03-31-2021, 11:58 AM | #45 |
Rep 82
Drives: 2012 BMW 328i Luxury Line RWD
Well 6500, but who's counting? Yep, working from home this past year and getting fatter. Mostly runs around the neighborhood to keep the fluids circulating. All the money I saved on gas turned into some new rifles in my safe. LoL
03-31-2021, 12:10 PM | #46 | |
Rep 1,643
My car has now developed a play in the turbo wastegate actuator, which requires an entire turbo assembly replacement for $3500 (not going to do it unless and until the power delivery gets affected; right now I just get an occasional drivetrain malfunction warning, but no power delivery issues). It is also due for pads+rotors and tires in the next 10k miles ($1500 total). So with all these items, the average expense will climb momentarily, but I think it will settle down as these services won't come up again for several years. Other than that, the car is still rock solid.
2020 M550i (G30) | Carbon Black/Black Nappa | DHP | DAP | Executive | Luxury Seating | Park Asst | Ceramic Controls | Front/Rear Heated Seats | 20" 668M wheels
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) |
03-31-2021, 12:31 PM | #47 |
Rep 1,643
Of relevance to this thread, here's my recent Blackstone oil analysis report at 118k miles: https://f30.bimmerpost.com/forums/sh....php?t=1809148
Engine condition is noted as excellent in the report.
03-31-2021, 12:32 PM | #48 |
Rep 82
You are lucky. Since Dec 2017, I averaged approx. $3300 USD per year. Suspension, brakes and a few small repairs (thermostat, oil filter housing gasket, fuel vapour solenoid and new exterior mirror assembly) being the main culprits. Tires and frequent alignments aren't cheap either. I should be good for a while though. No wastegate rattle here (yet).
03-31-2021, 10:17 PM | #49 | |
Rep 562
Drives: 2017 BMW 330i xDrive
Good looking oil report too, it’s not that far off from the one I just got back from Blackstone at 34k. Although your TBN is way better than mine on a 5k interval. I switched to Pennzoil for this change. Last edited by auburnf30x; 03-31-2021 at 10:24 PM.. |
04-01-2021, 09:34 AM | #50 | |
Rep 1,643
09-27-2021, 08:06 PM | #51 | |
M340i
394
Rep 977
Drives: BMW M340i
09-27-2021, 11:07 PM | #52 |
I can haz cheezburger?
6807
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
Glad to see N20’s lasting past 100k miles. Currently sitting at 208k on the engine/198k chassis. Engine replaced at 79k miles due to getting caught in a flash flood and replaced with another n20 with 10k miles more by insurance. I do light maintenance on my own.
09-28-2021, 09:12 AM | #53 |
Rep 1,643
Fully agreed, but I just don't have the aptitude for it. I am wary of dabbling in anything I don't have the aptitude for, or the time to learn it properly, especially when it is something as expensive as a BMW (or any vehicle for that matter). I am pretty busy with my full-time job (for which I have the aptitude ), and thankfully it allows me to afford having someone else maintain my car. I did maintain my own motorcycle for several years, but that's where I draw the line.
09-29-2021, 12:12 PM | #54 |
Rep 234
I'm going to watch this thread for any future updates as I'm genuinely curious how much longer the car will go before major components start giving you trouble, especially if you haven't flushed the critical fluids (trans, diffs, etc.).
I flushed my trans at 68k (ZF recommends a flush at 60k) and the fluid was black as night. I'd hate to see the condition of the fluid and metal content at 120k+. I changed my diff and t-case fluid at the same time. The timing chain issue seems to be consistent with an extended OCI, so I'm also curious what the conditioning and remaining lift of your chain and guides are as well. My car, for comparison, has about 81k currently, and other than $800 to flush all fluids in the car at 68k miles and oil changes every 5k miles, I haven't spent any other money on the car. I've hardly spent any money at all in maintenance and no money on repairs so far.
09-29-2021, 03:39 PM | #55 | |
Rep 1,643
You will start seeing more expenses around the 100k mile mark and soon thereafter. You only quote your expenses for fluids. If you haven't changed things like the plugs, engine/cabin filters, drive belt, done tire rotations, etc., you should. I can keep my expenses lower, but I like to keep my car in tip top shape while avoiding over-maintenance.
