BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Removed Front Passenger Seat - Passenger Restraint System Malfunction
      06-16-2024, 11:27 AM   #1
kingsautodetailing
bdking328i
kingsautodetailing's Avatar
Drives: BMW 328i (F30)
2014 BMW  [8.50]
Hi everyone, I have a 2014 328i (F30, N20) and I recently removed the front passenger seat so I could clean under the seat and when I put the seat back in the Passenger Restraint System Malfunction light came on, is there any way to remove this? Did I mess something up? Thanks in advance for your help!
Brian King
      06-16-2024, 12:19 PM   #2
mig2830
Drives: F30 340I
You probably did not disconnect the battery before you removed the seat. You will need to clear the fault memory using ISTA. You were locky that you did not blow the airbag
      06-23-2024, 11:26 AM   #3
kingsautodetailing
bdking328i
2014 BMW  [8.50]
This is true, I don't remember disconnecting the battery beforehand, although that is something I usually always do for fear of the airbag deploying, but I'm sure I didn't this time. I own and operate an auto detailing business and there are times when we have to remove the seats from a client's vehicle, can't believe I forgot to do it on my own car. Thank you for your reply.
      09-02-2024, 03:34 AM   #4
ByAnyMeans
Drives: BMW 320i
320i F30 N20
My situation is identical, what was the process like?
      09-02-2024, 06:16 AM   #5
mrpingu
Norway
599
Drives: 2018 F48 X1 xDrive 18D
Get a fault reader that can clear/reset restraint-system errors.For example ISTA and BimmerLink app can do that
f30, passenger restraint system
