| 10-24-2025, 02:38 AM | #5105 |
![]() 711
Rep 1,656
One year is not enough, if you're constantly running lean that's not healthy.
2018 RWD 340i 8AT | M Sport | Catless MPPSK | TU HPFP | Stock Turbo
Tunes: Self Tuned via MHD | Fuel: E50/92RON/87OCT Web APP: https://true-acceleration.app/ |
| 10-24-2025, 02:53 AM | #5106 | |
Rep 17
So, i will try to find what happen during cold weather and cold engine to have this CEL. When i'm checking data logging, i understand that no fuel pressure crash but as LFTF and STFT are quite high, it could be possible that i'm on edge of fuel pressure in this custom tune. I will try to check with my tuner Thanks for your help. |
| 10-24-2025, 09:52 AM | #5107 | |
Rep 2
What do you see needs work? |
| 10-24-2025, 11:52 AM | #5108 |
![]() 711
Rep 1,656
For a start, boost target vs Actual totally messed up and STFT way out of healthy range:
https://datazap.me/u/1sloevo/9280rev...ata=4-19-21-34
| 10-27-2025, 01:02 AM | #5109 |
Rep 25
https://datazap.me/u/hpzn/6874-v15?l...=3-15-17-48-49
Do y'all think I'm running out of pump or injector? |
| 11-07-2025, 06:27 AM | #5110 |
Rep 2
Hi everyone
I would like you to check my logs and let me know what do you think. The car: 540i gen 1 TU HPFP Downpipe with 200c Cat MHD stage 2+ 93 Oct I plan to get XHP ASAP, so I have the MHD map with the option to run without it at the moment. -Are the timing numbers ok or too low? Boost? -Are the load figures normal? -Torque. I know the map lies somehow the DME about the NM, but does it look ok? Any comments will be much appreciated, thanks! https://datazap.me/u/miguelsaiz/nov-...-9-16-19-22-23 |
| 11-07-2025, 09:21 AM | #5111 | |
![]() 711
Rep 1,656
Yeah, looks very good.
| Bookmarks |
| Thread Tools | |
