BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Retrofitting idrive touch.
      01-16-2020, 10:07 AM   #1
Mr_Breaker
Drives: 2012 BMW F30 330D
Hello guys. I'm looking to upgrade my standard Idrive controller to the touch version.
Is it a simple case of just getting the idrive touch and swapping it out and then coding? Or would I need some kind of module seems my car is a 2012 f30?
      01-16-2020, 12:14 PM   #2
robbiep
Drives: F31 325d M Sport, Z4 20Si
Won't work. The iDrive system is completely different, software and hardware
      01-16-2020, 03:57 PM   #3
MH94
MH94's Avatar
Drives: BMW F30
It's one feature that I have but really could live without as i only used it once which was when I picked the car up for the novelty of it and that's been it ever since
      01-16-2020, 04:48 PM   #4
Medslow
Drives: F31 340i Superman combo, MPE.
Same here... Sooooo useless. I wouldn't miss it.
The only thing going for it is the larger wheely thing.
      01-16-2020, 05:08 PM   #5
HarryTee
Drives: 2017 440i Coupe & 440i GC
I don't think I would use the touch feature much but I imagine it'd be useful to use our finger to move around on the map. Without touch, you can only shrink or enlarge the map but are unable to explore/ see areas near where you are, am I correct?
      01-16-2020, 05:14 PM   #6
robbiep
No, with the old type you can move to other areas of the map via the left-side jog menu, and then zoom in and out on those
      01-16-2020, 05:14 PM   #7
Medslow
You can still move and zoom without touch.
In theory it would be easier yes... But it's still a pain to move around using the touch.
I think in the 3 years I've had IDrive (both with and without touch), I've used the free look map feature about twice.
      01-17-2020, 01:54 AM   #8
WillLowe
Drives: F32 435d
I find it useful for typing postcodes, scrolling around the map, and even for adjusting the equalizer. Maybe being left handed helps?
      01-17-2020, 02:02 PM   #9
HarryTee
Thanks! Didn't know about this and just tried it out now
Learned something already, in just one day of joining
      01-17-2020, 03:01 PM   #10
muniz_ri
Drives: BMA 320I
A related question....I have a 2016 320I (lci) with the basic idrive controller that only moves left or right, the one without the nav button.
If I plugin the controller version with the nav button that moves left, right, and up and down will I gain the ability to move up and down on the idrive screen?
I retrofitted an Android Auto mmi and need the up and down movement in order to easily access incoming call notifications.
      01-18-2020, 12:08 PM   #11
Mr_Breaker
so I would have to upgrade to NBT?
