BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Exhaust advice pls. Catless DP with Remus axle-back 440i
      07-09-2019, 12:20 AM   #1
Var
Drives: 2019 440i
I recently installed an ER catless downpipe and an AFE intake on my 440i. I really enjoy the increase in exhaust note but it's just slightly too quiet still. After doing some reading, it seems like the Remus axle-back is the quietest option out there and what I would probably spring for. The only reason I haven't ordered it and I'm still on the fence is I'm concerned about drone. Currently from the cockpit with the valves closed, there's no discernable difference between stock and catless DP. I can cruise around lightly accelerating or cruising on the freeway with basically no difference in sound.
In an ideal world, I could keep the same closed-valve sound and just go louder with the open valve but I don't think that's an option. So I'm willing to take a noise increase as long as it's not droney.
Does anyone have any experience with catless downpipe and Remus axle-back that can confirm yay or nay on increased drone?
      07-09-2019, 08:45 AM   #2
Solid67
Drives: 2019 M240i xDrive MP Edition
If you are just getting the axle back then it will not drone. Drone only occurs when you get rid of the midpipe since it has two resonators. If you got the Remus catback they do have an option for a resonated or non-resonated midpipe. In your case, you would want to get the resonated midpipe or just keep the stock one.
Var8.50
      07-09-2019, 11:17 AM   #3
SoCalCarGuy
Drives: 2019 440ix cpe + 2018 x4 m40i
if you want more sound, I strong recommend going to good exhaust shop and ask them to cut off your resonators and put weld in some 3" pipes instead. (cost me $100 in Los Angeles) I have this with a DP and stock catback. it sounds amazing! No need to spend $x,xxx on an exhaust.
      07-09-2019, 12:31 PM   #4
Var
Drives: 2019 440i
Not a huge fan of the midpipe delete sound. I run even bigger than factory resonators usually on my catless cars
      07-09-2019, 12:43 PM   #5
E90ROXS
E90ROXS's Avatar
225
Drives: E90
With aftermarket exhausts you will get drone regardless of which brand and what you do. I have Remus exhaust with resonated midpipe and dp. I even got the external flap controller so I can close or open at any given time. City driving is great. However if I take the car out on a long drive (highway) especially on a hot day, the drone is there. By the way, it's very important that you move the tips out from the bumper as far as possible. Some people like to leave the tips behind the bumper. That's how they get that nasty drone.
      07-09-2019, 12:45 PM   #6
Var
Drives: 2019 440i
So you had the remus midpipe? I imagine that's a bit louder than the stock one right?
      07-09-2019, 01:57 PM   #7
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Get the REMUS axle back, with stock mipdipe drone is minimal if any
https://x-ph.com/sale/
Phone number 702-494-9435
Var8.50
      07-09-2019, 02:50 PM   #8
E90ROXS
E90ROXS's Avatar
225
Drives: E90
Remus midpipe is 1-2-1. Meaning it splits from 1 pipe into 2 pipes then come back into 1 pipe then to the exhaust. This method supposed to make the sound more deeper. I think it's louder than stock midpipe since the stock one has that big ass cat or resonator. I don't know what it is.
      07-10-2019, 12:38 PM   #9
jinh123
Drives: 2019 440i xDrive Coupe
Yes I agree 100%. I have the Dinan axle back paired with a vrsf catted downpipe. The Dinan has no flaps so it's full on sound the entire time from comfort to sport plus. There is a bit of drone cruising at 1.5k rpms 60 mph-70 mph but otherwise in my experience, it sounds amazing in all other rpms. My solution to the drone though is if I throw the car into sport automatic . It raises the rpm to around 2k while cruising and drone is gone.
      07-10-2019, 06:07 PM   #10
Var
Drives: 2019 440i
Does the Remus axle-back require any cutting? Also is it the same part for the 340 and the 440?
      08-12-2019, 01:32 PM   #11
Var
Drives: 2019 440i
I installed the Remus axle back over the weekend. And lo and behold I was pretty disappointed. It's barely 5% louder than stock even with a catless DP. And I had to cut my factory midpipe to install it. I'm at an exhaust shop getting the resonators hacked off right now. Hopefully this "fixes" the exhaust situation.
      08-14-2019, 10:09 AM   #12
zeenon53
zeenon53's Avatar
39
What do you think? I'm torn between the remus and Dinan myself.
2016 340i xdrive
2009 335i
      08-14-2019, 02:10 PM   #13
Astute
PsyD
Astute's Avatar
Drives: 2016 340i M-sport
You could also do the Remus catback with the midpipe.
      08-14-2019, 02:12 PM   #14
Var
Drives: 2019 440i
I went ahead and chopped the resonators off and it's pretty raspy now. But it's the correct volume one would expect with valves open/closed now. So I can add a resonator back in and that would quiet it down maybe too much? Not sure. The Remus muffler is too conservative IMO.
I've heard Dinan and Remus are the complete opposite ends of the spectrum as far as volume. I don't have any experience with the Dinan stuff so I couldn't give you good advise on that specifically. I think it also really depends on your DP (catted or catless) and also if you're doing axleback or catback. It's the entire combination of parts that dictates the tone, volume, rasp, and drone.
I will just say this about Remus specifically. It seems like the system was not engineered to be used like i'm using it. The best way to use it is probably with the stock downpipe and the entire Remus catback system. Once you go catless all bets are off with non-resonated midpipes. Exhaust tone is so subjective and exhaust parts are so expensive. You should be very careful on what you choose. At this point I think I will probably just "settle" because I can't just keep buying new exhaust parts. The only thing I might do is add a small resonator back to the system if the rasp remains too annoying. I'm kinda getting used to it at this point.
      08-14-2019, 02:20 PM   #15
Var
Drives: 2019 440i
Ya true but I basically achieved the same effect for $200 vs $700 plus labor. Although the divorced piped on the Remus might give a different tone, I don't know if it would do anything about the rasp
      08-14-2019, 05:38 PM   #16
Var
Drives: 2019 440i
I take back about it being raspy. I just had a friend drive it by for me and it heard it from the outside. Actually sounds pretty good.
      08-14-2019, 08:18 PM   #17
mike@x-ph.com
      08-15-2019, 11:52 AM   #18
zeenon53
zeenon53's Avatar
39
Thank you!
2016 340i xdrive
2009 335i
      08-15-2019, 06:31 PM   #19
SoCalCarGuy
glad you went with my my recommendation! I think our cars sound pretty sick for having stock mufflers and only changing downpipe/resonator delete. throw a stage 2 e30 tune on and we have mid-high 11 sec street warriors.
      08-16-2019, 12:32 PM   #20
Var
Drives: 2019 440i
I was honestly worried about the rasp but it ended up sounding good. I've heard much worse results from other cars. I guess it really depends on the muffler as well.
As for the tune, I have garbage fuel here so I'm running the BM3 stage 2 ACN91 tune. Better than nothing I guess
      08-16-2019, 04:43 PM   #21
SoCalCarGuy
Go get some E85 and switch to e30 tune!! Worth the 15 mile drive.
Download the Pearson fuels app
Var8.50
