10-01-2018, 09:20 AM | #2421 | |
Rep 164
Drives: 2016 M4/F82 MGM/SO
2016 F82/M4 DCT. MGM/SO Ext. leather. All the buttons.
10-01-2018, 09:22 AM | #2422 |
Rep 40,765
Use newest version, in this case f020_18_07_547_v_004_001_000.
TheONE2440.50 |
10-01-2018, 11:37 AM | #2424 | |
Rep 2,302
That depends on your cars I-Step. If the I-Step is brand new, you should also use the latest psdzdata and target. If the I-Step is older, you can also use older psdzdata or target. psdzdata or target must be always newer than the cars i-step. |
TheONE2440.50 |
10-01-2018, 12:51 PM | #2425 |
Rep 4
10-02-2018, 12:45 AM | #2426 |
Rep 1,123
10-02-2018, 03:07 AM | #2427 |
Rep 2,302
10-02-2018, 12:52 PM | #2428 | |
Rep 164
I had a similar issue when setting up 2.8.2 inside a VM. I was able to install it by deleting out the VM check in the msi installer but it would not actually start. I tried poking around in the dll files but couldn't find what I was looking for. Anyways, if you open task manager you should see it in there for about 30 seconds before it disappears. If so then check your event log>>Applications. It should tell you what check it is failing in the descriptions. Mine was still searching for, and able to find, a VM in the code. In case anyone is wondering and using VMWare Workstation, yes you can still install in a VM and get it to work. Just not without some manipulation.
10-02-2018, 12:58 PM | #2429 |
Rep 40,765
Did you attempt at some time to change System Date back in order to rearm Launcher premium after it's Token expired?
10-03-2018, 11:24 AM | #2430 |
Rep 1,123
10-03-2018, 11:36 AM | #2431 |
Rep 40,765
I replied to it.
10-04-2018, 01:42 PM | #2433 |
Rep 40,765
PM sent.
10-12-2018, 11:35 AM | #2435 | ||
Rep 2,302
10-12-2018, 01:35 PM | #2436 |
Rep 40,765
PM sent.
11-08-2018, 05:42 PM | #2438 |
Rep 40,765
PM sent.
11-08-2018, 07:42 PM | #2440 |
Rep 40,765
11-18-2018, 10:05 AM | #2442 |
Rep 40,765
