BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Photo, Video, Media Gallery, Journals > Lowering F30 (pics with info data)
Studio RSR
      12-10-2019, 04:47 PM   #1
sigtwenty
Drives: 2015 F30 / 2001 E38
So I need to get the wheel gap taken care of.
I'm not new to lowering a car. Done it to all my e38s.
Iirc my e38 the front was 1.9 and 1.6 rear.
I saw two different springs so far. Forget the drops tho.
Can y'all post pics of your lowered but not slammed F30 with the model of springs and drop amount so I can get an idea of what I'll be looking at. Its a daily driver I don't need to be scraping oil pans and dodging speed bumps.
      12-11-2019, 05:05 AM   #2
SuperHamz
Drives: F31 328i M Sport
The most common three options I've seen for springs on this forum for the F3x cars are as follows:
H&R - 20-25mm (0.8"-1") or 35-40mm (1.4"-1.6")
Eibach Pro Kit - 25-30mm (1"-1.1")
Eibach Sportline - 35-40mm (1.4"-1.6")
AC Schnitzer - 20-25mm (0.8"-1")
It's recommended that if you go for 30mm+ drop (greater than 1") than you should change the stock dampers as well.
I'm getting my Eibach's fitted tomorrow, so I've not got a post fitted picture.
      12-11-2019, 08:44 AM   #3
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
AC Schnitzer spring kit with Bilstein B8.
Id be careful about swapping springs alone... thats what a lot of people try (myself included) only to find out the ride becomes very bouncy as the stock dampers wear out. The process will happen quickly as stock dampers are not that high of quality to begin with and certainly not designed for lowering springs.
A side by side comparison of the Bilstein and OEM dampers was embarrassing (compression/rebound/etc).
ali820271.50
      12-11-2019, 10:51 AM   #4
sigtwenty
Thanks for the info. What are the dampers in replacing? The shocks themselves?
      12-11-2019, 11:33 AM   #5
sspade
sspade's Avatar
Drives: F30
Yes, shocks/struts/dampers are basically the same thing (same purpose). They work in conjunction with the springs to suspend the vehicle.
      12-11-2019, 01:05 PM   #6
Nickef30
Nickef30's Avatar
Drives: Bmw 340i
The first one was after and the 2nd one was the before. I used H&R sport. I didn't use supper sport cause I drive it daily and I didn't want to have to worry about scraping on everything. The wheel gap is gone and not that big of a hassle to drive.
VMRWheels2038.00
ali820271.50
mholder23.50
      12-11-2019, 01:08 PM   #7
Nickef30
Nickef30's Avatar
Drives: Bmw 340i
Here's another one so you can see
      12-11-2019, 04:08 PM   #8
blumagic
blumagic's Avatar
309
Drives: 2014 328i xdrive , 2013 SHO
Sometimes i swear i catch air on my H&R sports and stock dampers. 85% of the time its ok and 15% of the time it is horrible. That translates to 85% of the roads I drive on are low speed and/or pretty smooth.
      12-11-2019, 04:46 PM   #9
sigtwenty
Beautiful. HR sport are all the same drop or are there different levels? What is the drop amount.
That's exactly what I'm looking for is to close off some of the wheel gap. Im still running the stock 17s for now until the tires are low.
      12-11-2019, 10:08 PM   #10
Nickef30
Nickef30's Avatar
Drives: Bmw 340i
I would say the front is about 1.5 and read is about 2 inches.
      12-12-2019, 02:35 AM   #11
itachi_d
itachi_d's Avatar
South Africa
208
Drives: F30 330d M-Sport
H&R supersports
Love yourself, Fight for yourself!
Sasuke: F30 330d M Sport
Luffy: F30 328i M Sport
      12-12-2019, 03:17 PM   #12
SuperHamz
Eibach Pro Kit fitted today, fresh so will settle some more over time
      12-16-2019, 06:47 AM   #13
BIFCAIDS
Bird Flu and Cat Aids combined
BIFCAIDS's Avatar
Drives: F30 340i M-Sport+ MPPSK E92 M3
Lowered on H&R Super Sports (35-40mm (1.4"-1.6")
jph980.00
itachi_d207.50
      12-16-2019, 08:23 AM   #14
SuperHamz
That looks really smart - did you change the dampers as well? What's the ride comfort like on the super sports?
      12-17-2019, 02:15 AM   #15
BIFCAIDS
BIFCAIDS's Avatar
Thanks, appreciate the comment.
I didn't change the dampers, however I did change the bump stops for the BM shortened ones. Rides "alright" for a lowered car on springs, little bouncy on some particularly crappy roads (poorly laid - you know what its like here). I avoid pot holes, but if you catch small ones (shallow) it rides them the same as it would standard. Yes, it scuffs the road in some places but it only scuffs the underneath of the front splitter nowhere else.
SuperHamz742.00
      12-17-2019, 02:17 AM   #16
BIFCAIDS
BIFCAIDS's Avatar
Looks great bud
      12-31-2019, 11:08 AM   #17
Elitedesignworks
Drives: 2013 Bmw 335i
Looks Great man. Mine is lowered and im on my 3rd splitter. Certain things cant be avoided here in dallas
      01-07-2020, 11:07 PM   #18
ianbiz
Back in a BMW
ianbiz's Avatar
Drives: 2015 335i Msport
My front spoiler is still in the box for that reason
Ian
      01-09-2020, 08:09 AM   #19
KOWTOWN
Drives: 335i M sport
I wish I went with Super Sports, they're a more even drop and lower. I have AC Schnitzer and sometimes I wonder if I even lowered it
      01-09-2020, 12:58 PM   #20
Surreal Innovations
Drives: 13 335i xdrive;14 Q5 TDI
I'm a fan of the HR SS now, but if I remember right, they didnt have a SS for the xdrive model
Originally Posted by itachi_d View Post
H&R supersports
      01-09-2020, 02:56 PM   #21
Muscle m
Netherlands
22
Drives: BMW 316i
Good topic with lots of inspiration. Still doubting if I go for the H&R Supersports or Eibach Pro-kit springs...
Choices..
      01-09-2020, 07:42 PM   #22
MR_1818
Instagram : mr1818_
MR_1818's Avatar
98
Drives: BMW M2C
TOP
Vossen X Works
Front 9jj (235/35/19)
Rear 10jj (265/30/19)
BOTTOM
OZ Ultraleggera
Front 8jj (235/40/18)
Rear 9jj (265/35/18)
Both picture are running on the same Bilstien B16
Instagram : mr_b48
