_Connection. I couldn´t find a solution yet but maybe someone has more ideas than me. Blinken_Var_Connection has 7 Bytes to control what Blinken function is used. 0 = Blinken_Idx, 1 = Blinken_Var_Idx My F30 (11/2017) has the following value: 00, 00, 00, 00, 38, 00, 00 The description is a bit longer and identical for all 7 Bytes: Code:
Kommentar=Byte 1: LM01 Wertebereich: 0.. 255 Verbindung zwischen jede Lichtfunktion und die Funktion BLINKEN_VAR. Wenn das Bit einer Funktion aktiv ist, wird das Funktion BLINKER_VAR statt BLINKEN benutzt. Byte Zuordnung (Value jede BIT 0: BLINKER wird verbendet. 1: BLINKEN_VAR wird verbendet): Byte - Bitmaske - Lichtfunktion 200 - 00000001b - 01) Abblendlicht LV1 - Schlechtwetter C1 200 - 00000010b - 02) Abblendlicht LV2 - Schlechtwetter C2 200 - 00000100b - 03) Abblendlicht LV3 - Stadt V 200 - 00001000b - 04) Abblendlicht LV4 - SAE 200 - 00010000b - 05) Abblendlicht LV5 - H10 Landstrasse C 200 - 00100000b - 06) Abblendlicht LV6 - H8 Autobahn E3 200 - 01000000b - 07) Abblendlicht LV7 - H6 Autobahn E2 200 - 10000000b - 08) Abblendlicht LV8 - H5 Autobahn E1 201 - 00000001b - 09) Abblendlicht LV9 - H4 Autobahn E 201 - 00000010b - 10) Abblendlicht LV10 - H2 201 - 00000100b - 11) Abblendlicht LV11 - H0 201 - 00001000b - 12) Abblendlicht LV12 - H plus 2 201 - 00010000b - 13) Abblendlicht LV13 - H plus 4 201 - 00100000b - 14) Abblendlicht LV14 - Blendfreies Fernlicht 201 - 01000000b - 15) Abblendlicht LV15a - Fernlicht Modus 1a 201 - 10000000b - 16) Abblendlicht LV15b - Fernlicht Modus 1b 202 - 00000001b - 17) Abblendlicht LV16a - Fernlicht Modus 2a 202 - 00000010b - 18) Abblendlicht LV16b - Fernlicht Modus 2b 202 - 00000100b - 19) Abblendlicht LV17a - Fernlicht Modus 3a 202 - 00001000b - 20) Abblendlicht LV17b - Fernlicht Modus 3b 202 - 00010000b - 21) Abblendlicht LV18 - Blendfreies Fernlicht 1 202 - 00100000b - 22) Abblendlicht LV19 - Blendfreies Fernlicht 2 202 - 01000000b - 23) Abblendlicht LV20a - Blendfreies Fernlicht 3a 202 - 10000000b - 24) Abblendlicht LV20b - Blendfreies Fernlicht 3b 203 - 00000001b - 25) Abblendlicht LV21 - Blendfreies Fernlicht 4 203 - 00000010b - 26) Abblendlicht LV22 - Blendfreies Fernlicht 5 203 - 00000100b - 27) Abblendlicht LV23 - Blendfreies Fernlicht 6 203 - 00001000b - 28) Abblendlicht LV24 - Blendfreies Fernlicht 7 203 - 00010000b - 29) Abblendlicht LV25 - Blendfreies Fernlicht 8 203 - 00100000b - 30) Abblendlicht LV26 - Blendfreies Fernlicht 9 203 - 01000000b - 31) Abblendlicht LV27 - Blendfreies Fernlicht 10 203 - 10000000b - 32) Abblendlicht LV28 - Blendfreies Fernlicht 11 204 - 00000001b - 33) Abblendlicht LV29 - Blendfreies Fernlicht 12 204 - 00000010b - 34) Abblendlicht LV30 - Blendfreies Fernlicht 13 204 - 00000100b - 35) Tagfahrlicht 204 - 00001000b - 36) Standlicht Modus 1 204 - 00010000b - 37) Standlicht Modus 2 204 - 00100000b - 38) Standlicht Modus 3 204 - 01000000b - 39) Parklicht 204 - 10000000b - 40) Abbiegelicht 205 - 00000001b - 41) Welcome Light Modus 1 205 - 00000010b - 42) Welcome Light Modus 2 205 - 00000100b - 43) Welcome Light Modus 3 205 - 00001000b - 44) Welcome Light Modus 4 205 - 00010000b - 45) Follow Me Home 205 - 00100000b - 46) Remote Light 205 - 01000000b - 47) Fernlichtblinken 205 - 10000000b - 48) DWA-Blinken 206 - 00000001b - 49) Panik-Modus 206 - 00000010b - 50) Überfallalarm 206 - 00001000b - 52) ECO+ Dimmung 1 206 - 00010000b - 53) ECO+ Dimmung 2 206 - 00100000b - 54) ECO+ Dimmung 3 |
06-06-2020, 11:12 AM | #131 |
B58 Power
462
Rep 604
Only for LED headlights with TMS or FLE modules.
12-26-2020, 05:27 PM | #132 |
Rep 98
I have a 320 F30 2017 non-adaptive. I would like to leave the blinker always on. USA style. It's possible?
With what was explained here in the topic I did not understand how to do for this function. To look like the one in the photo: View post on imgur.com
