03-17-2021, 02:00 PM | #1 |
Rep 13
Summer Fitment Setup
Hey everyone,
I cannot seem to get a direct answer anywhere so I want your expertise. I recently bought a 2013 335i xdrive. It has the square 225/45/18 et34 setup. Car is stock other than an MST Intake. I'm looking at getting a second set to run in the summer months but I'm looking to go with 19s. This is a multi part question: Will 19x8.5 +33 Rohana RFX11's on 225/35/19 fit just fine or will I have any rubbing issues? Should I go 225/40/19 instead of 225/35/19? Would I be better off going with 235 instead of 225 for any reason? I really appreciate your feedback |
03-17-2021, 03:01 PM | #4 |
Rep 66
It would probably be more ideal to go with a 235 on an 8.5" rim. The minimum recommended is a 225 tire on the 8.5" but it'll probably stretch the tire a bit.
03-17-2021, 06:01 PM | #5 |
Rep 4,329
OP, you should run 235/40/19(26.4"). fits good on 8.5", 0.2" more sidewall than a 225/40/19, will give a better ride, impact protection and help to fill the some of the unsightly fenderwell gap
03-17-2021, 08:02 PM | #6 |
Rep 611
While it's good solution for square setup with 8.5" wide wheels, for six cylinder (and especially if you consider further engine tune) I'd suggest considering the staggered setup with wider rear rims and 235/265 tires or wider...
alohasurftoad3078.00 |
03-18-2021, 08:11 AM | #7 | |
Rep 849
Drives: BMW 435i
Going square makes the handling more balanced and dials back some of the car's tendency to understeer. For blasting down backroads, autocrossing, or even track time, the added ease of rotation in the car is a real bonus. The only thing I miss when going from my square winter set up back to my OEM staggered set for summer is the rotation. I have far more grip with the summers, but the car isn't as agile. Ideally if you wanted to improve the grip and keep the agility, a wider square set up would be the way to go.
Polo088161610.00 |
03-18-2021, 08:39 AM | #8 | |
Rep 13
03-18-2021, 10:56 AM | #9 |
Rep 13
I appreciate the feedback. Will oem size lugs still work when going from 8.0 to 8.5 wheels?
03-18-2021, 11:01 AM | #10 | |
Rep 4,329
personally, with 6-cyl torque and 8.5" width, i'd deviate even further, to a 255/35/19 square setup for high speed sweepers... https://f30.bimmerpost.com/forums/sh....php?t=1353997 |
matt26213.00 |
03-18-2021, 11:09 AM | #11 | |
Rep 13
03-18-2021, 11:33 AM | #12 |
Rep 4,329
03-18-2021, 11:50 AM | #13 |
A family of bimmers
2747
Rep 7,742
do 235/40/19. Nothing but benefits from it. I run that on my F30 for summer fronts.
03-18-2021, 12:39 PM | #15 |
Rep 4,329
here is a bmw F30 xdrive (340i) with bronze rohana rfx11 19x8.5 +33 with 255/35/19 square on stock suspension. https://www.customwheeloffset.com/wh...ock-suspension
fyi, the 8.5" width on a rfx11 has a flat face, no concavity. i thought i'd let you know now, in case you were expecting more, concavity. i still feel Michelin Pilot Sport 4S in 235/40/19 would be most suitable according to what you wrote for your needs, which is daily commuter. unfortunately they are quite expensive in this size. |
03-18-2021, 07:49 PM | #16 |
Rep 13
That's great info to know and nice to see an actual picture of it. Since we're on the fitment topic, the more and more "options" ive looked at today, the more I may go with something else besides the rfx11. The recommended offset of the f30 is +35-45, but a lot of 19x8.5 that i see are +30. Will this offset also work ok, just with a bit more poke? And will that poke be too much that it doesn't look flush and just looks goofy?
03-18-2021, 08:20 PM | #17 | |
Rep 4,329
03-18-2021, 08:40 PM | #18 |
Rep 13
Yes, 100% planning on going square and likely 235/40/19 from what I've gathered here
03-19-2021, 10:12 AM | #19 |
Rep 495
https://motoiq.com/how-to-properly-s...r-performance/
Posting this article written by an actual race car driver, once again. tl;dr - look on tirerack.com at a tire's actual Tread Width (225/235/245 are not exact measurements), select a tire that is approx 0.5" narrower than your wheel. Have an 8.5" wheel? Select a tire that has a tread width of 8.1". |
03-26-2021, 07:58 PM | #20 |
Rep 1
When I have a fitment question like this I normally call the dealers that sell aftermarket wheels and they help me out with every question I have. I recently bought the RFX13 from unleashedwheels and they were able to help with me with my fitment questions. Hope this helps in some way!
03-30-2021, 03:21 PM | #21 |
Rep 1,236
I run 235/35r19 on 19x8.5 et33 wheels, but I'm lowering my car on the 9th. If I were not, I would have purchased 235/40 for sure.
2023 M2. ZB. Manual.
2024 m235i |
04-01-2021, 12:00 PM | #22 |
Rep 424
Initially I put 235/40 on a 8.5 wheel with et30 and I was rubbing on the front on full lock. If your wheels are above et30 should be no rub but I had to learn the hard way. 235 tire stands taller than the 255/35/19 something to think about also
//'17 F36 440i Mineral Grey
//MPPSK w/carbon tips //Apex ARC8 255/40/18 //MST intake //AutoTechnik brace |
