BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Blue Spark v DTUK 3 Channel Box with rolling road graphs
      09-03-2017, 01:35 PM   #1
JLR1969
Drives: F10 530D M Sport
Decided to sell the Blue Spark box and was going to get a remap then at the last minute saw that DTUK do a three channel box.
Spoke with Andrew from DTUK and got a good price of 359 delivered.
Fitting was exactly the same as the BS box but with the addition of a connection to the cam sensor for monitoring the cars RPM
The connectors are slightly better than the BS box and are more like the original factory connectors.
The unit itself is a lot more solid and professional and feels very much improved.
A huge improvement over the BS box is the ability to change settings without having to disconnect, wait 5 mins, open the box etc etc. You simply press the buttons to select the setting you want with the engine running.
The hardest part is getting out of the car and opening the bonnet!
So how does the car drive.....
The car performs stronger across the whole rev range, where as the BS delivered a lot of torque straight away the DTUK box delivers continuously it feels stronger.
Maybe less torque lower down but only slightly less, Comfort mode also feels a lot stronger than the BS box before it felt a little dull compared to Sport but now it feels alive and Sport feels stronger still.
In summary the third connection seems to make for a better driving experience and the quality of everything is improved.
I feel as though this is as good as you will get without going for a full remap.
The BS box made 300BHP and 650 Nm so we will see at the rolling road day what this makes.
I would guess at more BHP but maybe slightly less torque so 310 BHP and 630Nm.
There is nothing wrong with the BS box and for 250 it's a fair price and does a good job but spend 50% more and you have another option.
      09-03-2017, 01:41 PM   #2
225
Drives: 340i
Good stuff. I've had one on the 340 for a while now and that bumps up to nearly 390bhp and over 400lb torque. No issues and makes the b58 lump fly!
      09-03-2017, 01:43 PM   #3
A15X
Drives: BMW 430d M sport Convertible
What car do you run this on JLR? I'm interested in a tuning box for my 430d but unsure what to go for.
      09-03-2017, 01:44 PM   #4
JLR1969
It's hard to go back when you have had the extra power isn't it.
Did you consider the pedal box
      09-03-2017, 01:47 PM   #5
JLR1969
It's on a 2016 F10 30D
190kw version (258 BHP)
      09-03-2017, 01:53 PM   #6
A15X
Mines a 2016 430d so must be the same engine I would of though. What's the effect on MPG?
      09-03-2017, 01:58 PM   #7
JLR1969
It's a bit of a myth in my opinion as the tuning box effects the OBD so you have to compare by checking full tank to full tank.
I would say it's no worse if you drive carefully maybe even better but I am not convinced, if you drive hard you use more fuel.
To be concerned about MPG is really missing the point as the overall effect is a transformation in the performance and a car that performs more like a 35D
If I sit on the motorway at 70mph it will easily achieve over 50mpg
Having had a box on the car I would have no hesitation in doing it again.
      09-03-2017, 02:59 PM   #8
Hugrov
Drives: F30 LCI
I have a 3-Channel DTUK box fitted to my 318d and it really does make a big difference, especially in Sport. Yeah ok, my car is never gonna go like a 6-pot diesel but I'm more than happy with the performance with the DTUK fitted, it just pulls so much better right through the range but the delivery is also smooth.
My biggest problem now is whether to just keep the box or get a remap once I'm out of warranty, my head is saying to keep the box. I honestly don't keep an eye on the MPG whatsoever, I just enjoy the increased performance.
JLR19691510.50
      09-03-2017, 03:37 PM   #9
Squiretolley
Drives: F25 X3 35d msport
Are you sure it's 3 channel. Thought they only did a dual channel?
My bad....they do a tri-channel for the 30d
2014 F31 320d M Sport 8AT, MG, M Sport + pack, heated seats, front/rear PDC, M Performance front grille, M Performance twin exhaust pipes.
      09-03-2017, 06:05 PM   #10
JLR1969
Yes I would have noticed
      09-03-2017, 06:37 PM   #11
Watsey
Drives: F31 330D sDrive M Sport
Interesting write-up. Sounds like a much better engineered/resolved solution than the BlueSpark.
Current : F31 330sD, DMS remap, Ohlins Road & Track, Millway Motorsports top mounts, SuperPro poly bushes, Quaife LSD, Stoptech Trophy front BBK / Stoptech discs rear, Pagid RS4-2 and RSL1 pads, H&R ARBs.
      09-03-2017, 06:41 PM   #12
JLR1969
It's it definitly, but it's more money but when you have a 35K+ car an extra 100 is not a consideration.
      09-05-2017, 07:54 AM   #13
335dxdrive
335dxdrive's Avatar
Drives: BMW 335D Xdrive
I was considering a DTUK or TDI tuning 3 channel box
Nice write up
BMW 335d xDrive M Sport
AC Schnitzer Springs | Ferodo DS2500 Pads
Pilot Sport 4S Tyres | Stage 1 Remap
JLR19691510.50
      09-05-2017, 04:35 PM   #14
225
Drives: 340i
Yes that's the problem! Obviously wait and see what the new g series offers but it's going to take something with a bit of oomph to replace this.
      09-05-2017, 05:01 PM   #15
Squiretolley
Just ordered the tri-channel for my 320d. Also got it for 359 delivered.
I've had one of their boxes on an Audi A3 in the past and it was a decent upgrade.
JLR19691510.50
      09-06-2017, 03:13 AM   #16
ahmedb
ahmedb's Avatar
Drives: F30 340i MPPSK
I'm running a tri channel on my F31 330d and I would vouch for it, I've had no issues at all and felt an instance change in performance from the moment it was fitted.
Which settings are you running? When you get your dyno runs, will you be experimenting with the different settings? I was on + and +3 but now I'm trying P +3 and both felt good, the latter seems to work better for comfort but the former I assume gives the most overall gains
Some Previous BMW's:
E90 330d, E90 335d, F31 330d, F30 335d, F30 335i, F31 335d, F30 335i, F30 340i (once confused, now no more).
      09-06-2017, 08:40 AM   #17
JLR1969
I am on P2 map 3 if that makes sense
So the + is on 3 and the P is the middle one
      09-07-2017, 10:17 AM   #18
ahmedb
ahmedb's Avatar
That makes sense, I am currently running the same. I might go back to P3 map 3. Apparently some cars don't agree with this settings and it can throw an engine light (you would notice this immediately) but no issues with me on that map.
      09-07-2017, 10:24 AM   #19
JLR1969
They told me that map 3 is more of an eco map and has less power that map 2
ahmedb238.50
      09-07-2017, 05:47 PM   #20
A15X
Where's the best place to purchase a dtuk box?
      09-07-2017, 06:09 PM   #21
JLR1969
Directly with DTUK
https://www.diesel-performance.co.uk/
      09-08-2017, 02:17 AM   #22
dbramley
320d M-Sport
England
78
Drives: BMW 320si
Let me know what it's like in Sport mode when you get it please and what sort of gains you're expecting. Tempted by one of these.
Thanks