09-29-2021, 03:57 PM | #56 | |
Rep 5,092
That $2k includes: $50-$100 x 6 6k-7k miles OCI@dealer $150 spark plugs 60k miles@indy $150 brake fluid@indy $250 brake fluid + coolant special@dealer $30 x 2 BMW cabin filters DIY $10 x 2 BMW wiper blades DIY $5 BMW air filter DIY $750 x 1.5 Driveguards (road hazard replacement) I project this $2k expense repeat every 40k miles. Crossing 100k miles should add $1k for brakes on both axles, $300 drive belt job, $500 for OFHG. As long as TC is good, this gen of N20/N26 appears to be quite reliable. Last edited by bavarianride; 09-29-2021 at 09:57 PM.. |
adhrp1324.00 |
09-29-2021, 04:30 PM | #57 |
Rep 425
Arguably no different in cost with any other auto brand as far as parts go with the exception of possibly the trans fluid that I thought was high
2013 328i M Sport, Estoril Blue, Venetian Beige, Walnut trim, 8AT, Premium, Cold Weather, Lighting, Technology, Navigation, Driver Assistance, HK Sound
09-29-2021, 04:46 PM | #58 | |
Rep 5,092
ZF does update their recommendation to 150000 km(almost 100000 miles) change interval, provided there is no high temp usage:
If prior usage is high temperature and load, or unknown history, then interval can be shortened per ZF. |
09-29-2021, 04:57 PM | #59 |
Rep 425
INteresting! Is that new? All i've read is 60k interval. If that's the case, I'll save my $$!
09-29-2021, 05:04 PM | #60 | |
Rep 5,092
The wordings imply that even 150000 km interval is optional dependent on usage. I would say one does have to be honest with one's usage to make sense of 60k/150k/lifetime. "ZF automatic transmissions are generally filled with lifetime oil. However, due to the many factors influencing the service life of transmissions in individual operation, ZF recommends an oil change after 150,000 km for its transmissions. In operating conditions with high temperatures and loads, or with unknown vehicle use in the past, it can make sense to change the transmission oil at shorter intervals" https://aftermarket.zf.com/remotemed...fluid-8-it.pdf |
sspade2467.00 |
09-29-2021, 05:15 PM | #61 |
Rep 5,092
Also, ZF says "In principle, an oil change is only necessary when repairs are carried out."
Enthusiasts tend to believe BMW(and ZF) saying fluid is lifetime to entice costly transmission failure(and replacement). My thinking is that as long as owners know their usages are not high temp and high load, this ZF Lifeguard 8 fluid can last past 100k miles and beyond. |
09-29-2021, 05:33 PM | #62 | |
Rep 234
OP, you're correct I didn't include spark plugs in my cost, which were $64. My drive belt is original, but is nearing the end of it's service life, so I'll replace that soon. So far in the first 81k miles, it's been oil changes, all fluids flushed at 68k, and spark plugs. Nothing else. I guess air filters, but they're cheap anyway. My brake pads are nearing the end as well, so that's also coming up. $200-300 coming up I would imagine.
09-29-2021, 08:04 PM | #63 | |
Rep 5,092
Also the BMW AT + throttle map programming is optimized for fuel efficiency such that the gear box gets to 6th and overdrives quickly(with engine rpm@2k 65mph). So normal DD likely does not entice high temp/load operations that much. I would say if towing, track use, and/or sustained autobahn speed, are not the typical usages, following ZF's 150000 km (or lifetime?) interval may not be bad. Last edited by bavarianride; 09-29-2021 at 09:56 PM.. |
09-29-2021, 08:26 PM | #64 | |
Rep 1,643
09-30-2021, 06:02 AM | #65 |
Rep 601
I bought a 2013 328i M sport from Germany in late 2012 while I was in the military. I have since given it to my daughter and it currently has 160K miles. Only problem was one of the turbos had to be replaced about 4 years ago. Other than that just regular maintenance.
09-30-2021, 06:41 AM | #66 | |
Rep 1,643
