02-07-2024, 11:07 AM | #1 |
Rep 8
Slight Oil leak (photo attached)
‘14 435i (n55) 62,500 miles
I went in for an alignment and multi point inspection. My dealership service advisor said I’m leaking oil from the oil pan, shown in the photo. Somehow some way, my Valve cover gasket is not leaking lmao. Crazy at this mileage. But how concerned should I be with that slight oil leak? My car hasn’t ever givven me a “low oil” warning. I just keep oil in the trunk in case. But yea will this turn into something bigger? I plan on having this car for awhile and love it! Thanks |
02-07-2024, 12:16 PM | #2 |
Rep 975
Your best bet would be to clean it and try to find the actual source. That oil could be coming from the OFHG, Oil Cooler, VC or all 3. Gravity can sometimes make it seem like its coming from the oil pan gasket.
Just as a data point, my 435i had been leaking in all 3 places at 58K....
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
02-07-2024, 01:10 PM | #4 | |
Rep 8
02-07-2024, 08:33 PM | #5 |
Rep 229
I have similar leak on the oil pan. The dealer gave me a $3k quote for the oil pan gasket. LOL!
It is my weekend car and at 82k miles. I will wait to summer to check it up.
2011 535i xDrive Black/Black, Michelin PS AS 4
2014 435i RWD Convertible Service Manual: www.newtis.info Part: http://www.realoem.com |
02-08-2024, 06:20 AM | #6 |
Rep 4
My dealer quoted 2300 and my indy will do it for 1800. Watching and waiting as the seep is only visible at a few of the passenger side rear bolts. 2015 with 24700 miles.
02-08-2024, 07:42 AM | #7 |
Rep 16,088
Step 1: Is there a pool of oil underneath where you park your car overnight? If so you've got a major problem. If not you don't. The way to find the source is to thoroughly clean the entire engine then use UV dye, lamp and tinted lenses to find it. https://www.google.com/search?q=uv+d...DuAxofIXs,st:0
02-09-2024, 07:27 AM | #8 |
Rep 975
No, I had caught it early enough to where the biggest issue was burning oil being introduced into the cabin through the vents. However, you can tell that the VC had been leaking for a while and the OFHG and OC was seeping after close inspection.
