04-09-2020, 11:20 AM | #23 | |
Rep 495
With the advent of ultra-low sulphur fuel, ever higher performance oil, and better engineering there's absolutely no reason you can't run 10,000mi on a stock car. If you're tuned, that's another story because usually you have to compensate for higher fuel dilution. RE: Original thread No reason to use techron for fuel cleaner as long as you're using high octane, top tier fuel like Shell, Exxon, etc. |
Blubaron791431.50 |
04-09-2020, 11:25 AM | #24 |
Rep 3,203
04-09-2020, 01:17 PM | #25 | |
Rep 923
I'm OCD about taking care of the machines in my life and usually defer to the owners' manuals. BMW engineers built a great car and have a lot of experience and data in how to maintain it. Anyway, I have my LL-14 and it'll go in soon, then come out around 10k miles later. I'm not drag racing...just out of the NJ tollbooths a little.
04-09-2020, 02:59 PM | #26 |
Rep 16,079
They still have toll booths? I haven't been there for a few years, but everywhere from NH to NYC is pretty much EZ Pass fly on through. Do they let you pump your own gas yet?
BTW, I remember when changing your oil around 5,000 miles was the norm, when it was 49 cents a quart mineral oil. I haven't used that schedule since going to Mobil 1 in 1974. |
04-09-2020, 03:00 PM | #27 | |
Rep 1,597
evilchargerfan269.00 |
04-09-2020, 04:59 PM | #28 | |
Rep 923
Yes, NJ has tollbooths still...they are EZ Pass, but I'll roll through slowly in 2nd and then get up to the speed limit as fast as I can--usually just 55, so the exciting acceleration is over in a couple of secs. ...and no, we can't pump our own gas still. Something to do with our advanced knowledge of people and their ways, I think.
Jake From State Farm54.00 |
04-09-2020, 05:07 PM | #29 |
Rep 1,118
Drives: 2015 BMW 435i Xdrive MSport
Honestly, I would run Shell V-Power Nitro+, that's what I use in my 435i and it honestly gives me all 320hp with absolutely no knock and keeps the engine clean and protected. You could also get walnut blasting done every 30,000 miles too if you so choose. Also, you could get a catch can.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
04-10-2020, 08:04 AM | #30 |
Rep 16,079
I guess that's better than tossing coins in a bin. Up here in the sticks we've had high speed EZ pass lanes for years. Some smart guy figured out that if you don't have to slow down to pay a toll you don't realize that you're paying a toll, so you're far less likely to take to shunpiking.
04-10-2020, 10:30 AM | #31 |
Rep 152
Terms like Top Tier Gas are just marketing. The difference between an Arco and a Chevron is the additives. Chevron is going to have more detergents and what not but the gas itself is the same.
Octane is a measure of the fuel's resistance to self detonate. The higher the octane, the higher the pressure it can withstand before it lights itself. Higher compression and turbo cars need the higher octane to prevent knock and engine damage. Higher octane is not necessarily higher quality. Theres nothing wrong with tossing in a bottle of techron every now and again. Its basically a concentrated bottle of the stuff they use in their gas. Like folks mentioned, its not going to do much for the valves in our cars but it can help prevent build up elsewhere in the fuel system. It can help keep the cylinder walls cleaner too. My personal favorite is SeaFoam fuel treatment. |
04-10-2020, 11:25 AM | #32 | |
Rep 495
You can literally run an F1 car on Shell 93 if you wanted, due to the formulation. This video shows there's quite a difference in Walmart, BP, Shell, and Exxon fuel quality. |
04-10-2020, 11:51 AM | #33 | |
Rep 3,752
When an order from a gas station is received ie shell, Mobil, arco, 76, Texaco and etc. A truck fill up the gas from the same source ie 87, 89, 91, 93 oct, then they proceed to a designated detergent depot for what station gas they are delivering. So if the truck going to deliver to a Chevron station, the truck get gas from a combine tank then go mixed it with a Chevron detergent. |
04-10-2020, 03:08 PM | #34 | |
Rep 152
Going over your car's octane rating won't do a whole lot since the car is tuned for a given octane. It doesn't know to change the tuning to take advantage of it. Going lower than your car's octane rating can have a negative effect as the engine senses detonation and detunes the car. I would rather see a straight comparison of brands at the same octane rating. |
Billfitz8243.00 |
04-10-2020, 04:34 PM | #35 |
Rep 16,079
I doubt that comparison has much validity in the US, where you're almost always using E90. My assumption is that they don't have the ethanol lobby in Parliament that we have in Congress forcing it down our filler pipes.
04-10-2020, 05:08 PM | #36 |
poopycat
266
Rep 791
04-10-2020, 05:10 PM | #37 | |
Rep 3,752
deviantspeed266.00 |
04-10-2020, 08:55 PM | #38 | ||
Rep 495
There is a measurable difference in the performance of each brand of fuel, as that video showed. 3-5hp delta between BP and Shell for example. Euro spec fuel and American is essentially identical in 2020, as we now have similar sulphur requirements as them. 87 R+A/2 = 95 RON 93 R+A/2 = 98 RON Quote:
C&D showed a 20hp gain in an F-150 between 87 and 93, whereas Ford says to use 87. IDK what to tell you man. |
04-10-2020, 09:24 PM | #39 | |
Rep 152
Quality however is subjective. The octane in US gas is tightly regulated. 91 at Arco is 91 at Chevron which is 91 at Shell. There is nothing wrong with paying more for the additives in the "premium" brands. Also not going to hurt your engine by using Arco gas on occasion. |
04-10-2020, 09:57 PM | #40 |
Rep 2,653
Recommendation on a catch can for N55 F30?
04-11-2020, 12:22 AM | #41 |
Rep 2,808
Drives: F33 430 and F39 M35i
You want a kit or are you good with making tubes yourself?
Catch can off fleabay is $30? A BMS kit is $199ish and comes with plug and play tubes and adapters with the can. I got the bms kit. Lol |
04-11-2020, 08:24 AM | #42 |
Rep 16,079
04-12-2020, 11:18 PM | #43 | |
Rep 495
Brand does matter, to an extent. |
