04-26-2021, 04:24 PM | #1 |
Rep 36
F30 xDrive 19/9.5 square?
I suppose it's too late since I've already bought the wheels and tires.
19" Style 740 Wheels - Square Set Of Four 19x9.5 ET37 5x120 72.6CB. Black/Machine Face And have these tires otw. 255/35R-19 Firestone Firehawk Indy 500 XL I've not been able to get a straight answer anywhere else for the last couple weeks. I'm thinking that I'll prob have some poke in the front, I wasn't anticipating getting some wheels and tires to be such a PITA lol. I get different answers, maybe you guys can help. I'm assuming I'll be in for some more work after these arrive to make it look decent? What am I looking at. |
05-04-2021, 05:52 PM | #2 |
Rep 28
have a look here https://www.bmwstylerims.com/bmw-whe.../#BMW-Series-3 but as far as i can tell the width of your wheel is 1.5 inch bigger than what would fit on the front and even the back would poke out a bit. For the F30 the 19 inch wheels should be 8 inch width on the front and 8.5 on the back. Maybe you could send back the wheels and ask them to swap them?
05-07-2021, 11:15 AM | #3 |
Rep 143
I have the same tire and wheel width setup (different brand tires though) so I'm not sure if it varies LCI or not but I have an LCI 16 f30 and I definitely have some poke on the front. You also should probably run a set of 3mm spacers up front, I did not and when I took my wheels off after a bit to do a different mod I noticed the pain on my strut had been slightly rubbed at and the rubber on the wheel had a slight rub on it around the entire tire. Now this rubbing on the tire was incredibly minor and it's possibly you'd be fine to just let it run minorly but I was worried about it eventually being a problem so figured I'd at least give you the info and you can see what you think is best Next time I get tires I'll be going 245 or 235 up front most likely to fix that and not need spacers. Hope this all helps!
05-07-2021, 01:34 PM | #4 | |
Rep 36
05-07-2021, 03:12 PM | #5 | ||
Rep 143
