04-28-2019, 03:37 AM | #1 |
Rep 10
Park Assist Error
Hey Guys
Recently got the the following error on my 2014 428i convertible Parking assistance - No parking assistance, please park unaided. Have the problem checked by your service partner. After trying to work out what happened, I realised someone has hit the back of my car (near the right reverse sensor) and even though the sensor looks okay, I have a feeling that this may be the reason. Does anyone know where the PDC module is located on a 428i? I'm thinking of looking into that before I remove the whole back bumper to check the sensors. Also, any tips would be appreciated. Thanks |
04-28-2019, 06:01 AM | #2 | |
Rep 552
I bumped my car and the parking sensor fell out. It's only held on using double side tape. The PDC is most likely in the boot. I would just change the sensor first. |
RG428i1.50 |
04-28-2019, 06:09 AM | #3 | ||
Rep 10
Are you able to confirm that I can access the sensors from the bottom of the car on a 428i convertible? I had a quick look but not sure what I'd need to remove to gain access |
04-28-2019, 06:24 AM | #4 | |
Rep 552
The sensor itself is clipped into to a painted plastic surround, this is stuck to the car using double sided tape. I would try leave that on the bumper as it's orientated to match the contour of the bumper. Not sure if the sensor is push clicked in or twist clicked in. |
mina009.00 |
04-28-2019, 06:27 AM | #5 | ||
Rep 10
I'll have another look later on and see how I go. |
04-29-2019, 04:13 AM | #6 | |||
Rep 10
Managed to take the bottom of the bumper off and noticed the the wires connecting to the right reverse sensor had been cut clean. Looks like something must have got in there and chewed through the wires. Anyways, I connected the wires again and good as knew. Thanks |
04-29-2019, 05:02 AM | #7 | |
Rep 552
06-04-2020, 01:45 PM | #8 |
Rep 2
Parking assistance warning
Hello guys,
My parking sensors are not working, so every time i shift to reverse the warning jumps. I cant fix the sensors now, so I want this warning to be disappeared. Can i code it using bimmercode? any suggestions? thank you. |
06-02-2023, 03:54 PM | #10 |
Rep 13
Drives: BMW F32 428i 2013
kingmonkey8 did u ever find this out? Got a 2013 428i coupe and this has just started to happen recently every now and again it pops up saying error
