12-02-2021, 07:39 PM | #23 | ||
Rep 1,934
And No you got that backwards. The run flats make it slower because they are heavier then an go flat in the same size. For eg, the stock and summer config I have in my photo are two different tire sizes. Oem is 225/45/18. My summer setup is 255/40/18 and still about 5lbs lighter.
12-02-2021, 08:04 PM | #24 | ||||
Rep 1,934
12-02-2021, 08:11 PM | #25 | |||||
Rep 188
Agreed 100% on go flats, best decision I've made so far on my car. No worries on hijacking my original post. My topics recently have led to some good discussion. So I'm still deciding on rotors and pads to maintain the 340/330 setup. Regardless of where I land, I do plan on upgrading the lines and doing a fluid flush. Any specific fluid brand/spec you recommend? Edit: no need to reply on the fluid rec. I see it in your original reply, unless you care to expand on it some.
2015 M-Sport 435i xDrive (6MT)
MHD Stage 2+ / VRSF Catted DP / ARM F3X IC / BMS CP / AFE Pro Dry S |
12-02-2021, 08:21 PM | #26 | ||||||
Rep 1,934
