06-05-2021, 08:19 AM | #1 |
Rep 14
Can anybody tell me the part numbers for these bolts?
Hi, does anybody know the part numbers for these 2 bolts?
mine have started to rust and look horrible its a 2014 f31. thanks in advance Last edited by JayLancs; 06-05-2021 at 10:12 AM.. |
06-05-2021, 09:53 AM | #3 |
Rep 4,653
Have a look on realoem.com they list out everything for your car.
Steve Roberts UK
F82 M4 I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/ |
06-05-2021, 02:28 PM | #4 |
Rep 2,048
If you can do without the car for a day or two then you should be able to get them re-plated by a local company. I'm rebuilding my Impreza at the moment and have had about 10kg of bolts and cleaned and re-plated for about £50. And that's been gold passivate rather than just plain zinc as they are. Might be a lot cheaper than going to BMW. Certainly just four suspension bolts from Subaru would be £50!
06-05-2021, 02:48 PM | #5 |
Rep 187
Drives: 330d f31 msport
mine rusted too , quick go with the sand blaster using glass bead and they're as good as new .
it's the coating that corrodes not the steel !! |
06-06-2021, 03:33 AM | #6 | |
Rep 1,141
I suspect your bare steel bolts will start rusting very soon. |
Ennoch2257.00 |
06-07-2021, 04:45 PM | #7 |
Rep 2,048
Yup, 100%. Steel and iron are the only things that rust. And unfortunately plain zinc isn't totally impervious as it acts as the sacrificial metal. If exposed to salt, or is breached then the idea is it protects the steel but eventually it will rust. This is why Subaru bolts last forever, as they are then subsequently chromate and then gold passivate coated which protects the zinc that's protecting the steel bolts.
