08-24-2020, 10:38 PM | #1 |
Rep 2
f32 18x9 +30 square
I have an f32 xdrive. I have a set of Apex SM-10's in 18x9 +30. I know 245/40/18 is the preferred. I'd like to run 255/40/18. Anybody running this setup?
08-26-2020, 06:04 PM | #2 | |
Rep 6,702
-Tom
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
09-02-2020, 03:05 PM | #3 |
Rep 424
curios if the +30 offset will stick out in the back?
//'17 F36 440i Mineral Grey
//MPPSK w/carbon tips //Apex ARC8 255/40/18 //MST intake //AutoTechnik brace |
09-02-2020, 03:27 PM | #4 |
Rep 6,702
The 18x9" ET30 square setup pokes slightly in the front with stock ride height but the rear is very flush. With lowering springs, the front poke typically goes away (depending on what size/type of tires you are running).
For your reference, here is one of our customer's cars running 18x9" ET30 ARC-8s wrapped in 255/40-18 PS4S tires at all four corners. This car is also on Swift lowering springs. Let me know if you have any additional questions! -Geirsen
09-02-2020, 03:31 PM | #5 | |
Rep 424
Im stock M suspension RWD on F36
04-24-2021, 03:20 AM | #6 | |
Rep 8
Can you confirm what other modifications were made other than lowering springs. Looking for the same set up for xdrive. Thanks a lot. |
04-26-2021, 12:10 PM | #7 | |
Rep 6,702
From what I can recall, this particular F30 only has Swift lowering springs. No other suspension/alignment changes to note. -Geirsen
