08-27-2023, 07:24 PM | #1 |
Rep 26
is a upgraded turbo outlet pipe needed if im getting a upgraded charge pipe
As the title states, im going to upgrade my charge pipe due to it developing a slight boost leak barely before 24 hours tuned lol. as stated im going to upgrade my intercooler as well but while looking at the option (in the photo) it shows an option for a turbo outlet pipe, I was wondering is a turbo outlet pipe needed or not?
08-28-2023, 10:15 AM | #2 |
1318
Rep 3,593
Not needed
2017 m240i xDrive 10.67@132.32mph w/bm3
08-28-2023, 02:36 PM | #3 |
Rep 7,733
Not needed, but if you are ever going to do the TIC pipe, the labor overlaps with IC, so now would be the time to do it.
08-29-2023, 12:02 PM | #4 | |
Rep 5,801
Check out Extreme Powerhouse. https://x-ph.com/?gclid=CjwKCAjwrran...hoC_3UQAvD_BwE |
alohasurftoad3319.50 |
08-29-2023, 12:33 PM | #5 | |
Rep 4,515
might as well do the rest while everything is apart. i'd get the turbo inlet/intake pipe and the turbosmart diverter valve done as well. |
08-29-2023, 12:49 PM | #6 | |
Rep 4,976
08-29-2023, 01:02 PM | #7 |
Rep 5,801
Yes, my MAD Race Intercooler was installed. A quick log that I did looked promising. But then I had stock EKP overheating issues that I just solved with a Stage2 EKPM3 from ET3 Design.
Just filled up with E85 minutes ago. Expecting super hot weather in the 90’s next week. I want to collect some logs with high ambient temperature on E85 with Bootmod3 FlexFuel MultiMap Stage2+ tune from 1st through 5th gears. That’s about the most stress my car with a stock N55 EWG turbo can generate for an intercooler. |
AmuroRay2851.50 |
08-29-2023, 02:08 PM | #8 | |
Rep 4,976
johnung4939.50 |
08-29-2023, 02:41 PM | #10 |
Car Hypochondriac
372
Rep 914
Do you have this exact combo? I have FTP pipes already and am thinking about swapping from my VRSF to the MAD race... want to confirm no fitment issues with this combo.
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
08-29-2023, 02:54 PM | #11 |
Rep 4,976
It's also called the Boost pipe and turbo to intercooler pipe - it fits on the other side of the intercooler.
08-29-2023, 03:02 PM | #13 | |
Rep 7,733
1. Bare minimum would be do IC+CP combo. 1a. The IC+CP you posted isnt very common, and a potentially better/cost effective option to consider is the Mad Race IC and FTP CP. 2. If you want to "do it while you are in there", you can consider installing the TIC (aka boost pipe aka turbo to intercooler pipe) at the same time. FTP also makes one of these i believe. 3. Similarly, if you have the TIC out, its easier to install a turbo inlet and/or DV upgrade. Personally, i would highly recommend a turbo inlet no matter what else you do - get the CTS or MST v2 (they are identical designs). I am still stock DV, but if you are going to do a DV, it requires removing the turbo inlet so once again labor overlap. You can see how this easily snowballs, so just decide how far you want to go with your budget. |
08-29-2023, 04:05 PM | #14 |
Car Hypochondriac
372
Rep 914
08-29-2023, 04:12 PM | #16 |
Rep 4,976
Correct
08-29-2023, 05:43 PM | #17 |
Rep 5,801
Eschmacher371.50 |
08-29-2023, 07:33 PM | #18 | |
Rep 7,733
177 mph pull with 5'' HD - note IAT rise: https://datazap.me/u/thejeremyman9/2...ata=4-10-21-22 0-150 mph with race - IATs end where they started: https://datazap.me/u/thejeremyman9/d...0&data=4-10-17 canyon driving with race: https://datazap.me/u/thejeremyman9/r...data=2-4-10-17 |
