04-15-2021, 08:16 AM | #23 | |
Noob
70
Rep 254
someone posted above that they wiggled around the wifi adapter in the OBDII port so instead of pushing the wifi agent into the port firmly I gently put it in so that it wasnt too snug, connected no problem and flashed back to the e20 map successfully. as always jeremy thanks for the help, will probably buy a cable for the future just in case this happens again.
FBO, MHD Stage 2+ E20, Xhp Stage 3
06-03-2021, 10:51 PM | #24 |
Rep 124
Drives: 2020 M340i xDrive
Rehashing an old thread, I’m having issues with mine
It connects to the adapter (iOS) but doesn’t connect to the car? I’ll try the looser connection instead and see |
08-14-2021, 09:50 AM | #25 | |
Rep 2
I have a huge feeling this sudden intermittent wifi connection is related to iOS major updates. My theory is that iOS changed something with how it handles Wifi in the back-end, and suspect the OS is timing out wifi connection when it doesn't detect an internet connection after some time. Currently on iOS v14.7.1. Has anyone tried flashing on iOS with the iPhone charger in? I need to run some more trial and error and report back. |
08-14-2021, 11:02 AM | #26 | |
Rep 873
I use the black MHD WiFi adapter, and it’s working the same (great) running under 14.7.1 with no issues. I’ve even switched over to using it’s WiFi for my BimmerLink/Bimmercode connections since it’s much faster (vs the original Bluetooth OBD adapter I bought for those apps). Last edited by visionaut; 08-14-2021 at 11:25 AM.. Reason: SpEellling… |
08-03-2022, 10:30 AM | #27 |
Rep 2
An other thread resurrection.
I purchased my black adapter months ago but left it lying around. Used it yesterday in someone else's g21 with bimmercode. Worked perfectly. Tried it today in my 2013 F30 and it looses connection a lot. Unuseable. An other vGate adapter works just fine in the car. Did someone else test a dodgy adapter in another car? There’s no way in hell I’ll chiptune my car with this …. |
