BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > m sport squeaky breaks
      01-10-2020, 05:40 PM   #1
B58_f32
Drives: 440I M Sport
had my car with m sport breaks for a month now,
and i have researched and know these breaks do squeak on slow application. mostly when coming to a stop at city traffic.
whats bmw's latest fix. do they replace pads and disc. my front ones are showing 4000 miles to replace, still have warranty so wondering if its worth taking it back to get some new free pads/disc
or dont they bother with a fix now
      01-10-2020, 06:09 PM   #2
teaston
Pirate
teaston's Avatar
Drives: X3 M40d
Welcome to F3x ownership, one of the many faults with them! Both of mine did it almost the entire time I had them!
Current: X3 ///M40d in PB/Tartufo
Previous: F30 335d, F30 330d, E90 320d, E46 320d, E46 330ci
      01-10-2020, 06:15 PM   #3
B58_f32
cheers i know its common, there are reports of BMW changing the pads. have they done this recently.
      01-10-2020, 06:23 PM   #4
teaston
Pirate
teaston's Avatar
Drives: X3 M40d
They changed the pads on the Gxx models, they have sticky pads that hold the pads on the brake pistons. I havenít heard of any foolproof fixes for the Fxx, just clean and liberally apply Ceratec paste which will stop the squealing for a few thousand miles if youíre lucky.
      01-11-2020, 03:58 AM   #5
muffking
Regular user
muffking's Avatar
Drives: F30 330D M-Sport Auto
All I can tell you is that I tried all sorts on my old one and the only thing that stopped it was by changing to grooved front discs which clean off the surface of the pads and prevent the squeal.
My current F30 doesn't squeal, but as it has a full BMWSH it probably has current BMW pads, maybe try those first and give everything a clean & grease while you're in there..
      01-11-2020, 04:11 AM   #6
teaston
Pirate
teaston's Avatar
Drives: X3 M40d
But in contrast I fitted grooved discs and they still squealed!
      01-11-2020, 04:12 AM   #7
KRS_SN
Drives: F15,F30, F34, E91.
Had the squeal on mine. Pads had about 10k miles left on them. I figured it was something to do with Brake pad compound BMW uses. So took a risk and changed over to Pagid brake pads front and back (total cost at indy £220) 3 months ago. Now silence!
      01-11-2020, 04:21 AM   #8
Rhino at Work
Rhino at Work's Avatar
391
Drives: EB F30 340i Shadow Edition
Interesting. It shouldn't be necessary but maybe it would be worth it.
Has anyone ever worked out whether it's the fronts or rears or both that squeal? It always seems to me it's the fronts but that may just be because I'm in the front seat.
Current: EB F30 340i Shadow Edition with even more toys
Previous: EB F30 330d xdrive with lots of toys
      01-11-2020, 04:55 AM   #9
KRS_SN
yes definitely its the fronts from my assessment. The Mrs would know im home before i rung the bell due to the squeal from the brake.
      01-11-2020, 05:02 AM   #10
SkyJawa
SkyJawa's Avatar
England
2376
Drives: 335d
My BRAKES squealed until I fitted grooved and dimpled TRW discs (with stock pads), not happened since, yet.....
      01-11-2020, 05:41 AM   #11
teaston
Pirate
teaston's Avatar
Drives: X3 M40d
I also tried Pagid pads, still squealed!!
      01-11-2020, 06:04 AM   #12
KRS_SN
oh!. I just got lucky then.
      01-11-2020, 06:37 AM   #13
JeffBMW4Series
Drives: 430i F33 Convertible
My cars in the local garge again to change from pads to BMW ones now. Been doing my head in the noise. Not a low squeal mines been an embarassing high pitched noise. I'm hoping to god these one's finally sort out the isse. Only seems to be from drivers side.
My wife knows when I'm 10 mins from home..... Lol
      01-11-2020, 07:10 AM   #14
ian332isport
ian332isport's Avatar
Drives: F31 340i Shadow Edition
In contrast, my 2018 car has never made a sound. Still on the original discs/pads.
      01-11-2020, 07:18 AM   #15
teaston
Pirate
teaston's Avatar
Drives: X3 M40d
It is strange that it doesn't affect some cars. Do you spend a lot of time on motorways?
      01-11-2020, 07:34 AM   #16
Rhino at Work
391
I have found that if you find a quiet bit of road and then absolutely stand on the brakes from 50+ mph it does seem to cure the problem for a bit.
      01-11-2020, 07:47 AM   #17
johnung
Must be the stock pads and/or improper installation as far as cleaning and applying the correct amount of grease in the correct areas. I've had different combinations of calipers and rotors on my car, all with Hawk 5.0 pads, and have never had any noise.
      01-11-2020, 08:01 AM   #18
JeffBMW4Series
Just got my 430i back and done a quick 20 miles, so far perfect.....hopefully now stay that way.
      01-11-2020, 01:55 PM   #19
ian332isport
Completely the opposite actually. Lots of short local journeys for the most part.
      01-11-2020, 01:56 PM   #20
teaston
Pirate
teaston's Avatar
Drives: X3 M40d
Just like my driving, strange!
      01-11-2020, 02:05 PM   #21
KRS_SN
I do 15k/yr motorway 90% still mine squealed like crazy.
      01-11-2020, 06:23 PM   #22
ukbeemerboy
Beemer Heaven
ukbeemerboy's Avatar
Drives: BMW 330d M Sport
Never had an issue with either of my F30 with M Sport brakes. The biggest killer of the brakes is TFR which these dodgy car washes use by the gallon.
Scott
2017 BMW 330d M Sport
2019 Mini Countryman Cooper S : 2008 Mini Cooper
