BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Andream 10.25 CarPlay Connection issues
      02-01-2024, 04:39 PM   #1
Dawsa101
Dawsa101's Avatar
Drives: F31 M Sport 220D
I have had an Andream headunit which has decided not to connect via Bluetooth . However there is no problem on OEM BMW, it’s only when I try & connect through car play & get a frozen screen & my I phone doesn’t recognize car play (only connection through BMW. This obviously results in no car play, is there an update or factory re-set for this? I’ve accessed the factory settings bet can’t see a factory rest? Is it possible to correct this BimmerCode? Thank you, any assistance appreciated
      02-01-2024, 06:08 PM   #2
YASBBYM3
YASBBYM3's Avatar
Drives: BMW M4 Cs Lamborghini Huracan
The Chinese aftermarket CarPlay add on run instead of the OEM HeadUnit and CID.
Bimmerlink, BimmerCode, Carly, ProTools, eSys or ISTA tools meant to adjust the OEM Equipment have zero ability to work on the aftermarket computer unit as a result. It is not a part of the OEM System.
      02-07-2024, 02:20 PM   #3
Dawsa101
Dawsa101's Avatar
Thanks for reply, are you aware of any upgrade or if I can re-set head unit?
      02-08-2024, 12:53 PM   #4
YASBBYM3
YASBBYM3's Avatar
That’s something you would need to obtain from the manufacturer/distributor/seller.
